path: root/tools
2007-11-20[BUILD] Generate include/autoconf.mk from board config filesGrant Likely
Use cpp and sed to postprocess config.h and import the defined values into include/autoconf.mk. autoconf.mk is then included by config.mk to give 'make' access to the board configuration. Doing this enables conditional compilation at the Makefile level instead of by wrapping every .c file with #ifdef/#endif wrappers. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-11-15Add .gitignore filesGrant Likely
Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Kim Phillips <kim.phillips@freescale.com>
2007-08-03Merge branch 'testing' into workingAndy Fleming
Conflicts: CHANGELOG fs/fat/fat.c include/configs/MPC8560ADS.h include/configs/pcs440ep.h net/eth.c
2007-07-10disk/ doc/ lib_*/ and tools/: Remove lingering references to CFG_CMD_* symbols.Jon Loeliger
2007-07-09tools/: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
2007-07-10Coding style cleanup; update CHANGELOG.Wolfgang Denk
2007-07-09Merge with /home/hs/Atronic/u-bootWolfgang Denk
2007-07-04tools/ : Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2007-06-22[PCS440EP] upgrade the PCS440EP board:Heiko Schocher
- Show on the Status LEDs, some States of the board. - Get the MAC addresses from the EEProm - use PREBOOT - use the CF on the board. - check the U-Boot image in the Flash with a SHA1 checksum. - use dynamic TLB entries generation for the SDRAM Signed-off-by: Heiko Schocher <hs@denx.de>
2007-05-15Fix compilation issues on MACOSXAubrey.Li
Singed-off-by: Marc Hoffman <Marc.Hoffman@analog.com> Signed-off-by: Aubrey Li <aubrey.adi@gmail.com>
2006-10-11Merge with /home/wd/git/u-boot/masterWolfgang Denk
2006-10-09Define IH_CPU_AVR32Stefan Roese
Make it possible to generate AVR32 uImage files with mkimage and make cmd_bootm recognize them. Patch by Haavard Skinnemoen, 22 Sep 2006
2006-10-09Coding style cleanupWolfgang Denk
2006-09-06Fix mkimage -l bug with multifile images on 64bit platformsWolfgang Denk
Patch by David Updegraff, 06 Sep 2006
2006-09-01Fix tools/updater build error.Marian Balakowicz
2006-09-01tools/easylogo/easylogo.cMarian Balakowicz
2006-08-16* Support for FDT in uImage format, error when using FDT from flashMatthew McClintock
Signed-off-by: Matthew McClintock <msm@freescale.com>
2006-04-28Fixed handling of bad checksums with "mkimage -l"Wolfgang Denk
2006-03-12Fix array overflow with fw_setenv on uninitialised environmentWolfgang Denk
Patch by Murray Jensen, 15 Jul 2005
2006-03-12Add ADI Blackfin supportWolfgang Denk
- add support for Analog Devices Blackfin BF533 CPU - add support for the ADI BF533 Stamp uClinux board - add support for the ADI BF533 EZKit board Patches by Richard Klingler, June 11th 2005:
2006-02-21Add GIT version information (commid ID) to untagged U-Boot versionsWolfgang Denk
As done in the linux kernel, the U-Boot version (U_BOOT_VERSION) of all unreleased (untagged) U-Boot images will be automatically extended upon compiletime with a part of the GIT commit ID and possibly with "dirty" if uncommited changes are detected. Here an example for the resulting version: "U-Boot 1.1.4-g3457ac18-dirty" The version is now maintained in the toplevel Makefile and the version headers are autogenerated. Patch by Stefan Roese, 9 Feb 2006
2006-01-11Fix mkimage bug with multifile images created on 64 bit systems.Wolfgang Denk
2005-10-11Added support for TQM834x boards.Marian Balakowicz
2005-09-25Fix tools/bmp_logo.c using incorrect offset to pixel dataWolfgang Denk
Patch by Andrew Dyer, 31 Jan 2005
2005-09-25Fix error handling in tools/env/fw_env.cWolfgang Denk
Patch by Ara Avanesyan, 01 Feb 2005
2005-08-12Update Hymod Board Database PHP code in "tools" directoryWolfgang Denk
Patch by Murray Jensen, 01 Jul 2005
2005-08-12Fix Murray Jensen's mail address.Wolfgang Denk
Patch by Murray Jensen, 30 Jun 2005
2005-08-03Cleanup build problems (on Fedora Core x86_64 build host)Wolfgang Denk
2005-07-21Fix file permissionsWolfgang Denk
2005-04-03* Patch by Scott McNutt, 01 Nov 2004:wdenk
Add missing NIOS/NIOS2 support for "iminfo" command * Patch by Detlev Zundel, 29 Oct 2004: Add missing NIOS/NIOS2 support for "mkimage" tool.
2004-12-31* Code cleanup, mostly for GCC-3.3.xwdenk
* Cleanup confusing use of CONFIG_ETH*ADDR - ust his only to pre-define a MAC address; use CONFIG_HAS_ETH* to enable support for additional ethernet addresses. * Cleanup drivers/i82365.c - avoid duplication of code * Fix bogus "cannot span across banks" flash error message * Add support for CompactFlash for the CPC45 Board.
2004-11-21* Update for AT91RM9200DK and CMC_PU2 boards:wdenk
- Enable booting directly from flash - fix CMC_PU2 flash driver * Fix mkimage usage message
2004-10-10* Configure SX1 board to use drivers/cfi_flash.cwdenk
* Patches by Michael Bendzick, 30 Aug 2004: - Configure omap1510inn board to use drivers/cfi_flash.c - Make drivers/cfi_flash.c protect environment and redundant environment. * Patch by Steven Scholz, 23 Jun 2004: - Add script (tools/img2brec.sh) to programm U-Boot into (Synch)Flash using the Bootstrap Mode of the MC9328MX1/L
2004-10-09* Clean up tools/bmp_logo.c to not add trailing white spacewdenk
* Patch by Hinko Kocevar, 21 Aug 2004: - Group common framebuffer functions in common/lcd.c - Group common framebuffer macros and #defines in include/lcd.h - Provide calc_fbsize() for video ATAG
2004-09-28* Patch by Yuli Barcohen, 19 Jul 2004:wdenk
- Fix host tools building in Cygwin environment - Fix header files search order for host tools * Patch by Tom Armistead, 19 Jul 2004: Fix kgdb.S support for 74xx_75x cpu
2004-09-08* Patch by Detlev Zundel, 08 Sep 2004:LABEL_2004_09_09_0000wdenk
Update etags build target * Improve NetConsole support: add support for broadcast destination address and buffered input. * Cleanup compiler warnings for GCC 3.3.x and later * Fix problem in cmd_jffs2.c introduced by CFG_JFFS_SINGLE_PART patch
2004-07-10* Rename SBC8560 into sbc8560 for consistencywdenk
* Patch by Daniel Poirot, 24 Jun 2004: Add support for Wind River's sbc8240 board * Patches by Yasushi Shoji, 26 Jun 2004: - drivers/serial_xuartlite.c: fix "return 0" in void function - add microblaze support to mkimage tool
2004-02-26* Patch by Rahul Shanbhag, 19 Feb 2004:wdenk
Fixes for for OMAP1610 board: - shift some IRQ specific code to platform.S file - remove duplicatewatchdog reset code from start.S * Make Auto-MDIX Support configurable on INCA-IP board * Fix license for mkimage tool
2003-12-06* Patch by Gleb Natapov, 19 Sep 2003:wdenk
Move most of the timer interrupt related PPC code to ppc_lib/interrupts.c * Patch by Anders Larsen, 17 Sep 2003: Bring ARM memory layout in sync with the documentation: stack and malloc-heap are now located _below_ the U-Boot code
2003-11-17* Use "-fPIC" instead of "-mrelocatable" to prevent problems withwdenk
recent tools * Add checksum verification to 'imls' command * Add bd_info fields needed for 4xx Linux I2C driver * Patch by Martin Krause, 4 Nov. 2003: Fix error in cmd_vfd.c (TRAB board: "vfd /1" shows now only one Bitmap) * Print used network interface when CONFIG_NET_MULTI is set
2003-10-30* Fix parameter passing to standalone images with bootm commandU-Boot-1_0_0wdenk
* Patch by Kyle Harris, 30 Oct 2003: Fix build errors for ixdp425 board * Patch by David M. Horn, 29 Oct 2003: Fixes to build under CYGWIN * Get IceCube MGT5100 working (again)
2003-10-08* Patch by Anders Larsen, 18 Sep 2003:wdenk
allow mkimage to build and run on Cygwin-hosted systems * Patch by Frank Müller, 18 Sep 2003: use bi_intfreq instead of bi_busfreq to compute fec_mii_speed in cpu/mpc8xx/fec.c * Patch by Pantelis Antoniou, 16 Sep 2003: add tool to compute fileds in the PLPRCR register for MPC86x
2003-10-07Fix build problems under FreeBSDwdenk
2003-10-06Add generic filesystem image typewdenk
2003-09-16Make IPB clock on MGT5100/MPC5200 configurable in board config file;wdenk
go back to 66 MHz for stability
2003-08-17* Make Ethernet autonegotiation on INCA-IP work for all clock rates;U-Boot-0_4_6wdenk
allow selection of clock frequency as "make" target * Implement memory autosizing code for IceCube boards * Configure network port on INCA-IP for autonegotiation * Fix overflow problem in network timeout code * Patch by Richard Woodruff, 8 Aug 2003: Allow crc32 to be used at address 0x000 (crc32_no_comp, too).
2003-08-07Removed the file tools/gdb/astest.cdzu
2003-08-07Removed tools/gdb from "make all" target. Added make target "gdbtools"dzu
in toplevel directory instead. Removed astest.c from tools/gdb because it is no longer relevant.
