Patch fixes this issue:
fw_env.c: In function ‘fw_setenv’:
fw_env.c:492:5: warning: format ‘%u’ expects argument of type ‘unsigned int’, but argument 3 has type ‘size_t’ [-Wformat]
fw_env.c: In function ‘flash_write_buf’:
fw_env.c:806:6: warning: format ‘%u’ expects argument of type ‘unsigned int’, but argument 3 has type ‘size_t’ [-Wformat]
Signed-off-by: Luka Perkov <lists@lukaperkov.net>
mkimage's ublimage support can't depend of build-time board configs;
instead, this should be set in ublimage.cfg. Since currently no configs
in u-boot override the NAND block size, hardcode it as such in
ublimage.h to fix a build failure with "make tools":
gcc [...] -o ublimage.o ublimage.c -c
In file included from ublimage.c:37:0:
ublimage.h:31:20: fatal error: config.h: No such file or directory
Cc: patches@linaro.org
Signed-off-by: Loïc Minier <loic.minier@linaro.org>
Acked-by: Heiko Schocher <hs@denx.de>
Some images have not a header of fix lenght. The patch will be
used for the generation of AIS images, because this header has
a variable lenght. The patch adds also the parameter "-s" (skip)
to not copy automatically the passed image file.
Each image handler must return a not-zero velue if the
header is not recognized to allow the main program to
iterate to the next handler.
CC: Heiko Schocher <hs@denx.de>
Using mkimage with e.g.
tools/mkimage -A arm -T firmware -O u-boot -d u-boot.bin foo.img
gives a warning
"Unknown OMAP image type - 5"
while it seems that the image itself is created successfully.
This does come from the patch "mkimage: Add OMAP boot image support".
The method check_image_type in image_type_params is supposed to just
return success or failure. However, for omap it also calls fprintf:
static int omapimage_check_image_types(uint8_t type)
if (type == IH_TYPE_OMAPIMAGE)
return EXIT_SUCCESS;
else {
fprintf(stderr, "Unknown OMAP image type - %x", type);
return EXIT_FAILURE;
All the other image checkers and no others have this, so the fix is to
simply remove the fprintf.
Signed-off-by: Dirk Behme <dirk.behme@googlemail.com>
CC: John Rigby <john.rigby@linaro.org>
CC: Aneesh V <aneesh@ti.com>
CC: Sandeep Paulraj <s-paulraj@ti.com>
- Add mkimage support for OMAP boot image
- Add support for OMAP boot image(MLO) generation in the new
SPL framework
Signed-off-by: John Rigby <john.rigby@linaro.org>
Signed-off-by: Aneesh V <aneesh@ti.com>
Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
Add support for:
1. DPLL locking
2. Initialization of clock domains and clock modules
3. Setting up the right voltage on voltage rails
This work draws upon previous work done for x-loader by:
Santosh Shilimkar <santosh.shilimkar@ti.com>
Rajendra Nayak <rnayak@ti.com>
The INCA-IP SoC belongs to the Lantiq XWAY SoC product portfolio.
For the upcoming support of other Lantiq SoC devices this tool should
not solely depend on the INCA-IP board.
Rename the tool to xway-swap-bytes and add an config option
to enable compilation optionally.
Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
Acked-by: Thomas Langer <thomas.langer@lantiq.com>
Signed-off-by: Shinya Kuribayashi <skuribay@pobox.com>
creating an u-boot.ubl file, which contains the UBL Header
needed for booting from NAND with the RBL from TI. For more
information read doc/README.ublimage.
For people who want to manually extract the embedded environment so that
it can be manually packed into the final u-boot image, add a config opt
to force building of the envcrc tool.
On Sunday, June 19, 2011 13:55:13 Ilya Yanok wrote:
> On 18.06.2011 23:03, Mike Frysinger wrote:
> >> - tools/Makefile put common/env_embedded.o and envcrc.o to object list
> >> conditionally. This fixes errors during dependency generation.
> > pretty sure this breaks board builds. if the only thing this fixes is a
> I'm sorry but I can't see how this can break the builds. Could you
> please be more specific? I've tried to build some boards, it actually
> works...
i might be thinking of a different env_embedded situation. a different
problem with your patch to tools/Makefile: you copied the same logic multiple
times which means more bitrot.
why dont you do something like:
> > harmless warning when generating dependency files, then i say ignore it.
> > after all, this is how it has always worked in the past and no one really
> > cared.
> Yep, they are harmless but they are not warnings but rather scary errors
> actually. ;) I think it's better to fix them.
i guess my threshold for being scared is a bit higher :p
-mike
The 'trab' board configuration is broken, and there is nobody who is
interested and willing to fix it. Drop it.
This includes support for VFD displays which have always been used by
this board only.
This reverts commit bbc6353c740064c8e0741b772376a1a67a1c3f01.
It breaks building on many systems:
.../common/env_embedded.c:28:20: fatal error: config.h: No such file or directory
compilation terminated.
.../common/image.c:27:20: fatal error: common.h: No such file or directory
.../lib/crc32.c:12:20: fatal error: common.h: No such file or directory
.../lib/md5.c:28:22: fatal error: compiler.h: No such file or directory
.../lib/sha1.c:33:20: fatal error: common.h: No such file or directory
calc_hdrcsum two times are checked. checksumi of exthdr is not checked.
Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
CC: Prafulla Wadaskar <prafulla@marvell.com>
- don't include config.h when building with host cc,
- HOSTCFLAGS was defined with the wrong name, so wasn't used,
- make sure make finds sources outside of tools/.
Signed-off-by: François Revol <revol@free.fr>
Signed-off-by: Luca Ceresoli <luca.ceresoli@comelit.it>
This fixes two bugs with comparison of redundant environment flags on
read.
flag0 and flag1 in fw_env_open() were declared signed instead of
unsigned char breaking BOOLEAN mode "== 0xFF" tests and in INCREMENTAL
mode the wrong environment would be chosen where the flag values are
127 and 128 (either way round). With both flags over 128, both signs
flipped and the logic worked by happy accident.
Also there was a logic bug in the INCREMENTAL test (after signedness was
fixed) in the case flag0=0, flag1=255, env 1 would be incorrectly chosen.
Fix both of these.
Signed-off-by: Jon Povey <jon.povey@racelogic.co.uk>
* The sector size for SPI-dataflash (like AT45 flashes) are not always
a power-of-2. So, the sector calculations are rewritten such that it
works for either power-of-2 as any size sectors.
* Make the flash sector size optional in case it is the same value as
the environment size.
Signed-off-by: Remy Bohmer <linux@bohmer.net>
"make tools-all" should allow building tools such as mkimage and the new
imximage without any config, but imximage.c currently fails to build
with:
imximage.h:27:20: error: config.h: No such file or directory
config.h is not needed in imximage.h nor in imximage.c, and imximage.h
is only included from imximage.c, so drop this include to fix the build.
This patch add the MX53 boot image support.
This patch has been tested on Freescale MX53EVK board
and MX51EVK board.
Signed-off-by: Jason Liu <r64343@freescale.com>
Reorder including config.mk before the HOSTCC check, so HOSTCC is
actually defined when checking for it.
Cleaned up commit message
This patch makes tools/env/Makefile more similar to tools/imls:
- define HOSTSRCS and HOSTCPPFLAGS, so that .depend generation works.
- include U-Boot headers using -idirafter to prevent picking up
u-boot/include/errno.h.
- use HOSTCFLAGS_NOPED (fw_env.c does not conform to -pedantic).
In order to cross-compile tools/env, override the HOSTCC variable
as in this example:
make tools env HOSTCC=bfin-uclinux-gcc
Signed-off-by: Daniel Hobi <daniel.hobi@schmid-telecom.ch>
Tested-by: Detlev Zundel <dzu@denx.de>
Tested-by: Steve Sakoman <steve.sakoman@linaro.org>
When copying the "sed" script to generate the asm-offsets.h file from
the Linux Kbuild script into the make-asm-offsets file I missed the
fact that the former runs in a "make" context and thus uses double
"$$" to escape a single "$", while the latter is a shell script, where
this must not be done. Unfortunately the problem did not show up
during the initial tests on Power Architecture systems, but on ARM the
generated asm-offsets.h was not correct.
Tested-by: Heiko Schocher <hs@denx.de>
Tested-by: Ben Gardiner <bengardiner@nanometrics.ca>
A recurrent issue is that certain C level constructs like sizeof() or
offsetof() cannot be used in assembler files, which is inconvenient
when such constructs are used in the definition of macro names etc.
To avoid duplication of such definitions (and thus another cause of
problems), we adapt the Linux way to automatically generate the
respective definitions from the respective C header files.
In Linux, this is implemented in include/linux/kbuild.h, Kbuild, and
arch/*/kernel/asm-offsets.c; we adapt the code from the Linux v2.6.36
kernel tree.
We also copy the concept of the include/generated/ directory which can
be used to hold other automatically generated files as well.
We start with an architecture-independent lib/asm-offsets.c which
generates include/generated/generic-asm-offsets.h (included by
include/asm-offsets.h, which is what will be referred to in the actual
source code). Later this may be extended by architecture-specific
arch/*/lib/asm-offsets.c files that will generate a
include/generated/asm-offsets.h.
Acked-by: Kumar Gala <galak@kernel.crashing.org>
When generating include/autoconfig.mk, hex numbers would be quoted.
This caused some false positives during automatic testing of the
builds, and is known to cause some real issues for some Blackfin
configurations. Don't use apostophes for decimal and hex numbers (nor
for octal numbers).
The change is currently needed to be able to remove the board
configuration scripting from the top level Makefile and replace it by
a simple, table driven script.
Moving this configuration setting into the "CONFIG_*" name space is
also desirable because it is needed if we ever should move forward to
a Kconfig driven configuration system.
Commit d984fed0 (makefiles: fixes for building build tools)
changed the variable name FIT_CFLAGS to HOSTCFLAGS_NOPED
but forgot to update to corresponding comment.
Cc: Scott Wood <scottwood@freescale.com>
include/ppc4xx.h
Add the Freescale logo and update the Makefile to build it when building
a Freescale board.
If working out of a custom git tree that lacks annotated tags, the
'git describe' operation spews "fatal: cannot describe" errors all
over the place. So add some fallback code in case the best naming
was unable to locate something useful.
Convert the tools/env/Makefile to use the same host tool syntax as the
other tool subdirs.
In commit bd7b26f8 (Tools: set multiple variable with fw_setenv utility),
the option parsing was changed to getopt_long(3), but option "-n"
of fw_printenv was not included.
This leads to an error message "invalid option -- 'n'" on stderr,
although the output on stdout is correct.
This patch adds support for the jadecpu board using the
MB86R01 'Jade' SoC from Fujitsu.
Signed-off-by: Matthias Weisser <weisserm@arcor.de>
The invalidation of the old environment instance did not work for flashes
supporting hardware locking. Now we unlock/lock around this update also.
Signed-off-by: Detlev Zundel <dzu@denx.de>
Avoid extra carriage returns in the output by disabling output processing.
Otherwise, whenever the remote sends a \r\n, we end up with \r\r\n.
Reported-by: Vivi Li <vivi.li@analog.com>
Lots of code use this construct:
cmd_usage(cmdtp);
return 1;
Change cmd_usage() let it return 1 - then we can replace all these
ocurrances by
return cmd_usage(cmdtp);
This fixes a few places with incorrect return code handling, too.
Add a sort of batch mode to fw_setenv, allowing to set
multiple variables in one shot, without updating the flash after
each set as now. It is added the possibility to pass
a config file with a list of pairs <variable, value> to be set,
separated by a TAB character.
Move the libfdt directory into the common lib/ directory to clean up the
top-level directory.
Now that the other architecture-specific lib directories have been
moved out of the top-level directory there's not much reason to have the
'_generic' suffix on the common lib directory.
Version 4.2.4 of gcc produces the following warnings without this change:
mkimage.c: In function ‘main’:
mkimage.c:204: warning: dereferencing type-punned pointer will break strict-aliasing rules
mkimage.c:222: warning: dereferencing type-punned pointer will break strict-aliasing rules
The restructuring of the mkimage command in commit 89a4d6b1 ("tools:
mkimage: split code into core, default and FIT image specific")
introduced a bug that caused mkimage to segfault when run without
"-n name" option. Initialize the imagename entry to prevent that.
Some people boot images with the entry point in the middle of the blob
(like Linux with the head code in discardable .init.text), and there is no
no real requirement that the entry point be right after the mkimage header
when doing XIP, so let people specify whatever they want. If they do need
an entry right after the header, then they still can do that with normal
-e behavior.
