Treat the first equal sign as a key/value separation too. This makes
the script files compatible with mkenvimage input file format. It
won't support variables with equal signs anymore, but this seems not
really like a loss.
The fw_env utility family has a default environment compiled in
which ties it quite strongly to the U-Boot source/config it has
been built with. Allow to display the U-Boot version it has been
built with using the -v/--version argument.
Reviewed-by: Lukasz Majewski <lukma@denx.de>
(cherry picked from commit 84d46e7e8948780d7ca20c24dfc7b653b900f728)
Move the imximage.h header file to a common location so we can make
use of it from U-Boot too.
commit 183923d3e412500bdc597d1745e2fb6f7f679ec7 enforces that the
environment must start at an erase block boundary.
For block devices the sample fw_env.config does not mandate a erase block size
for block devices. A missing setting defaults to the full env size.
Depending on the environment location the alignment check now errors out for
perfectly legal settings.
Fix this by defaulting to the standard blocksize of 0x200 for environments
stored in a block device.
That keeps the fw_env.config files for block devices working even with that
new check.
Commit fed329aebe3a ("tools: add mksunxiboot to tools-all target") added
mksunxiboot to the tools-all target, but used the CONFIG_SUNXI symbol
to enable its build. Now commit aec9a0f19f64 ("sunxi: Rename CONFIG_SUNXI
to CONFIG_ARCH_SUNXI"), merged before that, renamed that symbol, so that
the first patch basically gets ineffective.
Adjust the symbol name in tools/Makefile to make it build again.
Reviewed-by: Hans de Goede <hdegoede@redhat.com>
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
Adds -i option that allows specifying a ramdisk file to be added to the
FIT image when we are using the automatic FIT mode (no ITS file).
This makes adding Depthcharge support to LAVA much more convenient, as
no additional configuration files need to be kept around in the machine
that dispatches jobs to the boards.
Signed-off-by: Tomeu Vizoso <tomeu.vizoso@collabora.com>
Cc: Matt Hart <matthew.hart@linaro.org>
Cc: Neil Williams <codehelp@debian.org>
The README for buildman says that we can use any field in boards.cfg to
decide what to build. However, we were not saving the options field
correctly.
Check return value when open the plugin file.
Coverity report:
** CID 153926: Error handling issues (NEGATIVE_RETURNS)
/tools/imximage.c: 542 in copy_plugin_code()
ifd = open(plugin_file, O_RDONLY|O_BINARY);
>>> "ifd" is passed to a parameter that cannot be negative.
Signed-off-by: Peng Fan <peng.fan@nxp.com>
Reported-by: Coverity (CID: 153926)
The allocated memory should be freed. Fix it.
Reported-by: Coverity (CID: 150963)
Signed-off-by: Vagrant Cascadian <vagrant@debian.org>
Acked-by: Angelo Dureghello <angelo@sysam.it>
mksunxiboot is useful outside of u-boot, it is e.g. used by sunxi-tools.
Signed-off-by: Stefan Brüns <stefan.bruens@rwth-aachen.de>
CONFIG_SUNXI -> CONFIG_ARCH_SUNXI
and removed CONFIG_SUNIX from config_whitelist.txt
Cc: Ian Campbell <ijc@hellion.org.uk>
Cc: Hans de Goede <hdegoede@redhat.com>
Signed-off-by: Jagan Teki <jteki@openedev.com>
common/Kconfig
configs/dms-ba16_defconfig
Supporting shell-style wildcards for the --defconfigs option will be
useful to run the moveconfig tool against a specific platform. For
example, "uniphier*" in the file passed by --defconfigs option will
be expanded to defconfig files that start with "uniphier". This is
easier than listing out all defconfig files you are interested in.
Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
Add plugin support for imximage.
Define CONFIG_USE_IMXIMG_PLUGIN in defconfig to enable using plugin.
Cc: Eric Nelson <eric@nelint.com>
Cc: Ye Li <ye.li@nxp.com>
PBL flush command is restricted to CCSR memory space. So use WAIT
PBI command to provide enough time for data to get flush in
target memory.
Signed-off-by: Zhao Qiang <qiang.zhao@nxp.com>
[York Sun: rewrap commit message]
Reviewed-by: York Sun <york.sun@nxp.com>
Now we can use compiler wrapper such as ccache or distcc for buildman.
Signed-off-by: York Sun <york.sun@nxp.com>
CC: Simon Glass <sjg@chromium.org>
Fixed commit subject:
If we use the '/' operator then python 3.x will produce a float, and
refuse to multiply the string sequence in Conv_name_to_c by it with:
TypeError: can't multiply sequence by non-int of type 'float'
Use the '//' operator instead to enforce that we want integer rather
than floating point division.
Signed-off-by: Paul Burton <paul.burton@imgtec.com>
On python 3.x struct.unpack will complain if we provide it with a
string since it expects to operate on a bytes object. In order to
satisfy this requirement, encode the string to a bytes object when
running on python 3.x.
In python 3.x the iteritems() method has been removed from dictionaries,
and the items() method does effectively the same thing. On python 2.x
using items() is a little less efficient since it involves copying data,
but as speed isn't a concern in the affected code switch to using
items() anyway for simplicity.
In python 3.x StringIO is no longer a module, and the class can instead
be found in the io module. Adjust the code in the doctest input to
account for both.
but as speed isn't a concern in this code switch to using items() anyway
for simplicity.
In python 3.x module names used in import statements are case sensitive,
and the configparser module is named in all lower-case. Import it as such
in order to avoid errors when running with python 3.x.
Syntax for exception handling is a little more strict in python 3.x.
Convert all uses to a form accepted by both python 2.x & python 3.x.
In python 3.x, print must be used as a function call. Convert all print
statements to the function call style, importing from __future__ where
we print with no trailing newline or print to a file object.
In preparation for running on python 3.x, which will refuse to run
scripts which mix tabs & spaces for indentation, replace 2 tab
characters present in series.py with spaces.
We need to test both the normal (Python libfdt module) and fallback (fdtget)
implementations of the Fdt class. Add a way to select which implementation
to use.
There is no need to pass a node path separately. Instead we should use the
path for the node provided. Correct this.
This does not actually call fdtget correctly when requesting a particular
type. Fix it.
This is not used, so drop it.
When Ctrl-C is pressed, just exited quietly. There is no sense in displaying
a stack trace since buildman will always be in the same place: waiting for
threads to complete building all the jobs on the queue.
This serves no real purpose, since when we are not active, we exit. Drop it.
It is annoying that buildman does not respond cleanly to Ctrl-C or SIGINT,
particularly on machines with lots of CPUS. Unfortunately queue.join()
blocks the main thread and does not allow it to see the signal. Use a
separate thread instead,
If patman is installed on the machine (e.g. in the standard dist-packages
directory), it will find libraries from there in preference to our local
libraries. Adjust the order of the path to ensure that local libraries are
found first.
Make it clear when buildman actually starts building. This happens when it
has prepared the threads, working directory and output directories.
When buildman starts, it prepares its output directory by removing any old
build directories which will not be used this time. This can happen if a
previous build left directories around for commit hashes which are no-longer
part of the branch.
This can take quite a while, so print a message to indicate what is going
on.
On a machine with a lot of CPUs this prints a lot of useless lines of the
form:
Cloning repo for thread <n>
Adjust the output so that these all appear on one line, and disappear when
the cloning is complete.
Note: This cloning is actually unnecessary and very wasteful on disk space
(about 3.5GB each time). It would be better to create symlinks.
Output which does not include a newline will not be displayed unless
flushed. Add a flush to ensure that it becomes visible.
The default lockname is set to /var/lock. This limits the
usage of this application where OS uses different lockfile
location parameter.
For example, In case of android, the default lock
path location is /data.
Hence by providing the command line option to input lockfile
path will be useful to reuse the tool across multiple
operating system.
usage: ./fw_printenv -l <lockfile path>
Signed-off-by: Ravi Babu <ravibabu@ti.com>
Fix various misspellings of:
* deprecated
* partition
* preceding,preceded
* preparation
* its versus it's
* export
* existing
* scenario
* redundant
* remaining
* value
* architecture
Reviewed-by: Jagan Teki <jteki@openedev.com>
flash_write_buf: enforce offset to be start of environment
This allows to take advantage of the environment being block aligned.
This is not a new constraint. Writes always start at the begin of the
environment, since the header with CRC/length as there.
Every environment modification requires updating the header
Signed-off-by: Andreas Fenkart <andreas.fenkart@digitalstrom.com>
flash_write_buf already looks up size/offset/#sector from struct
envdev_s. It can look up mtd_type as well. Same applies to
flash_read_buf. Makes the interface simpler
the offset is not modified by linux ioctl call
see mtd_ioctl{drivers/mtd/mtdchar.c}
Makes the interface less ambiguous, since the caller can
now exclude a modification of blockstart
instead of adhoc computation of the environment end,
use a function with a proper name
This format can be flashed directly at address 0 of
the NAND FLASH, as it contains all necessary headers.
Signed-off-by: Albert ARIBAUD (3ADEV) <albert.aribaud@3adev.fr>
Provide easy helpers for reading integer, string and boolean values from
device-tree properties.
The style is to use single quotes for strings where possible. Adjust this
function.
Add a way to find the byte offset of a property within the device tree. This
is only supported with the normal libfdt implementation since fdtget does
not provide this information.
