path: root/tools
2015-05-15logos: Add Solidrun's logoFabio Estevam
Let Solidrun's logo appear on Cuboxi and Hummingboard by default. Signed-off-by: Rabeeh Khoury <rabeeh@solid-run.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-05-08Fix musl buildJörg Krause
This patch fixes cross-compiling U-Boot tools with the musl C library: * including <sys/types.h> is needed for ulong * defining _GNU_SOURCE is needed for loff_t Tested for target at91sam9261ek_dataflash_cs3. Signed-off-by: Jörg Krause <joerg.krause@embedded.rocks> Cc: Tom Rini <trini@konsulko.com>
2015-05-05fw_env.h: include autoconf.hMax Krummenacher
Without this, when CONFIG_ENV_VARS_UBOOT_CONFIG is active we get a compile time error when doing 'make env'. In file included from tools/env/fw_env.c:117:0: include/env_default.h:110:11: error: expected ‘}’ before ‘CONFIG_SYS_ARCH’ When building U-Boot this is included indirectly by the compiler switch -include /home/trdx/git.toradex.com/u-boot-2014.10-toradex/include/linux/kconfig.h Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2015-04-23patman: check git format.subjectprefix setting when generate patches prefixWu, Josh
For the local project, we may specified format.subjectprefix setting. Then the patch will be formated as [Project_prefix][PATCH]. But patman will not check this setting. It will remove the format.subjectprefix. So This patch will let patman check this setting and add it as a project prefix. Signed-off-by: Josh Wu <josh.wu@atmel.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2015-04-23buildman: Add gcc 4.9.0 with Microblaze toolchainMichal Simek
Also read gcc 4.9.0 at kernel.org which also have Microblaze toolchain. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org> Fixed unit test failure by updating the test: Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-18patman: cover letter shows like 00/xx if more than 10 patchesWu, Josh
Make cover letter shows like 0/x, 00/xx and 000/xxx etc. Signed-off-by: Josh Wu <josh.wu@atmel.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18buildman: Make -V (verbose_build) really be verboseTom Rini
The help text for -V says we will pass V=1 but all it really did was not pass in -s. Change the logic to pass make V=1 with given to buildman -V or -s to make otherwise. Cc: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18buildman: Keep more outputs with the --keep-outputs flagTom Rini
When told to keep outputs, be much more liberal in what files we keep. In addition to adding 'MLO', keep anything that matches u-boot-spl.* (so that we keep the map file as well) and anything we generate about 'u-boot itself. A large number of bootable formats now match this and thus it's easier to build many targets and then boot them afterwards using buildman. Cc: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18buildman: Allow comparison of build configurationSimon Glass
It is useful to be able to see CONFIG changes made by commits. Add this feature to buildman using the -K flag so that all CONFIG changes are reported. The CONFIG options exist in a number of files. Each is reported individually as well as a summary that covers all files. The output shows three parts: green for additions, red for removals and yellow for changes. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-18buildman: Store build config filesSimon Glass
Store all config file output so that we can compare changes if requested. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-18buildman: Adjust the 'aborted' heuristic for writing outputSimon Glass
At present buildman tries to detect an aborted build and doesn't record a result in that case. This is to make sure that an abort (e.g. with Ctrl-C) does not mark the build as done. Without this option, buildman would never retry the build unless -f/-F are provided. The effect is that aborting the build creates 'fake errors' on whatever builds buildman happens to be working on at the time. Unfortunately the current test is not reliable and this detection can trigger if a required toolchain tool is missing. In this case the toolchain problem is never reported. Adjust the logic to continue processing the build result, mark the build as done (and failed), but with a return code which indicates that it should be retried. The correct fix is to fully and correctly detect an aborted build, quit buildman immediately and not write any partial build results in this case. Unfortunately this is currently beyond my powers and is left as an exercise for the reader (and patches are welcome). Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-18buildman: Show 'make' command line when -V is usedSimon Glass
When a verbose build it selected, show the make command before the output of that command. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-10lpc32xx: add lpc32xx-spl.bin boot image targetAlbert ARIBAUD \(3ADEV\)
Signed-off-by: Albert ARIBAUD (3ADEV) <albert.aribaud@3adev.fr>
2015-04-03Merge branch 'master' of git://git.denx.de/u-boot-tegraTom Rini
Conflicts: board/armltd/vexpress64/vexpress64.c Signed-off-by: Tom Rini <trini@konsulko.com>
2015-03-30ARM: tegra: rename colibri_t20 board/configuration/device-treeMarcel Ziswiler
In accordance with our other modules supported by U-Boot and as agreed upon for Apalis/Colibri T30 get rid of the carrier board in the board/ configuration/device-tree naming. While at it also bring the prompt more in line with our other products. Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-03-28Patch to mkenvimage to handle text files with length that exceed env sizeBrian McFarland
The current head revision of mkenvimage (e72be8947e129f5ab274c0a9f235d2cc0014b2ea) will prevent you from creating an env image from a text file that is larger than the env length specified by the '-s' option. That doesn't make sense given that the tool now allows comments and blank lines. This patch removes that limitation and allows longer text files to be used. I don't have time / desire at the moment to figure out "patman" and could really care less if this is adopted up stream. Just figured I would share in case anybody else finds it useful enough to take time to do a proper patch. >From 39ff30190c2bf687861f4b4b33230f1944fb64f9 Mon Sep 17 00:00:00 2001 From: Brian McFarland <bmcfarland@rldrake.com> Date: Thu, 12 Mar 2015 11:37:19 -0400 Subject: [PATCH] In mkenvimage, removed the check that prevented using a source text file larger than the output environment image. Instead, the main parsing loop checks to see if the environment buffer is full, and quits if it is. After the main parse loop, a second loop swallows comments and whitespace until either the EOF is reached or more env vars are found, in which case an error will be thrown.
2015-03-05Merge branch 'buildman' of git://git.denx.de/u-boot-x86Tom Rini
2015-03-05buildman: Add a space before the list of boardsSimon Glass
Tweak the output slightly so we don't get things like: - board1 board2+ board3 board4 There should be a space before the '+'. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-03-05buildman: Correct toolchain download featureSimon Glass
Commit d908898 updated the ScanPath() function but not its documentation and not all its callers. This breaks the toolchain check after it is downloaded. Fix it. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Heiko Schocher <hs@denx.de>
2015-03-05kwbimage: align v1 binary header to 4BChris Packham
According to the Armada-XP documentation the binary header format requires the header length to be aligned to 4B. Signed-off-by: Chris Packham <judge.packham@gmail.com> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Prafulla Wadaskar <prafulla@marvell.com>
2015-02-17add example for file on VFAT filesystem usageWaldemar Brodkorb
For example on a raspberry pi the u-boot environment can be saved in a file on the first VFAT partition. This example illustrates how to use it with fw_printenv/fw_setenv. Signed-off-by: Waldemar Brodkorb <wbx@openadk.org>
2015-02-17Merge branch 'master' of http://git.denx.de/u-boot-sunxiTom Rini
2015-02-16tools: mksunxiboot: Fix problems on big endian systemsSiarhei Siamashka
Now my PS3 can be also used to build u-boot for sunxi devices. Signed-off-by: Siarhei Siamashka <siarhei.siamashka@gmail.com> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-02-16tools/imagetool: remove linker scriptAndreas Bießmann
Commit a93648d197df48fa46dd55f925ff70468bd81c71 introduced linker generated lists for imagetool which is the base for some host tools (mkimage, dumpimage, et al.). Unfortunately some host tool chains do not support the used type of linker scripts. Therefore this commit broke these host-tools for them, namely FreeBSD and Darwin (OS/X). This commit tries to fix this. In order to have a clean distinction between host and embedded code space we need to introduce our own linker generated list instead of re-using the available linker_lists.h provided functionality. So we copy the implementation used in linux kernel script/mod/file2alias.c which has the very same problem (cause it is a host tool). This code also comes with an abstraction for Mach-O binary format used in Darwin systems. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Cc: Guilherme Maciel Ferreira <guilherme.maciel.ferreira@gmail.com>
2015-02-15buildman: allow multiple toolchains in a single pathAlbert ARIBAUD
When buildman scans a toolchain path, it stops at the first toolchain found. However, a single path can contains several toolchains, each with its own prefix. This patch lets buildman scan all toolchains in the path. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Acked-by: Simon Glass <sjg@chromium.org>
2015-02-15patman: Read in the git-mailrc alias fileSimon Glass
We should read this file to obtain a set of aliases. This reduces the need to create them in the ~/.patman file. This feature did exist in some version of patman, and is mentioned in the help but it did not find its way upstream. Reported-by: Graeme Russ <gruss@tss-engineering.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-15buildman: Fix incorrect arguemnt in GetUpstream()Simon Glass
This causes an error when trying to build a local branch which has a local branch as its upstream. Signed-off-by: Simon Glass <sjg@chromium.org> Reported-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2015-02-10Merge branch 'master' of git://git.denx.de/u-boot-x86Tom Rini
2015-02-10Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2015-02-10imx: imximage: Add QuadSPI boot supportYe.Li
Add QuadSPI boot support to imximage tool. Note: The QuadSPI configuration parameters at offset 0x400 are not included in this patch. Need other tools to generate the parameters part. Signed-off-by: Ye.Li <B37916@freescale.com>
2015-02-07kwbimage: Make the Makefile pass in CONFIG_SYS_SPI_U_BOOT_OFFSTom Rini
We can't use config.h directly as some platforms include headers that aren't safe to use in normal Linux userland. Signed-off-by: Tom Rini <trini@ti.com>
2015-02-06tools: kwbimage: Support u-boot.img padding to CONFIG_SYS_SPI_U_BOOT_OFFSStefan Roese
This is used on the AXP boards, to pad u-boot.img to the desired offset in SPI flash (only this boot target supported right now). This offset is used by the SPL then to load u-boot.img into SDRAM and execute it there. Signed-off-by: Stefan Roese <sr@denx.de> Reviewed-by: Luka Perkov <luka.perkov@sartura.hr>
2015-02-05x86: Enhance the microcode tool to support header files as inputSimon Glass
Sometimes microcode is delivered as a header file. Allow the tool to support this as well as collecting multiple microcode blocks into a single update. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Bin Meng <bmeng.cn@gmail.com>
2015-01-31Merge branch 'patman' of git://git.denx.de/u-boot-x86Tom Rini
2015-01-30patman: Explain how to make doc/git-mailrc workSimon Glass
Add an explanation for how to set up git so that patman can find the alias file. Fix up the get_maintainers message too. Reported-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2015-01-30patman: Check commit_match before stripping leading whitespaceScott Wood
True commit lines start at column zero. Anything that is indented is part of the commit message instead. I noticed this by trying to run buildman with commit e3a4facdfc07179ebe017a07b8de6224a935a9f3 as master, which contained a reference to a Linux commit inside the commit message. ProcessLine saw that as a genuite commit line, and thus buildman tried to build it, and died with an exception because that SHA is not present in the U-Boot tree. Signed-off-by: Scott Wood <scottwood@freescale.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-01-30patman: Make dry-run output match real functionalityPeter Tyser
When run with the --dry-run argument patman prints out information showing what it would do. This information currently doesn't line up with what patman/git send-email really do. Some basic examples: - If an email address is addressed via "Series-cc" and "Patch-cc" patman shows that email address would be CC-ed two times. - If an email address is addressed via "Series-to" and "Patch-cc" patman shows that email address would be sent TO and CC-ed. - If an email address is addressed from a combination of tag aliases, get_maintainer.pl output, "Series-cc", "Patch-cc", etc patman shows that the email address would be CC-ed multiple times. Patman currently does try to send duplicate emails like the --dry-run output shows, but "git send-email" intelligently removes duplicate addresses so this patch shouldn't change the non-dry-run functionality. Change patman's output and email addressing to line up with the "git send-email" logic. This trims down patman's dry-run output and prevents confusion about what patman will do when emails are actually sent. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2015-01-30Merge branch 'master' of git://git.denx.de/u-boot-dmTom Rini
2015-01-29Use hash.c in mkimageRuchika Gupta
Signed-off-by: Ruchika Gupta <ruchika.gupta@freescale.com> CC: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2015-01-29rsa: Split the rsa-verify to separate the modular exponentiationRuchika Gupta
Public exponentiation which is required in rsa verify functionality is tightly integrated with verification code in rsa_verify.c. The patch splits the file into twp separating the modular exponentiation. 1. rsa-verify.c - The file parses device tree keys node to fill a keyprop structure. The keyprop structure can then be converted to implementation specific format. (struct rsa_pub_key for sw implementation) - The parsed device tree node is then passed to a generic rsa_mod_exp function. 2. rsa-mod-exp.c Move the software specific functions related to modular exponentiation from rsa-verify.c to this file. Signed-off-by: Ruchika Gupta <ruchika.gupta@freescale.com> CC: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2015-01-29tools: do not print error messages in verify_header() functionsGuilherme Maciel Ferreira
default_image.c and socfpgaimage.c are the only image modules that print error messages during header verification. The verify_header() is used to query if a given image file is processed by the image format. Thus, if the image format can't handle the file, it must simply return an error. Otherwise we pollute the screen with errors messages until we find the image format that handle a given image file. Signed-off-by: Guilherme Maciel Ferreira <guilherme.maciel.ferreira@gmail.com>
2015-01-29dumpimage: fit: extract FIT imagesGuilherme Maciel Ferreira
The dumpimage is able to extract components contained in a FIT image: $ ./dumpimage -T flat_dt -i CONTAINER.ITB -p INDEX FILE The CONTAINER.ITB is a regular FIT container file. The INDEX is the poisition of the sub-image to be retrieved, and FILE is the file (path+name) to save the extracted sub-image. For example, given the following kernel.its to build a kernel.itb: /dts-v1/; / { ... images { kernel@1 { description = "Kernel 2.6.32-34"; data = /incbin/("/boot/vmlinuz-2.6.32-34-generic"); type = "kernel"; arch = "ppc"; os = "linux"; compression = "gzip"; load = <00000000>; entry = <00000000>; hash@1 { algo = "md5"; }; }; ... }; ... }; The dumpimage can extract the 'kernel@1' node through the following command: $ ./dumpimage -T flat_dt -i kernel.itb -p 0 kernel Extracted: Image 0 (kernel@1) Description: Kernel 2.6.32-34 Created: Wed Oct 22 15:50:26 2014 Type: Kernel Image Compression: gzip compressed Data Size: 4040128 Bytes = 3945.44 kB = 3.85 MB Architecture: PowerPC OS: Linux Load Address: 0x00000000 Entry Point: 0x00000000 Hash algo: md5 Hash value: 22352ad39bdc03e2e50f9cc28c1c3652 Which results in the file 'kernel' being exactly the same as '/boot/vmlinuz-2.6.32-34-generic'. Signed-off-by: Guilherme Maciel Ferreira <guilherme.maciel.ferreira@gmail.com>
2015-01-29dumpimage: replace the term "datafile" by "subimage"Guilherme Maciel Ferreira
2015-01-29dumpimage: add 'T' option to explicitly set the image typeGuilherme Maciel Ferreira
Some image types, like "KeyStone GP", do not have magic numbers to distinguish them from other image types. Thus, the automatic image type discovery does not work correctly. This patch also fix some integer type mismatches. Signed-off-by: Guilherme Maciel Ferreira <guilherme.maciel.ferreira@gmail.com>
2015-01-29imagetool: replace image registration function by linker_lists featureGuilherme Maciel Ferreira
The registration was introduced in commit f86ed6a8d52c99bb2d17d3cac1647edca0c4399c This commit also removes all registration functions, and the member "next" from image_type_params struct Signed-off-by: Guilherme Maciel Ferreira <guilherme.maciel.ferreira@gmail.com>
2015-01-29imagetool: make the image_save_datafile() available to all image typesGuilherme Maciel Ferreira
Move the image_save_datafile() function from an U-Multi specific file (default_image.c) to a file common to all image types (image.c). And rename it to genimg_save_datafile(), to make clear it is useful for any image type. Signed-off-by: Guilherme Maciel Ferreira <guilherme.maciel.ferreira@gmail.com>
2015-01-29imagetool: move common code to imagetool moduleGuilherme Maciel Ferreira
The get_type() and verify_print_header() functions have the same code on both dumpimage.c and mkimage.c modules. Signed-off-by: Guilherme Maciel Ferreira <guilherme.maciel.ferreira@gmail.com>
2015-01-29arm: mx6: cm-fx6: display compulab logoNikita Kiryanov
Add compulab logo and display it on boot. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Cc: Stefano Babic <sbabic@denx.de> Cc: Igor Grinberg <grinberg@compulab.co.il> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2015-01-19mxsboot : Support of 224-bytes OOB area lengthAlexandre Coffignal
Add support for the NAND Flash chip with page size of 4096+224-bytes OOB area length For example Micron MT29F4G08 NAND flash device defines a OOB area which is 224 bytes long (oobsize). Signed-off-by: Alexandre Coffignal <acoffignal@geral.com>
2015-01-14buildman: Add an option to write the full build outputSimon Glass
Normally buildman runs with 'make -s' meaning that only errors and warnings appear in the log file. Add a -V option to run make in verbose mode, and with V=1, causing a full build log to be created. Signed-off-by: Simon Glass <sjg@chromium.org>
