After any node/property deletion the device tree can be packed to remove
spare space. Add a way to perform this operation.
Note that for fdt_fallback, fdtput automatically packs the device tree after
deletion, so no action is required here.
Add support for deleting a device tree property. With the fallback
implementation this uses fdtput. With libfdt it uses the API call and
updates the offsets afterwards.
Since we want to be able to change the in-memory device tree using libfdt,
use a bytearray instead of a string. This makes interfacing from Python
easier.
For binman we need to support deleting properties in the device tree. This
will change the offsets of nodes after the deletion. In preparation, add
code to keep track of when the offsets are invalid, and regenerate them.
This is not used anywhere in dtoc, so drop it.
If a source device tree is provide to the Fdt() constructors, compile it
automatically. This will be used in tests, where we want to build a
particular test .dts file and check that it works correctly in binman.
When tools want to display information of varying levels of importance, it
helps to provide the user with control over the verbosity of these messages.
Progress messages work best if they are displayed and then removed from the
display when no-longer relevant.
Add a new tout library (terminal out) to handle these tasks.
For tools which want to use input files and temporary output, it is useful
to have the handling of these dealt with in one place. Add a new library
which allows input files to be read, and output files to be written, all
based on a common directory structure.
Some functions have the same code in the subclasses. Move these into the
superclass to avoid duplication.
These functions are identical in both subclasses. Move them into the base
class.
Note: In fact there is a bug in one version, which was fixed by this patch:
https://patchwork.ozlabs.org/patch/651697/
These functions are currently in a separate fdt_util file. Since they are
only used from PropBase and subclasses, it makes sense for them to be in the
PropBase class.
Move these functions into fdt.py along with the list of types.
At present we have two separate implementations of the Fdt library, one which
uses fdtget/fdtput and one which uses libfdt (via swig).
Before adding more functionality it makes sense to create a base class for
these. This will allow common functions to be shared, and make the Fdt API
a little clearer.
Create a new fdt.py file with the base class, and adjust fdt_normal.py and
fdt_fallback.py to use it.
In preparation for creating an Fdt base class, rename this file to indicate
it is the normal Fdt implementation.
Rather than have dtc worry about which fdt library to use, move this into
a helper file. Add a function which creates a new Fdt object and scans it,
regardless of the implementation.
This should be in with the other system includes. Move it.
It is more useful to have this method raise an error when something goes
wrong. Make this the default and adjust the few callers that don't want to
use it this way.
The moveconfig tool is quite clever and generally produces results that
are suitable for sending as a patch without further work. The main required
step is to add the changes to a commit.
Add an option to do this automatically. This allows moveconfig to be used
from a script to convert multiple CONFIG options, once per commit.
At present it is not easy to use moveconfig from a script since it asks
for user input a few times. Add a -y option to skip this and assume that
'y' was entered.
Prior to this commit, the tool could not move options guarded by
CONFIG_SPL_BUILD ifdef conditionals because they do not show up in
include/autoconf.mk. This new option, if given, makes the tool
parse spl/include/autoconf.mk instead of include/autoconf.mk,
which is probably preferred behavior when moving options for SPL.
Currently, the tool gives up moving an option quietly if its entry
was not found in Kconfig.
If the option is not defined in the config header in the first
place, it is no problem (as the Kconfig entry may have been hidden
by reasonable "depends on").
However, if the option is defined in the config header, the missing
Kconfig entry is a sign of possible behavior change. It is highly
recommended to manually check if the option has been moved as
expected. In this case, let's add "suspicious" in the log and
change the log color (if --color option is given) to make it stand
out.
This was suggested by Tom in [1].
[1] http://lists.denx.de/pipermail/u-boot/2016-July/261988.html
Suggested-by: Tom Rini <trini@konsulko.com>
The sets feature is handier for adding unique elements.
Since commit cc008299f852 ("tools: moveconfig: do not rely on type
and default value given by users"), we do not have this error case.
Signed-off-by: Tim Harvey <tharvey@gateworks.com>
Most of them are my mistakes.
This is needed to move CONFIG options for the recently-added
xtfpga_defconfig.
The tarball of the pre-built toolchain can be downloaded from:
https://www.kernel.org/pub/tools/crosstool/files/bin/x86_64/4.9.0/
Commit f4db6c976cf ("arm: mvebu: Add runtime detection of UART (xmodem)
boot-mode") added a change to hdr->destaddr when dynamically patching an
image for UART boot mode. With this change, kwboot ceases to work on
Kirkwood.
Thus, let's change hdr->destaddr only when we are patching an image with
header version 1 (Orion and Kirkwood use header version 0).
Signed-off-by: Simon Baatz <gmbnomis@gmail.com>
Fixes: f4db6c976cf ("arm: mvebu: Add runtime detection of UART (xmodem) boot-mode")
Cc: Stefan Roese <sr@denx.de>
Cc: Luka Perkov <luka.perkov@sartura.hr>
Cc: Kevin Smith <kevin.smith@elecsyscorp.com>
addon 183923d3e
MMC/SATA have no erase blocks, only blocks. Hence the warning
about erase block alignment might be confusing in such environment.
Signed-off-by: Andreas Fenkart <andreas.fenkart@digitalstrom.com>
For double buffering to work, the target buffer must always be big
enough to hold all data. This can only be ensured if buffers are of
equal size, otherwise one must be smaller and we risk data loss
when copying from the bigger to the smaller buffer.
56086921 added support for unaligned environments access.
U-boot itself does not support this:
- env_nand.c fails when using an unaligned offset. It produces an
error in nand_erase_opts{drivers/mtd/nand/nand_util.c}
- in env_sf/env_flash the unused space at the end is preserved, but
not in the beginning. block alignment is assumed
- env_sata/env_mmc aligns offset/length to the block size of the
underlying device. data is silently redirected to the beginning of
a block
There is seems no use case for unaligned environment. If there is
some useful data at the beginning of the the block (e.g. end of u-boot)
that would be very unsafe. If the redundant environments are hosted by
the same erase block then that invalidates the idea of double buffering.
It might be that unaligned access was allowed in the past, and that
people with legacy u-boot are trapped. But at the time of 56086921
it wasn't supported and due to reasons above I guess it was never
introduced.
I prefer to remove that (unused) feature in favor of simplicity
Inform getopt that '-c' requires a parameter.
Fixes: a02221f29deb ("mkimage: Convert to use getopt()")
Signed-off-by: Karl Beldan <kbeldan@baylibre.com>
We mostly move config options from board header files to Kconfig,
but sometimes config defines come from CONFIG_SYS_EXTRA_OPTIONS.
Historically, CONFIG_SYS_EXTRA_OPTIONS originates in boards.cfg,
which was used as a central database of configuration prior to the
Kconfig conversion.
Now, we want to migrate to primary entries in Kconfig rather than
option list in CONFIG_SYS_EXTRA_OPTIONS, so it should be helpful to
have the tool to cleanup CONFIG_SYS_EXTRA_OPTIONS automatically.
I want to reuse this routine in the next commit.
Correct the clean-up of such defines that continue across multiple
lines, like follows:
#define CONFIG_FOO "this continues to the next line " \
"this line should be removed too" \
"this line should be removed as well"
Show code diff in color if --color option is given.
The header cleanup feature of this tool now removes empty ifdef's,
successive blank lines as well as moved option defines. So, we
want to see a little more context to check which lines were deleted.
It is true that we can see it by "git diff", but it would not work
in the --dry-run mode. So, here, this commit.
The tools/moveconfig.py has a feature to cleanup #define/#undef's
of moved config options, but I want this tool to do a better job.
For example, when we are moving CONFIG_FOO and its define is
surrounded by #ifdef ... #endif, like follows:
#ifdef CONFIG_BAR
# define CONFIG_FOO
#endif
The header cleanup will leave empty #ifdef ... #endif:
#ifdef CONFIG_BAR
#endif
Likewise, if a define line between two blank lines
<blank line>
#define CONFIG_FOO
<blank lines.
... is deleted, the result of the clean-up will be successive empty
lines, which is a coding-style violation.
It is tedious to remove left-over garbage lines manually, so I want
the tool to take care of this. The tool's job is still not perfect,
so we should check the output of the tool, but I hope our life will
be much easier with this patch.
The clean tree (make mrproper) and compilers are required when moving
config options, but not needed when we only cleanup headers.
The files in include/generated are generated during build and removed
by "make mrproper", so it has no point to touch them by this tool.
For those who just want to build a board, it is useful to see a quick hint
right at the start of the documentation. Add a few commands showing how to
download toolchains and build a board.
The current code for setting up the toolchain config always writes the new
paths to an item called 'toolchain'. This means that it will overwrite any
existing toolchain item with the same name. In practice, this means that:
buildman --fetch-arch all
will fetch all toolchains, but only the path of the final one will be added
to the config. This normally works out OK, since most toolchains are the
same version (e.g. gcc 4.9) and will be found on the same path. But it is
not correct and toolchains for archs which don't use the same version will
not function as expected.
Adjust the code to use a complete glob of the toolchain path.
It doesn't make sense to complain about missing toolchains when the
--fetch-arch option is being used. The user is presumably aware that there
is a toolchain problem and is actively correcting it by running with this
option.
Refactor the code to avoid printing this confusing message.
The function comment should say 'buildman'. Fix it.
Use colour to make it easier to see what is going on. Also print a message
before downloading a new toolchain. Mention --fetch-arch in the message that
is shown when there are no available toolchains, since this is the quickest
way to resolve the problem.
When there are no toolchains a warning is printed. But in some cases this is
confusing, such as when the user is fetching new toolchains.
Adjust the function to supress the warning in this case.
When buildman is run via a symlink, this test fails. Fix it to work the same
way as buildman itself.
If there is no ~/.buildman file, buildman currently complains and exists. To
make things a little more friendly, create an empty one automatically. This
will not allow things to be built, but --fetch-arch can be used to handle
that.
Tidy up some problems found by a recent review.
Format warnings (-Wformat) were shown in printf() calls after defining
DEBUG macro.
Update format string and explicitly cast variables to suppress all
warnings.
Signed-off-by: Marcin Niestroj <m.niestroj@grinn-global.com>
