path: root/tools
2011-11-03arm, davinci: add cam_enc_4xx supportHeiko Schocher
- DM368 SOC - booting with spl not with UBL from TI - before loading u-boot from NAND into RAM, test the RAM with the post memory test. If error is found, switch all LEDs on and halt system. - SPI Flash Dataflash Typ: M25PE80 - Ethernet DM9161BI - MMC - USB Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Sandeep Paulraj <s-paulraj@ti.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-10-23mkimage: adding support for Davinci AIS imageStefano Babic
Some Davinci processors supports the Application Image Script (AIS) boot process. The patch adds the generation of the AIS image inside the mkimage tool to make possible to generate a bootable U-boot without external tools (TI Davinci AIS Generator). Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Wolfgang Denk <wd@denx.de>
2011-10-22common: cosmetic: CONFIG_BOOTFILE checkpatch complianceJoe Hershberger
Remove MK_STR from places that consume CONFIG_BOOTFILE to force all definitions to be string literals. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-22common: cosmetic: CONFIG_ROOTPATH checkpatch complianceJoe Hershberger
Remove MK_STR from places that consume CONFIG_ROOTPATH to force all definitions to be string literals. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-22checkpatch whitespace cleanupsStephen Warren
This avoids the following checkpatch warning in later patches: ERROR: "(foo*)" should be "(foo *)" ERROR: space required before the open brace '{' ERROR: space prohibited before that close parenthesis ')' ERROR: spaces required around that '||' (ctx:WxV) WARNING: space prohibited between function name and open parenthesis '(' WARNING: line over 80 characters This fixes all the white-space warnings/errors in my subsequent patch, and within this current patch. A number of other checkpatch warnings and errors are still present in this patch itself, but are beyond simple whitespace fixes, so are not solved by this patch. v2: New patch Signed-off-by: Stephen Warren <swarren@nvidia.com> Tested-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2011-10-22fix compile warning for env toolsLuka Perkov
Patch fixes this issue: fw_env.c: In function ‘fw_setenv’: fw_env.c:492:5: warning: format ‘%u’ expects argument of type ‘unsigned int’, but argument 3 has type ‘size_t’ [-Wformat] fw_env.c: In function ‘flash_write_buf’: fw_env.c:806:6: warning: format ‘%u’ expects argument of type ‘unsigned int’, but argument 3 has type ‘size_t’ [-Wformat] Signed-off-by: Luka Perkov <lists@lukaperkov.net> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-06ublimage: NAND block size isn't set at build-timeLoïc Minier
mkimage's ublimage support can't depend of build-time board configs; instead, this should be set in ublimage.cfg. Since currently no configs in u-boot override the NAND block size, hardcode it as such in ublimage.h to fix a build failure with "make tools": gcc [...] -o ublimage.o ublimage.c -c In file included from ublimage.c:37:0: ublimage.h:31:20: fatal error: config.h: No such file or directory Cc: Heiko Schocher <hs@denx.de> Cc: patches@linaro.org Signed-off-by: Loïc Minier <loic.minier@linaro.org> Acked-by: Heiko Schocher <hs@denx.de>
2011-10-05mkimage: Add variable lenght header supportStefano Babic
Some images have not a header of fix lenght. The patch will be used for the generation of AIS images, because this header has a variable lenght. The patch adds also the parameter "-s" (skip) to not copy automatically the passed image file. Signed-off-by: Stefano Babic <sbabic@denx.de>
2011-10-05mkimage: ublimage must return if the header is not verifiedStefano Babic
Each image handler must return a not-zero velue if the header is not recognized to allow the main program to iterate to the next handler. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Heiko Schocher <hs@denx.de> Acked-by: Heiko Schocher <hs@denx.de>
2011-09-04mkimage: Fix 'Unknown OMAP image type - 5'Dirk Behme
Using mkimage with e.g. tools/mkimage -A arm -T firmware -O u-boot -d u-boot.bin foo.img gives a warning "Unknown OMAP image type - 5" while it seems that the image itself is created successfully. This does come from the patch "mkimage: Add OMAP boot image support". The method check_image_type in image_type_params is supposed to just return success or failure. However, for omap it also calls fprintf: static int omapimage_check_image_types(uint8_t type) { if (type == IH_TYPE_OMAPIMAGE) return EXIT_SUCCESS; else { fprintf(stderr, "Unknown OMAP image type - %x", type); return EXIT_FAILURE; } } All the other image checkers and no others have this, so the fix is to simply remove the fprintf. Signed-off-by: Dirk Behme <dirk.behme@googlemail.com> CC: John Rigby <john.rigby@linaro.org> CC: Aneesh V <aneesh@ti.com> CC: Sandeep Paulraj <s-paulraj@ti.com>
2011-08-03mkimage: Add OMAP boot image supportJohn Rigby
- Add mkimage support for OMAP boot image - Add support for OMAP boot image(MLO) generation in the new SPL framework Signed-off-by: John Rigby <john.rigby@linaro.org> Signed-off-by: Aneesh V <aneesh@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-08-03omap4: add clock supportAneesh V
Add support for: 1. DPLL locking 2. Initialization of clock domains and clock modules 3. Setting up the right voltage on voltage rails This work draws upon previous work done for x-loader by: Santosh Shilimkar <santosh.shilimkar@ti.com> Rajendra Nayak <rnayak@ti.com> Signed-off-by: Aneesh V <aneesh@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-07-31MIPS: INCA-IP: rename inca-swap-bytes host toolDaniel Schwierzeck
The INCA-IP SoC belongs to the Lantiq XWAY SoC product portfolio. For the upcoming support of other Lantiq SoC devices this tool should not solely depend on the INCA-IP board. Rename the tool to xway-swap-bytes and add an config option to enable compilation optionally. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Acked-by: Thomas Langer <thomas.langer@lantiq.com> Signed-off-by: Shinya Kuribayashi <skuribay@pobox.com>
2011-07-28mkimage: add UBL header support for booting davinci cpusHeiko Schocher
creating an u-boot.ubl file, which contains the UBL Header needed for booting from NAND with the RBL from TI. For more information read doc/README.ublimage. Signed-off-by: Heiko Schocher <hs@denx.de>
2011-07-27digsy_mtc: move board into vendor dir and add vendor logoAnatolij Gustschin
2011-07-26env: allow people to force envcrc buildingMike Frysinger
For people who want to manually extract the embedded environment so that it can be manually packed into the final u-boot image, add a config opt to force building of the envcrc tool. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-06-22tools: make it possible to build tools unconfiguredMike Frysinger
On Sunday, June 19, 2011 13:55:13 Ilya Yanok wrote: > On 18.06.2011 23:03, Mike Frysinger wrote: > >> - tools/Makefile put common/env_embedded.o and envcrc.o to object list > >> > >> conditionally. This fixes errors during dependency generation. > > > > pretty sure this breaks board builds. if the only thing this fixes is a > > I'm sorry but I can't see how this can break the builds. Could you > please be more specific? I've tried to build some boards, it actually > works... i might be thinking of a different env_embedded situation. a different problem with your patch to tools/Makefile: you copied the same logic multiple times which means more bitrot. why dont you do something like: > > harmless warning when generating dependency files, then i say ignore it. > > after all, this is how it has always worked in the past and no one really > > cared. > > Yep, they are harmless but they are not warnings but rather scary errors > actually. ;) I think it's better to fix them. i guess my threshold for being scared is a bit higher :p -mike
2011-06-22ARM: drop unsupported 'trab' boardWolfgang Denk
The 'trab' board configuration is broken, and there is nobody who is interested and willing to fix it. Drop it. This includes support for VFD displays which have always been used by this board only. Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-05-13Revert "Fix building tools alone with host compiler"Wolfgang Denk
This reverts commit bbc6353c740064c8e0741b772376a1a67a1c3f01. It breaks building on many systems: ... .../common/env_embedded.c:28:20: fatal error: config.h: No such file or directory compilation terminated. .../common/image.c:27:20: fatal error: common.h: No such file or directory compilation terminated. .../lib/crc32.c:12:20: fatal error: common.h: No such file or directory compilation terminated. .../lib/md5.c:28:22: fatal error: compiler.h: No such file or directory compilation terminated. .../lib/sha1.c:33:20: fatal error: common.h: No such file or directory compilation terminated.
2011-05-12kwbimage: Fix check variable of checksumNobuhiro Iwamatsu
calc_hdrcsum two times are checked. checksumi of exthdr is not checked. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> CC: Prafulla Wadaskar <prafulla@marvell.com>
2011-05-12Fix building tools alone with host compilerFrançois Revol
- don't include config.h when building with host cc, - HOSTCFLAGS was defined with the wrong name, so wasn't used, - make sure make finds sources outside of tools/. Signed-off-by: François Revol <revol@free.fr>
2011-04-30tools/env: document current cross-compilation issues and workaroundLuca Ceresoli
Signed-off-by: Luca Ceresoli <luca.ceresoli@comelit.it>
2011-04-21tools/env: fix redundant env flag comparisonJon Povey
This fixes two bugs with comparison of redundant environment flags on read. flag0 and flag1 in fw_env_open() were declared signed instead of unsigned char breaking BOOLEAN mode "== 0xFF" tests and in INCREMENTAL mode the wrong environment would be chosen where the flag values are 127 and 128 (either way round). With both flags over 128, both signs flipped and the logic worked by happy accident. Also there was a logic bug in the INCREMENTAL test (after signedness was fixed) in the case flag0=0, flag1=255, env 1 would be incorrectly chosen. Fix both of these. Signed-off-by: Jon Povey <jon.povey@racelogic.co.uk>
2011-04-12Add support for dataflash to U-boot environment settings tool.Remy Bohmer
* The sector size for SPI-dataflash (like AT45 flashes) are not always a power-of-2. So, the sector calculations are rewritten such that it works for either power-of-2 as any size sectors. * Make the flash sector size optional in case it is the same value as the environment size. Signed-off-by: Remy Bohmer <linux@bohmer.net>
2011-04-12mkimage: add "-V" option to print version informationWolfgang Denk
2011-04-12Drop config.h include in tools/imximage.hLoïc Minier
"make tools-all" should allow building tools such as mkimage and the new imximage without any config, but imximage.c currently fails to build with: imximage.h:27:20: error: config.h: No such file or directory config.h is not needed in imximage.h nor in imximage.c, and imximage.h is only included from imximage.c, so drop this include to fix the build. Signed-off-by: Loïc Minier <loic.minier@linaro.org>
2011-02-02imximage: Add MX53 boot image supportLiu Hui-R64343
This patch add the MX53 boot image support. This patch has been tested on Freescale MX53EVK board and MX51EVK board. Signed-off-by: Jason Liu <r64343@freescale.com>
2011-01-19Fix typo ("comand" instead of "command")Loïc Minier
2010-11-27Coding Style (white space) cleanupWolfgang Denk
2010-11-14Makefile: move include for config.mk upFrançois Revol
Reorder including config.mk before the HOSTCC check, so HOSTCC is actually defined when checking for it. Signed-off-by: François Revol <revol@free.fr> Cleaned up commit message Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-11-14tools/env: cleanup host build flagsDaniel Hobi
This patch makes tools/env/Makefile more similar to tools/imls: - define HOSTSRCS and HOSTCPPFLAGS, so that .depend generation works. - include U-Boot headers using -idirafter to prevent picking up u-boot/include/errno.h. - use HOSTCFLAGS_NOPED (fw_env.c does not conform to -pedantic). In order to cross-compile tools/env, override the HOSTCC variable as in this example: make tools env HOSTCC=bfin-uclinux-gcc Signed-off-by: Daniel Hobi <daniel.hobi@schmid-telecom.ch> Tested-by: Detlev Zundel <dzu@denx.de> Tested-by: Steve Sakoman <steve.sakoman@linaro.org>
2010-10-27make-asm-offsets: fix sed scriptWolfgang Denk
When copying the "sed" script to generate the asm-offsets.h file from the Linux Kbuild script into the make-asm-offsets file I missed the fact that the former runs in a "make" context and thus uses double "$$" to escape a single "$", while the latter is a shell script, where this must not be done. Unfortunately the problem did not show up during the initial tests on Power Architecture systems, but on ARM the generated asm-offsets.h was not correct. Signed-off-by: Wolfgang Denk <wd@denx.de> Tested-by: Heiko Schocher <hs@denx.de> Tested-by: Ben Gardiner <bengardiner@nanometrics.ca>
2010-10-26include/asm-offsets.h: automatically generate assembler constantsWolfgang Denk
A recurrent issue is that certain C level constructs like sizeof() or offsetof() cannot be used in assembler files, which is inconvenient when such constructs are used in the definition of macro names etc. To avoid duplication of such definitions (and thus another cause of problems), we adapt the Linux way to automatically generate the respective definitions from the respective C header files. In Linux, this is implemented in include/linux/kbuild.h, Kbuild, and arch/*/kernel/asm-offsets.c; we adapt the code from the Linux v2.6.36 kernel tree. We also copy the concept of the include/generated/ directory which can be used to hold other automatically generated files as well. We start with an architecture-independent lib/asm-offsets.c which generates include/generated/generic-asm-offsets.h (included by include/asm-offsets.h, which is what will be referred to in the actual source code). Later this may be extended by architecture-specific arch/*/lib/asm-offsets.c files that will generate a include/generated/asm-offsets.h. Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Kumar Gala <galak@kernel.crashing.org>
2010-10-18autoconfig.mk: avoid apostophes around hex valuesWolfgang Denk
When generating include/autoconfig.mk, hex numbers would be quoted. This caused some false positives during automatic testing of the builds, and is known to cause some real issues for some Blackfin configurations. Don't use apostophes for decimal and hex numbers (nor for octal numbers). Signed-off-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-12tools/imls: fix comment in MakefileDaniel Hobi
Commit d984fed0 (makefiles: fixes for building build tools) changed the variable name FIT_CFLAGS to HOSTCFLAGS_NOPED but forgot to update to corresponding comment. Signed-off-by: Daniel Hobi <daniel.hobi@schmid-telecom.ch> Cc: Scott Wood <scottwood@freescale.com> Cc: Wolfgang Denk <wd@denx.de>
2010-09-28Merge branch 'next' of /home/wd/git/u-boot/nextWolfgang Denk
Conflicts: include/ppc4xx.h Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-09-21logos: add Freescale logoTimur Tabi
Add the Freescale logo and update the Makefile to build it when building a Freescale board. Signed-off-by: Timur Tabi <timur@freescale.com>
2010-09-21setlocalversion: add some more fallbacks for git describeMike Frysinger
If working out of a custom git tree that lacks annotated tags, the 'git describe' operation spews "fatal: cannot describe" errors all over the place. So add some fallback code in case the best naming was unable to locate something useful. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-09-19tools: enable img2srec for "tools-all" targetMike Frysinger
2010-09-19tools/env: use host build flagsMike Frysinger
Convert the tools/env/Makefile to use the same host tool syntax as the other tool subdirs. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-09-19tools: update .gitignoreMike Frysinger
2010-09-18tools/env: fail on invalid optionsDaniel Hobi
2010-09-18tools/env: allow option "-n" for fw_printenvDaniel Hobi
In commit bd7b26f8 (Tools: set multiple variable with fw_setenv utility), the option parsing was changed to getopt_long(3), but option "-n" of fw_printenv was not included. This leads to an error message "invalid option -- 'n'" on stderr, although the output on stdout is correct. Signed-off-by: Daniel Hobi <daniel.hobi@schmid-telecom.ch>
2010-08-10ARM: Add support for jadecpu board based on MB86R01 SoCMatthias Weisser
This patch adds support for the jadecpu board using the MB86R01 'Jade' SoC from Fujitsu. Signed-off-by: Matthias Weisser <weisserm@arcor.de>
2010-08-09tools/env/fw_printenv: Make redundant env work on locked flashes alsoDetlev Zundel
The invalidation of the old environment instance did not work for flashes supporting hardware locking. Now we unlock/lock around this update also. Signed-off-by: Detlev Zundel <dzu@denx.de>
2010-07-25Blackfin: jtagconsole: disable output processingMike Frysinger
Avoid extra carriage returns in the output by disabling output processing. Otherwise, whenever the remote sends a \r\n, we end up with \r\r\n. Reported-by: Vivi Li <vivi.li@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-07-24cmd_usage(): simplify return code handlingWolfgang Denk
Lots of code use this construct: cmd_usage(cmdtp); return 1; Change cmd_usage() let it return 1 - then we can replace all these ocurrances by return cmd_usage(cmdtp); This fixes a few places with incorrect return code handling, too. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-06-29Tools: set multiple variable with fw_setenv utilityStefano Babic
Add a sort of batch mode to fw_setenv, allowing to set multiple variables in one shot, without updating the flash after each set as now. It is added the possibility to pass a config file with a list of pairs <variable, value> to be set, separated by a TAB character. Signed-off-by: Stefano Babic <sbabic@denx.de>
2010-04-30mkimage: correct spelling error in imximageStefano Babic
