path: root/tools
2014-02-19kernel-doc: move kernel-doc tools to scripts/Masahiro Yamada
tools/kernel-doc/docproc.c and tools/kernel-doc/kernel-doc are files imported from Linux Kernel. They originally resided under scripts/ directory in Linux Kernel. This commit moves them to the original location. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-02-19tools/env: cross-compile fw_printenv without setting HOSTCCMasahiro Yamada
fw_printenv is a program which mostly runs on the target Linux. Before switching to Kbuild, we needed to set HOSTCC at the command line like this: make HOSTCC=<your CC cross-compiler> env Going forward we can cross compile it by specifying CROSS_COMPILE: make CROSS_COMPILE=<your cross-compiler prefix> env This looks more natural. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Tested-by: Gerhard Sittig <gsi@denx.de>
2014-02-19Makefile: refactor tools-all targetsMasahiro Yamada
- Move "easylogo", "gdb" tagets to tools/Makefile - Delete "gdbtools" target (same as "gdb") Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19kbuild: use Linux Kernel build scriptsMasahiro Yamada
Now we are ready to switch over to real Kbuild. This commit disables temporary scripts: scripts/{Makefile.build.tmp, Makefile.host.tmp} and enables real Kbuild scripts: scripts/{Makefile.build,Makefile.host,Makefile.lib}. This switch is triggered by the line in scripts/Kbuild.include -build := -f $(if $(KBUILD_SRC),$(srctree)/)scripts/Makefile.build.tmp obj +build := -f $(if $(KBUILD_SRC),$(srctree)/)scripts/Makefile.build obj We need to adjust some build scripts for U-Boot. But smaller amount of modification is preferable. Additionally, we need to fix compiler flags which are locally added or removed. In Kbuild, it is not allowed to change CFLAGS locally. Instead, ccflags-y, asflags-y, cppflags-y, CFLAGS_$(basetarget).o, CFLAGS_REMOVE_$(basetarget).o are prepared for that purpose. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Tested-by: Gerhard Sittig <gsi@denx.de>
2014-02-19kbuild: change out-of-tree buildMasahiro Yamada
This commit changes the working directory where the build process occurs. Before this commit, build process occurred under the source tree for both in-tree and out-of-tree build. That's why we needed to add $(obj) prefix to all generated files in makefiles like follows: $(obj)u-boot.bin: $(obj)u-boot Here, $(obj) is empty for in-tree build, whereas it points to the output directory for out-of-tree build. And our old build system changes the current working directory with "make -C <sub-dir>" syntax when descending into the sub-directories. On the other hand, Kbuild uses a different idea to handle out-of-tree build and directory descending. The build process of Kbuild always occurs under the output tree. When "O=dir/to/store/output/files" is given, the build system changes the current working directory to that directory and restarts the make. Kbuild uses "make -f $(srctree)/scripts/Makefile.build obj=<sub-dir>" syntax for descending into sub-directories. (We can write it like "make $(obj)=<sub-dir>" with a shorthand.) This means the current working directory is always the top of the output directory. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Tested-by: Gerhard Sittig <gsi@denx.de>
2014-02-19Makefile: refactor include path settingsMasahiro Yamada
This commit merges commonly-used header include paths to UBOOTINCLUDE and NOSTDINC_FLAGS variables, which are placed at the top Makefile. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19Makefile: move BFD_ROOT_DIR to tools/gdb/MakefileMasahiro Yamada
BFD_ROOT_DIR is used only in tools/gdb/Makefile Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19tools: convert makefiles to kbuild styleMasahiro Yamada
Before this commit, makefiles under tools/ directory were implemented with their own way. This commit refactors them by using "hostprogs-y" variable. Several C sources have been added to wrap other C sources to simplify Makefile. For example, tools/crc32.c includes lib/crc32.c Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19tools: correct proftool build ruleIan Campbell
The incorrect substitution made it rebuild every time. Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Cc: Tom Rini <trini@ti.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-02-13relocate-rela: replace a magic number with sizeof(Elf64_Rela)Masahiro Yamada
Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Scott Wood <scottwood@freescale.com> Cc: David Feng <fenghua@phytium.com.cn> Acked-by: Scott Wood <scottwood@freescale.com>
2014-01-24tools: move kermit files to tools/kermit directoryMasahiro Yamada
The script files, define2mk.sed and make-asm-offsets are used to create autoconf.mk and asm-offsets.h while build. Whereas README, dot.kermrc, flash_param, send_cmd, send_image are files useful for kermit. We should not put files which have the totally different purpose into the same directory. This commit creates a new directory, tools/kermit, and move kermit files into it. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Wolfgang Denk <wd@denx.de>
2014-01-24cosmetic: tools/scripts/README: insert only one space between wordsMasahiro Yamada
2014-01-20.gitignore: ignore u-boot.elf and tools/relocate-relaMasahiro Yamada
2014-01-10Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
Bringing in the MMC tree means that CONFIG_BOUNCE_BUFFER needed to be added to include/configs/exynos5-dt.h now. Conflicts: include/configs/exynos5250-dt.h Signed-off-by: Tom Rini <trini@ti.com>
2014-01-09arm64: Add tool to statically apply RELA relocationsScott Wood
ARM64 uses the newer RELA-style relocations rather than the older REL. RELA relocations have an addend in the relocation struct, rather than expecting the loader to read a value from the location to be updated. While this is beneficial for ordinary program loading, it's problematic for U-Boot because the location to be updated starts out with zero, rather than a pre-relocation value. Since we need to be able to run C code before relocation, we need a tool to apply the relocations at build time. In theory this tool is applicable to other newer architectures (mainly 64-bit), but currently the only relocations it supports are for arm64, and it assumes a 64-bit little-endian target. If the latter limitation is ever to be changed, we'll need a way to tell the tool what format the image is in. Eventually this may be replaced by a tool that uses libelf or similar and operates directly on the ELF file. I've written some code for such an approach but libelf does not make it easy to poke addresses by memory address (rather than by section), and I was hesitant to write code to manually parse the program headers and do the update outside of libelf (or to iterate over sections) -- especially since it wouldn't get test coverage on things like binaries with multiple PT_LOAD segments. This should be good enough for now to let the manual relocation stuff be removed from the arm64 patches. Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: David Feng <fenghua@phytium.com.cn>
2014-01-06Merge branch 'u-boot-samsung/master' into 'u-boot-arm/master'Albert ARIBAUD
2014-01-06Merge branch 'u-boot-imx/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: include/micrel.h The conflict above was trivial, caused by four lines being added in both branches with different whitepace.
2013-12-30SPL: EXYNOS: Prepare for variable size SPL supportRajeshwari Birje
When variable size SPL is used, the BL1 expects the SPL to be encapsulated differently: instead of putting the checksum at a fixed offset in the SPL blob, prepend the blob with a header including the size and the checksum. The enhancements include - adding a command line option, '--vs' to indicate the need for the variable size encapsulation - padding the fixed size encapsulated blob with 0xff instead of random memory contents - do not silently truncate the input file, report error instead - no need to explicitly closing files/freeing memory, this all happens on exit; removing cleanups it makes code clearer - profuse commenting - modify Makefile to allow enabling the new feature per board Signed-off-by: Vadim Bendebury <vbendeb@chromium.org> Signed-off-by: Rajeshwari S Shinde <rajeshwari.s@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-12-30Exynos5420: Add base patch for SMDK5420Rajeshwari Birje
Adding the base patch for Exynos based SMDK5420. This shall enable compilation and basic boot support for SMDK5420. Signed-off-by: Rajeshwari S Shinde <rajeshwari.s@samsung.com> Signed-off-by: Akshay Saraswat <akshay.s@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-12-17ARM: mxs: tools: Fix errno handling in strtoul() invocationMarek Vasut
According to NOTE in strtoul(3), the errno must be zeroed before strtoul() is called. Zero the errno. The NOTE reads as such: Since strtoul() can legitimately return 0 or ULONG_MAX (ULLONG_MAX for strtoull()) on both success and failure, the calling program should set errno to 0 before the call, and then determine if an error occurred by checking whether errno has a nonzero value after the call. This issue was detected on Fedora 19 with glibc 2.17 . Signed-off-by: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Tom Rini <trini@ti.com>
2013-12-16Makefile, .gitignore: Cleanup non-existing binariesMasahiro Yamada
2013-12-13Makefile: Move some scripts imported from LinuxMasahiro Yamada
We have some scripts imported from Linux Kernel: setlocalversion, checkstack.pl, checkpatch.pl, cleanpatch They are located under tools/ directory in U-Boot now. But they were originally located under scripts/ directory in Linux Kernel. This commit moves them to the original location. It is true that binutils-version.sh and dtc-version.sh do not originate in Linux Kernel, but they should be moved by analogy to gcc-version.sh. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-12-13Add dumpimage, a tool to extract data from U-Boot imagesGuilherme Maciel Ferreira
Given a multi-file image created through the mkimage's -d option: $ mkimage -A x86 -O linux -T multi -n x86 -d vmlinuz:initrd.img:System.map \ multi.img Image Name: x86 Created: Thu Jul 25 10:29:13 2013 Image Type: Intel x86 Linux Multi-File Image (gzip compressed) Data Size: 13722956 Bytes = 13401.32 kB = 13.09 MB Load Address: 00000000 Entry Point: 00000000 Contents: Image 0: 4040128 Bytes = 3945.44 kB = 3.85 MB Image 1: 7991719 Bytes = 7804.41 kB = 7.62 MB Image 2: 1691092 Bytes = 1651.46 kB = 1.61 MB It is possible to perform the innverse operation -- extracting any file from the image -- by using the dumpimage's -i option: $ dumpimage -i multi.img -p 2 System.map Although it's feasible to retrieve "data files" from image through scripting, the requirement to embed tools such 'dd', 'awk' and 'sed' for this sole purpose is cumbersome and unreliable -- once you must keep track of file sizes inside the image. Furthermore, extracting data files using "dumpimage" tool is faster than through scripting. Signed-off-by: Guilherme Maciel Ferreira <guilherme.maciel.ferreira@gmail.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2013-12-13tools: moved code common to all image tools to a separated module.Guilherme Maciel Ferreira
In order to avoid duplicating code and keep only one point of modification, the functions, structs and defines useful for "dumpimage" were moved from "mkimage" to a common module called "imagetool". This modification also weakens the coupling between image types (FIT, IMX, MXS, and so on) and image tools (mkimage and dumpimage). Any tool may initialize the "imagetool" through register_image_tool() function, while the image types register themselves within an image tool using the register_image_type() function: +---------------+ +------| fit_image | +--------------+ +-----------+ | +---------------+ | mkimage |--------> | | <-----+ +--------------+ | | +---------------+ | imagetool | <------------| imximage | +--------------+ | | +---------------+ | dumpimage |--------> | | <-----+ +--------------+ +-----------+ | +---------------+ +------| default_image | +---------------+ register_image_tool() register_image_type() Also, the struct "mkimage_params" was renamed to "image_tool_params" to make clear its general purpose. Signed-off-by: Guilherme Maciel Ferreira <guilherme.maciel.ferreira@gmail.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2013-12-13mkimage: added 'static' specifier to match function's prototype.Guilherme Maciel Ferreira
This function should be declared static. Signed-off-by: Guilherme Maciel Ferreira <guilherme.maciel.ferreira@gmail.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2013-11-25Merge branch 'buildpatman' of http://git.denx.de/u-boot-x86Tom Rini
2013-11-25tools: updater: Remove remainders of dead boardMasahiro Yamada
tools/updater needs board/MAI/AmigaOneG3SE board for compiling. But AmigaOneG3SE board was already deleted by Commit 953b7e6. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-11-25tools: imls: Remove a broken and unused tool.Masahiro Yamada
It looks like tools/imls/Makefile is invoked from nowhere. And also it is broken. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-11-21buildman: make board selector argument a regexStephen Warren
A common use-case is to build all boards for a particular SoC. This can be achieved by: ./tools/buildman/buildman -b mainline_dev tegra20 However, when the SoC is a member of a family of SoCs, and each SoC has a different name, it would be even more useful to build all boards for every SoC in that family. This currently isn't possible since buildman's board selection command-line arguments are compared to board definitions using pure string equality. To enable this, compare using a regex match instead. This matches MAKEALL's handling of command-line arguments. This enables: (all Tegra) ./tools/buildman/buildman -b mainline_dev tegra (all Tegra) ./tools/buildman/buildman -b mainline_dev '^tegra.*$' (all Tegra20, Tegra30 boards, but not Tegra114) ./tools/buildman/buildman -b mainline_dev 'tegra[23]' Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org>
2013-11-21buildman: fix READMEAndreas Bießmann
This is a trivial fix for c'n'p error. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Acked-by: Simon Glass <sjg@chromium.org>
2013-11-21patman: add Commit-notes tag and sectionAlbert ARIBAUD
Sometimes a commit should have notes enclosed with it rather than withing the cover letter -- possibly even because there is no cover letter. Add a 'Commit-notes' tag, similar to the 'Series-notes' one; lines between this tag and the next END line are inserted in the patch right after the '---' commit delimiter. Change-Id: I01e99ae125607dc6dec08f3be8a5a0b37f0a483d Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Signed-off-by: Simon Glass <sjg@chromium.org> (Updated README)
2013-11-17tools: Makefile: delete redundant linesMasahiro Yamada
HOSTOS is defined and exported at the top Makefile. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-11-08Makefile: do not create a symbolic link to arch/${ARCH}/include/asmMasahiro Yamada
In-tree build: - Do not create a symbolic link from include/asm to arch/${ARCH}/include/asm - Add ${SRCTREE}/arch/arm/include into the header search path Out-of-tree build: - Do not create a directory ${OBJTREE}/include2 - Do not create a symbolic link from ${OBJTREE}/include2/asm to ${SRCTREE}/arch/${ARCH}/include/asm - Add ${SRCTREE}/arch/arm/include into the header search path Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-10-15buildman: Use env to pick the python from $PATHJagannadha Sutradharudu Teki
python used in buildman doesn't need to be placed in /usr/bin/python, So use env to ensure that the interpreter will pick the python from environment. Usefull with several versions of python's installed on system. Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com> Acked-by: Simon Glass <sjg@chromium.org>
2013-10-14Merge branch 'buildman' of git://git.denx.de/u-boot-x86Tom Rini
2013-10-14Coding Style cleanup: drop some excessive empty linesWolfgang Denk
2013-10-14Coding Style cleanup: replace leading SPACEs by TABsWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> [trini: Drop changes for PEP 4 following python tools] Signed-off-by: Tom Rini <trini@ti.com>
2013-10-10buildman: don't fail --list-toolchains when toolchains failStephen Warren
When a toolchain invocation fails, an exception is thrown but not caught which then aborts the entire toolchain detection process. To solve this, request that exceptions not be thrown, since the toolchain init code already error-checks the command result. This solves e.g.: - found '/usr/bin/winegcc' Traceback (most recent call last): ... Exception: Error running '/usr/bin/winegcc --version' Change-Id: I579c72ab3b021e38b14132893c3375ea257c74f0 Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org> (formatted to 80cols)
2013-10-02Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2013-10-01buildman: Allow make flags to be specified for each boardSimon Glass
There are a few make options such as BUILD_TAG which can be provided when building U-Boot. Provide a way for buildman to pass these flags to make also. The flags should be in a [make-flags] section and arranged by target name (the 'target' column in boards.cfg. See the README for more details. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-10-01buildman: Adjust tests for new boards.cfg formatSimon Glass
Commit 27af930e9a5c91365ca639ada580b338eabe4989 changed the boards.cfg format but missed to change the parsing in buildman. A follow-on commit 03c1bb242548e4e9d267d784861ccd69a1887aa0 fixed this but missed fixing the tests. This patch updates the tests to fit the new Board constructor. ./tools/buildman/buildman -t <unittest.result.TestResult run=1 errors=0 failures=0> Signed-off-by: Simon Glass <sjg@chromium.org>
2013-09-27tools/imximage.c: Fix compiling warningYork Sun
Convert set_hdr_func(struct imx_header *imxhdr) to set_hdr_func(void) to get rid of the warning warning: ‘imxhdr’ is used uninitialized in this function Signed-off-by: York Sun <yorksun@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de>
2013-09-20buildman: fix boards.cfg parsingAndreas Bießmann
Commit 27af930e9a5c91365ca639ada580b338eabe4989 changed the boards.cfg format but missed to change the parsing in buildman. This patch changes c'tor of Board class to the new sequence, but omits maintainer field. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-09-20FIT: delete unnecessary castsMasahiro Yamada
Becuase fdt_check_header function takes (const void *) type argument, the argument should be passed to it without being casted to (char *). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-09-20boards.cfg: show info about boards.cfg instead of MAINTAINERSRoger Meier
Signed-off-by: Roger Meier <roger@bufferoverflow.ch>
2013-09-13Merge branch 'master' of git://git.denx.de/u-boot-armStefano Babic
Conflicts: MAINTAINERS boards.cfg Signed-off-by: Stefano Babic <sbabic@denx.de>
2013-09-12Merge and reformat boards.cfg and MAINTAINERSAlbert ARIBAUD
Put all informations about targets, including state (active or orphan) and maintainers, in boards.cfg; remove MAINTAINERS; adjust the build system accordingly. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2013-09-12Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2013-09-11Merge branch 'u-boot-samsung/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: tools/Makefile
