Now we can use compiler wrapper such as ccache or distcc for buildman.
Signed-off-by: York Sun <york.sun@nxp.com>
CC: Simon Glass <sjg@chromium.org>
Fixed commit subject:
If we use the '/' operator then python 3.x will produce a float, and
refuse to multiply the string sequence in Conv_name_to_c by it with:
TypeError: can't multiply sequence by non-int of type 'float'
Use the '//' operator instead to enforce that we want integer rather
than floating point division.
Signed-off-by: Paul Burton <paul.burton@imgtec.com>
On python 3.x struct.unpack will complain if we provide it with a
string since it expects to operate on a bytes object. In order to
satisfy this requirement, encode the string to a bytes object when
running on python 3.x.
In python 3.x the iteritems() method has been removed from dictionaries,
and the items() method does effectively the same thing. On python 2.x
using items() is a little less efficient since it involves copying data,
but as speed isn't a concern in the affected code switch to using
items() anyway for simplicity.
In python 3.x StringIO is no longer a module, and the class can instead
be found in the io module. Adjust the code in the doctest input to
account for both.
but as speed isn't a concern in this code switch to using items() anyway
for simplicity.
In python 3.x module names used in import statements are case sensitive,
and the configparser module is named in all lower-case. Import it as such
in order to avoid errors when running with python 3.x.
Syntax for exception handling is a little more strict in python 3.x.
Convert all uses to a form accepted by both python 2.x & python 3.x.
In python 3.x, print must be used as a function call. Convert all print
statements to the function call style, importing from __future__ where
we print with no trailing newline or print to a file object.
In preparation for running on python 3.x, which will refuse to run
scripts which mix tabs & spaces for indentation, replace 2 tab
characters present in series.py with spaces.
We need to test both the normal (Python libfdt module) and fallback (fdtget)
implementations of the Fdt class. Add a way to select which implementation
to use.
There is no need to pass a node path separately. Instead we should use the
path for the node provided. Correct this.
This does not actually call fdtget correctly when requesting a particular
type. Fix it.
This is not used, so drop it.
When Ctrl-C is pressed, just exited quietly. There is no sense in displaying
a stack trace since buildman will always be in the same place: waiting for
threads to complete building all the jobs on the queue.
This serves no real purpose, since when we are not active, we exit. Drop it.
It is annoying that buildman does not respond cleanly to Ctrl-C or SIGINT,
particularly on machines with lots of CPUS. Unfortunately queue.join()
blocks the main thread and does not allow it to see the signal. Use a
separate thread instead,
If patman is installed on the machine (e.g. in the standard dist-packages
directory), it will find libraries from there in preference to our local
libraries. Adjust the order of the path to ensure that local libraries are
found first.
Make it clear when buildman actually starts building. This happens when it
has prepared the threads, working directory and output directories.
When buildman starts, it prepares its output directory by removing any old
build directories which will not be used this time. This can happen if a
previous build left directories around for commit hashes which are no-longer
part of the branch.
This can take quite a while, so print a message to indicate what is going
on.
On a machine with a lot of CPUs this prints a lot of useless lines of the
form:
Cloning repo for thread <n>
Adjust the output so that these all appear on one line, and disappear when
the cloning is complete.
Note: This cloning is actually unnecessary and very wasteful on disk space
(about 3.5GB each time). It would be better to create symlinks.
Output which does not include a newline will not be displayed unless
flushed. Add a flush to ensure that it becomes visible.
The default lockname is set to /var/lock. This limits the
usage of this application where OS uses different lockfile
location parameter.
For example, In case of android, the default lock
path location is /data.
Hence by providing the command line option to input lockfile
path will be useful to reuse the tool across multiple
operating system.
usage: ./fw_printenv -l <lockfile path>
Signed-off-by: Ravi Babu <ravibabu@ti.com>
Fix various misspellings of:
* deprecated
* partition
* preceding,preceded
* preparation
* its versus it's
* export
* existing
* scenario
* redundant
* remaining
* value
* architecture
Reviewed-by: Jagan Teki <jteki@openedev.com>
flash_write_buf: enforce offset to be start of environment
This allows to take advantage of the environment being block aligned.
This is not a new constraint. Writes always start at the begin of the
environment, since the header with CRC/length as there.
Every environment modification requires updating the header
Signed-off-by: Andreas Fenkart <andreas.fenkart@digitalstrom.com>
flash_write_buf already looks up size/offset/#sector from struct
envdev_s. It can look up mtd_type as well. Same applies to
flash_read_buf. Makes the interface simpler
the offset is not modified by linux ioctl call
see mtd_ioctl{drivers/mtd/mtdchar.c}
Makes the interface less ambiguous, since the caller can
now exclude a modification of blockstart
instead of adhoc computation of the environment end,
use a function with a proper name
This format can be flashed directly at address 0 of
the NAND FLASH, as it contains all necessary headers.
Signed-off-by: Albert ARIBAUD (3ADEV) <albert.aribaud@3adev.fr>
Provide easy helpers for reading integer, string and boolean values from
device-tree properties.
The style is to use single quotes for strings where possible. Adjust this
function.
Add a way to find the byte offset of a property within the device tree. This
is only supported with the normal libfdt implementation since fdtget does
not provide this information.
After any node/property deletion the device tree can be packed to remove
spare space. Add a way to perform this operation.
Note that for fdt_fallback, fdtput automatically packs the device tree after
deletion, so no action is required here.
Add support for deleting a device tree property. With the fallback
implementation this uses fdtput. With libfdt it uses the API call and
updates the offsets afterwards.
Since we want to be able to change the in-memory device tree using libfdt,
use a bytearray instead of a string. This makes interfacing from Python
easier.
For binman we need to support deleting properties in the device tree. This
will change the offsets of nodes after the deletion. In preparation, add
code to keep track of when the offsets are invalid, and regenerate them.
This is not used anywhere in dtoc, so drop it.
If a source device tree is provide to the Fdt() constructors, compile it
automatically. This will be used in tests, where we want to build a
particular test .dts file and check that it works correctly in binman.
When tools want to display information of varying levels of importance, it
helps to provide the user with control over the verbosity of these messages.
Progress messages work best if they are displayed and then removed from the
display when no-longer relevant.
Add a new tout library (terminal out) to handle these tasks.
For tools which want to use input files and temporary output, it is useful
to have the handling of these dealt with in one place. Add a new library
which allows input files to be read, and output files to be written, all
based on a common directory structure.
Some functions have the same code in the subclasses. Move these into the
superclass to avoid duplication.
These functions are identical in both subclasses. Move them into the base
class.
Note: In fact there is a bug in one version, which was fixed by this patch:
https://patchwork.ozlabs.org/patch/651697/
These functions are currently in a separate fdt_util file. Since they are
only used from PropBase and subclasses, it makes sense for them to be in the
PropBase class.
Move these functions into fdt.py along with the list of types.
At present we have two separate implementations of the Fdt library, one which
uses fdtget/fdtput and one which uses libfdt (via swig).
Before adding more functionality it makes sense to create a base class for
these. This will allow common functions to be shared, and make the Fdt API
a little clearer.
Create a new fdt.py file with the base class, and adjust fdt_normal.py and
fdt_fallback.py to use it.
In preparation for creating an Fdt base class, rename this file to indicate
it is the normal Fdt implementation.
Rather than have dtc worry about which fdt library to use, move this into
a helper file. Add a function which creates a new Fdt object and scans it,
regardless of the implementation.
This should be in with the other system includes. Move it.
It is more useful to have this method raise an error when something goes
wrong. Make this the default and adjust the few callers that don't want to
use it this way.
