path: root/tools
2009-04-04tools/Makefile: Remove symlinks for fdt targetsPeter Tyser
2009-04-04tools/Makefile: Add libfdt/ to the include search pathPeter Tyser
This change makes the process of symlinking libfdt_internal.h unnecessary Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-04-04tools: Remove unecessary symlinking of zlib.hPeter Tyser
crc32.c uses the zlib.h header in include/u-boot/zlib.h. The symlink was previously necessary to give U-Boot's version of zlib.h precedence over the host computer's version of zlib.h. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-04-04tools/Makefile: Add tools/ to the include search pathPeter Tyser
This change makes the process of symlinking mkimage.h and fdt_host.h unnecessary Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-04-04tools/Makefile: Compile ncb when CONFIG_NETCONSOLEPeter Tyser
Also conditionally add ncb.o to OBJ_FILES list Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-04-04tools/Makefile: Make gen_eth_addr dependent upon CONFIG_CMD_NETPeter Tyser
2009-04-04tools/Makefile: Make envcrc dependent upon CONFIG_ENV_IS_EMBEDDEDPeter Tyser
2009-04-04tools/Makefile: Make inca-swap-bytes dependent on CONFIG_INCA_IPPeter Tyser
2009-04-04tools/Makefile: Make ubsha1 dependent upon CONFIG_SHA1_CHECK_UB_IMGPeter Tyser
2009-04-04tools/Makefile: Make img2srec dependent upon CONFIG_CMD_LOADSPeter Tyser
2009-04-04tools/Makefile: Build bmp_logo only when LCD or VIDEO logos are enabledPeter Tyser
2009-04-04tools/Makefile: Split variable declarations into multiple linesPeter Tyser
Split variable declarations into multiple lines and use the standard VAR-y convention. Also move object and binary variable declarations to after config.mk has been included to allow for these lists to utilize the CONFIG_XXX variables. These changes lay the groundwork for conditional compilation of files in the tools directory. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-04-04tools/Makefile: Remove inappropriate double-tabsPeter Tyser
2009-04-04tools/Makefile: Remove HOSTARCH HOSTOS definesPeter Tyser
The values of HOSTARCH and HOSTOS which are exported from the top-level Makefile should be used Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-04-04gen_eth_addr: Use POSIX rand() and srand()Peter Tyser
Replace random()/srandom() use with rand()/srand() to support compilation with the mingw toolchain. The rand()/srand() functions are generally more common and are functionally equivalent to the original random()/srandom() calls. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-01-28Standardize command usage messages with cmd_usage()Peter Tyser
2009-01-24easylogo: add optional gzip supportMike Frysinger
Some images can be quite large, so add an option to compress the image data with gzip in the U-Boot image. Then at runtime, the board can decompress it with the normal zlib functions. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-01-16ncb: use socklen_tMike Frysinger
The recvfrom() function takes a socklen_t, not an int. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-12-15Fix a typo in fw_env.configMartin Michlmayr
Reported-by: Martin Michlmayr <tbm@cyrius.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-12-10tools/netconsole: new script for working with netconsole over UDPMike Frysinger
While the doc/README.NetConsole does have a snippet for people to create their own netcat script, it's a lot easier to make a simple dedicated script and tell people to use it. Also spruce it up a bit to make it user friendly. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-10-18Adds two more ethernet interface to 83xxrichardretanubun
Added as a convenience for other platforms that uses MPC8360 (has 8 UCC). Six eth interface is chosen because the platform I am using combines UCC1&2 and UCC3&4 as 1000 Eth and the other four UCCs as 10/100 Eth. Signed-off-by: Richard Retanubun <RichardRetanubun@RugggedCom.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-09-09fw_env: add NAND supportGuennadi Liakhovetski
Add support for environment in NAND with automatic NOR / NAND recognition, including unaligned environment, bad-block skipping, redundant environment copy. Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
2008-09-02fw_env.c: fix build problems with MTD_VERSION=oldWolfgang Denk
(as needed to support old 2.4 Linux kernel based releases) Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-08-18Add 'license' command to U-Boot command lineHarald Welte
The 'license' command includes the U-Boot license (GPLv2) into the actual bootloader binary. The license text can be shown interactively at the U-Boot commandline. For products where the commandline can actually be accessed by the end user, this helps to prevent inadvertent GPL violations, since the GPLv2 license text can no longer be 'forgotten' to be included into the product. The 'license' command can be enabled by CONFIG_CMD_LICENSE. Signed-off-by: Harald Welte <laforge@openmoko.org>
2008-07-15tools/gitignore: update to all generated filesJean-Christophe PLAGNIOL-VILLARD
2008-07-14Code cleanup: fix old style assignment ambiguities like "=-" etc.Wolfgang Denk
2008-07-11Fixed some out-of-tree build issuesWolfgang Denk
2008-07-02Add logos for RRvision boardGary Jennejohn
Signed-off-by: Gary Jennejohn <garyj@denx.de>
2008-05-24Merging Stelian Pop AT91 patchesJean-Christophe PLAGNIOL-VILLARD
Merge branch 'testing-V2' Conflicts: board/atmel/at91cap9adk/Makefile Fixing copyright board/atmel/at91sam9260ek/Makefile Fixing copyright board/atmel/at91sam9260ek/u-boot.lds Delete no more needed ld script Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-05-10Use custom logo for Atmel boardsStelian Pop
This patch adds a custom vendor logo for the Atmel AT91 boards. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-05-09Propagate Error Status to the Shell on fw_printenv ErrorsGrant Erickson
Changed implementation such that fw_printenv returns failure status when one or more specified variables do not exist or when incorrect command syntax is used. This aids scripting fw_printenv such that the script can key of the return status rather than relying on standard error "scraping". Signed-off-by: Grant Erickson <gerickson@nuovations.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-05-09Fix Compilation Errors with 'tools/env/fw_printenv'Grant Erickson
In the current top-of-tree, 1.3.3.-rc2, the optional tool 'tools/env/fw_printenv' fails to compile for two reasons: 1) The header watchdog.h cannot be found. 2) The header zlib.h is picked up from the tool chain rather than the project causing a prototype conflict for crc32. This patch addresses both of these issues. Platforms Tested On: - AMCC "Kilauea" Signed-off-by: Grant Erickson <gerickson@nuovations.com>
2008-05-03mkimage: make mmap() checks consistentMike Frysinger
The mmap() related code is full of inconsistent casts/constants when it comes to error checking, and may break when building on some systems (like ones that do not implicitly define the caddr_t type). Let's just avoid the whole mess by writing the code nice and clean in the first place. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-04-29Update .gitignore for zlib.hKumar Gala
2008-04-24Memory footprint optimizationsBartlomiej Sieka
As suggested by Wolfgang Denk: - image printing functions: - remove wrappers - remove indentation prefix from functions' signatures - merge getenv_verify and getenv_autostart into one parametrized function Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
2008-04-24crc32: use uint32_t rather than unsigned longMike Frysinger
The envcrc.c does sizeof(unsigned long) when calculating the crc, but this is done with the build toolchain instead of the target tool chain, so if the build is a 64bit system but the target is 32bits, the size will obviously be wrong. This converts all unsigned long stuff related to crc32 to uint32_t types. Compile tested only: output of ./tools/envcrc when run on a 32bit build system matches that of a 64bit build system. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-04-18Add support for u-boot in svn and localversion-* filesMike Frysinger
2008-03-27Fix out of tree building issueAnatolij Gustschin
Currently U-Boot building in some external directory doesn't work. This patch tries to fix the problem. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2008-03-26Merge branch 'new-image' of git://www.denx.de/git/u-boot-testingBartlomiej Sieka
Conflicts: common/cmd_bootm.c cpu/mpc8xx/cpu.c Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
2008-03-14Add MD5 support to the new uImage formatBartlomiej Sieka
2008-03-14tools/setlocalversion: use a git-describe-ish formatWolfgang Denk
Change the automatic local version to have the form -nnnnn-gSHA1SUMID, where 'nnnnn' is the number of commits since the last tag (i.e., 1.3.2-rc3). This makes it much easier to recognize "newer" versions and to see how much has been changed since the referenced tag. Stolen from Linux kernel's scripts/setlocalversio, see commit d882421f. Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-03-11[new uImage] Add support for new uImage format to mkimage toolBartlomiej Sieka
Support for the new uImage format (FIT) is added to mkimage tool. Commandline syntax is appropriately extended: mkimage [-D dtc_options] -f fit-image.its fit-image mkimage (together with dtc) takes fit-image.its and referenced therein binaries (like vmlinux.bin.gz) as inputs, and produces fit-image file -- the final image that can be transferred to the target (e.g., via tftp) and then booted using the bootm command in U-Boot. Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
2008-03-10[new uImage] New uImage low-level APIMarian Balakowicz
Add FDT-based functions for handling new format component images, configurations, node operations, property get/set, etc. fit_ - routines handling global new format uImage operations like get/set top level property, process all nodes, etc. fit_image_ - routines handling component images subnodes fit_conf_ - routines handling configurations node Signed-off-by: Bartlomiej Sieka <tur@semihalf.com> Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-02-29[new uImage] Add libfdt support to mkimageBartlomiej Sieka
2008-02-29[new uImage] Add sha1.o object to mkimage binary buildBartlomiej Sieka
