path: root/tools/zynqimage.c
2016-12-27tools: mkimage: Call fclose in error pathMichal Simek
This patch is fixing missing fclose() calls in error patch introduced by: "tools: mkimage: Use fstat instead of stat to avoid malicious hacks" (sha1: ebe0f53f48e8f9ecc823e533a85b05c13638c350) Reported-by: Coverity (CID: 155064, 155065) Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-12-09tools: mkimage: Use fstat instead of stat to avoid malicious hacksMichal Simek
The patch is fixing: "tools: mkimage: Check if file is regular file" (sha1: 56c7e8015509312240b1ee15f2ff74510939a45d) which contains two issues reported by Coverity Unchecked return value from stat and incorrect calling sequence where attack can happen between calling stat and fopen. Using pair in opposite order (fopen and fstat) is fixing this issue because fstat is using the same file descriptor (FILE *). Also fixing issue with: "tools: mkimage: Add support for initialization table for Zynq and ZynqMP" (sha1: 3b6460809c2a28360029c1c48247648fac4455c9) where file wasn't checked that it is regular file. Reported-by: Coverity (CID: 154711, 154712) Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-12-09Revert "Merge branch 'master' of git://www.denx.de/git/u-boot-microblaze"Tom Rini
This reverts commit 3edc0c252257e4afed163a3a74aba24a5509b198, reversing changes made to bb135a0180c31fbd7456021fb9700b49bba7f533.
2016-12-08tools: mkimage: Use fstat instead of stat to avoid malicious hacksMichal Simek
The patch is fixing: "tools: mkimage: Check if file is regular file" (sha1: 56c7e8015509312240b1ee15f2ff74510939a45d) which contains two issues reported by Coverity Unchecked return value from stat and incorrect calling sequence where attack can happen between calling stat and fopen. Using pair in opposite order (fopen and fstat) is fixing this issue because fstat is using the same file descriptor (FILE *). Also fixing issue with: "tools: mkimage: Add support for initialization table for Zynq and ZynqMP" (sha1: 3b6460809c2a28360029c1c48247648fac4455c9) where file wasn't checked that it is regular file. Reported-by: Coverity (CID: 154711, 154712) Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Tom Rini <trini@konsulko.com> Series-to: trini Series-cc: u-boot
2016-11-15tools: mkimage: Add support for initialization table for Zynq and ZynqMPMike Looijmans
The Zynq/ZynqMP boot.bin file contains a region for register initialization data. Filling in proper values in this table can reduce boot time (e.g. about 50ms faster on QSPI boot) and also reduce the size of the SPL binary. The table is a simple text file with register+data on each line. Other lines are simply skipped. The file can be passed to mkimage using the "-R" parameter. It is recommended to add reg init file to board folder. For example: CONFIG_BOOT_INIT_FILE="board/xilinx/zynqmp/xilinx_zynqmp_zcu102/reg.int Signed-off-by: Mike Looijmans <mike.looijmans@topic.nl> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-12-18tools: zynqimage: Clean up check_paramsNathan Rossi
Clean up the param checking, removing some code paths that will never happen. Signed-off-by: Nathan Rossi <nathan@nathanrossi.com> Cc: Michal Simek <michal.simek@xilinx.com> Cc: Tom Rini <trini@konsulko.com> Reported-by: Coverity (CID 133251) Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-11-19tools: zynqimage: Add Xilinx Zynq boot header generation to mkimageNathan Rossi
As with other platforms vendors love to create their own boot header formats. Xilinx is no different and for the Zynq platform/SoC there exists the "boot.bin" which is read by the platforms bootrom. This format is described to a useful extent within the Xilinx Zynq TRM. This implementation adds support for the 'zynqimage' to mkimage. The implementation only considers the most common boot header which is un-encrypted and packed directly after the boot header itself (no XIP, etc.). However this implementation does take into consideration the other fields of the header for image dumping use cases (vector table and register initialization). Signed-off-by: Nathan Rossi <nathan@nathanrossi.com> Cc: Michal Simek <michal.simek@xilinx.com> Cc: Tom Rini <trini@konsulko.com> Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
