path: root/tools/updater
2007-07-10disk/ doc/ lib_*/ and tools/: Remove lingering references to CFG_CMD_* symbols.Jon Loeliger
2007-07-09tools/: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
2007-07-04tools/ : Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2006-09-01Fix tools/updater build error.Marian Balakowicz
2005-10-11Added support for TQM834x boards.Marian Balakowicz
2003-07-24* Implement new mechanism to export U-Boot's functions to standalonewdenk
applications: instead of using (PPC-specific) system calls we now use a jump table; please see doc/README.standalone for details * Patch by Dave Westwood, 24 Jul 2003: added support for Unity OS (a proprietary OS)
