path: root/tools/updater/utils.c
2013-11-25tools: updater: Remove remainders of dead boardMasahiro Yamada
tools/updater needs board/MAI/AmigaOneG3SE board for compiling. But AmigaOneG3SE board was already deleted by Commit 953b7e6. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
