path: root/tools/ubsha1.c
2009-04-04Add support for building native win32 toolsPeter Tyser
Add support for compiling the host tools in the tools directory using the MinGW toolchain. This produces executables which can be used on standard Windows computers without requiring cygwin. One must specify the MinGW compiler and strip utilities as if they were the host toolchain in order to build win32 executables, eg: make HOSTCC=i586-mingw32msvc-gcc HOSTSTRIP=i586-mingw32msvc-strip tools Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2007-07-10Coding style cleanup; update CHANGELOG.Wolfgang Denk
2007-06-22[PCS440EP] upgrade the PCS440EP board:Heiko Schocher
- Show on the Status LEDs, some States of the board. - Get the MAC addresses from the EEProm - use PREBOOT - use the CF on the board. - check the U-Boot image in the Flash with a SHA1 checksum. - use dynamic TLB entries generation for the SDRAM Signed-off-by: Heiko Schocher <hs@denx.de>
