path: root/tools/ublimage.c
2013-08-16tools/Makefile: Move _GNU_SOURCE to MakefileYork Sun
Commit 669dfc2e adds libfdt_env.h to HOSTCPPFLAGS. It causes stdio.h to be included before _GNU_SOURCE is defined in C files. On some old hosts some prototypes are protected by #ifdef __USE_GNU, which is set when _GNU_SOURCE is defined. Signed-off-by: York Sun <yorksun@freescale.com> Acked-by: Simon Glass <sjg@chromium.org>
2011-10-05mkimage: ublimage must return if the header is not verifiedStefano Babic
Each image handler must return a not-zero velue if the header is not recognized to allow the main program to iterate to the next handler. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Heiko Schocher <hs@denx.de> Acked-by: Heiko Schocher <hs@denx.de>
2011-07-28mkimage: add UBL header support for booting davinci cpusHeiko Schocher
creating an u-boot.ubl file, which contains the UBL Header needed for booting from NAND with the RBL from TI. For more information read doc/README.ublimage. Signed-off-by: Heiko Schocher <hs@denx.de>
