path: root/tools/socfpgaimage.c
2020-04-24tool: use ALIGN() to align the sizeKever Yang
Use the ALIGN() for size align so that the code is more readable. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Reviewed-by: Punit Agrawal <punit1.agrawal@toshiba.co.jp> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-12-02crc32: Use the crc.h header for crc functionsSimon Glass
Drop inclusion of crc.h in common.h and use the correct header directly instead. With this we can drop the conflicting definition in fw_env.h and rely on the crc.h header, which is already included. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-10-03tools: socfpga: fix sfp_verify_headerAtsushi Nemoto
Fix sfp_verify_header to return correct version number. This fixes "Not a sane SOCFPGA preloader" error message with v1 header. Signed-off-by: Atsushi Nemoto <atsushi.nemoto@sord.co.jp>
2018-05-08tools: socfpga: Add SFP image V1 supportMarek Vasut
Add support for the SoCFPGA header v1 , which is used on Arria 10. Thus far the mkimage-socfpga image only supported header format v0 used on Cyclone V and Arria V, but is not supported on Arria 10. The layout of the v0 and v1 header is similar, yet there are a few differences, see the patch body for details. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Dinh Nguyen <dinguyen@kernel.org> Cc: Chin Liang See <chin.liang.see@intel.com>
2018-05-08tools: socfpga: Stop using global struct socfpga_imageMarek Vasut
The structure is passed around correctly, create local instances where necessary and zap the global struct socfpga_image instance. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Dinh Nguyen <dinguyen@kernel.org> Cc: Chin Liang See <chin.liang.see@intel.com>
2015-01-29tools: do not print error messages in verify_header() functionsGuilherme Maciel Ferreira
default_image.c and socfpgaimage.c are the only image modules that print error messages during header verification. The verify_header() is used to query if a given image file is processed by the image format. Thus, if the image format can't handle the file, it must simply return an error. Otherwise we pollute the screen with errors messages until we find the image format that handle a given image file. Signed-off-by: Guilherme Maciel Ferreira <guilherme.maciel.ferreira@gmail.com>
2015-01-29imagetool: replace image registration function by linker_lists featureGuilherme Maciel Ferreira
The registration was introduced in commit f86ed6a8d52c99bb2d17d3cac1647edca0c4399c This commit also removes all registration functions, and the member "next" from image_type_params struct Signed-off-by: Guilherme Maciel Ferreira <guilherme.maciel.ferreira@gmail.com>
2014-10-27tools/socfpgaimage.c: fix build on darwinAndreas Bießmann
socfpgaimage utilizes htole32 and friends, unfortunately these functions are not available on darwin. Fix it by using the cpu_to_le32 and friends defined in compiler.h as other parts in mkimage do. This patch fixes the following error: ---8<--- HOSTCC tools/socfpgaimage.o tools/socfpgaimage.c:77:22: warning: implicit declaration of function 'htole32' is invalid in C99 [-Wimplicit-function-declaration] header.validation = htole32(VALIDATION_WORD); ^ tools/socfpgaimage.c:80:22: warning: implicit declaration of function 'htole16' is invalid in C99 [-Wimplicit-function-declaration] header.length_u32 = htole16(length_bytes/4); ^ tools/socfpgaimage.c:95:6: warning: implicit declaration of function 'le32toh' is invalid in C99 [-Wimplicit-function-declaration] if (le32toh(header.validation) != VALIDATION_WORD) ^ tools/socfpgaimage.c:97:6: warning: implicit declaration of function 'le16toh' is invalid in C99 [-Wimplicit-function-declaration] if (le16toh(header.checksum) != hdr_checksum(&header)) ^ 4 warnings generated. ... HOSTLD tools/dumpimage Undefined symbols for architecture x86_64: "_htole16", referenced from: _socfpgaimage_set_header in socfpgaimage.o "_htole32", referenced from: _socfpgaimage_set_header in socfpgaimage.o "_le16toh", referenced from: _verify_buffer in socfpgaimage.o "_le32toh", referenced from: _verify_buffer in socfpgaimage.o ld: symbol(s) not found for architecture x86_64 --->8--- Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Acked-by: Pavel Machek <pavel@denx.de>
2014-10-06tools: socfpga: Add socfpga preloader signing to mkimageCharles Manning
Like many platforms, the Altera socfpga platform requires that the preloader be "signed" in a certain way or the built-in boot ROM will not boot the code. This change automatically creates an appropriately signed preloader from an SPL image. The signed image includes a CRC which must, of course, be generated with a CRC generator that the SoCFPGA boot ROM agrees with otherwise the boot ROM will reject the image. Unfortunately the CRC used in this boot ROM is not the same as the Adler CRC in lib/crc32.c. Indeed the Adler code is not technically a CRC but is more correctly described as a checksum. Thus, the appropriate CRC generator is added to lib/ as crc32_alt.c. Signed-off-by: Charles Manning <cdhmanning@gmail.com> Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@altera.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Tom Rini <trini@ti.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Pavel Machek <pavel@denx.de> Acked-by: Pavel Machek <pavel@denx.de> V2: - Zap unused constant - Explicitly print an error message in case of error - Rework the hdr_checksum() function to take the *header directly instead of a plan buffer pointer
