path: root/tools/scripts/define2mk.sed
2013-04-12autoconfig.mk: Make it possible to define configs from other configsBenoît Thébaudeau
Give more flexibility to define configs that can be interpreted by make, e.g. to define fallback values of configs like in the example below. Before this change, the config lines: #define CONFIG_SPL_MAX_SIZE 2048 #define CONFIG_SPL_PAD_TO CONFIG_SPL_MAX_SIZE would have been changed in autoconfig.mk into: CONFIG_SPL_MAX_SIZE=2048 CONFIG_SPL_PAD_TO="CONFIG_SPL_MAX_SIZE" Hence, a make recipe using as an argument to $(OBJCOPY): --pad-to=$(CONFIG_SPL_PAD_TO) would have issued: --pad-to="CONFIG_SPL_MAX_SIZE" which means nothing for $(OBJCOPY) and makes it fail. Thanks to this change, the config lines above are changed in autoconfig.mk into: CONFIG_SPL_MAX_SIZE=2048 CONFIG_SPL_PAD_TO=$(CONFIG_SPL_MAX_SIZE) Hence, the make recipe above now issues: --pad-to=2048 as expected from the defined config. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Reviewed-by: Tom Rini <trini@ti.com>
2010-10-18autoconfig.mk: avoid apostophes around hex valuesWolfgang Denk
When generating include/autoconfig.mk, hex numbers would be quoted. This caused some false positives during automatic testing of the builds, and is known to cause some real issues for some Blackfin configurations. Don't use apostophes for decimal and hex numbers (nor for octal numbers). Signed-off-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-02-22make define2mk.sed work on FreeBSDMarcel Moolenaar
In the thread "[1.3.2-rc1] MPC8548CDS/MPC8555CDS configs fails to link", the define2mk.sed script was identified as the source of the link failure on FreeBSD. The problem is that sed(1) does not always support the '+' operator. It isn't on FreeBSD. The attach patch implements the equivalent, using the '*' operator instead and should work everywhere. Signed-off-by: Marcel Moolenaar <marcelm@juniper.net>
2007-11-20[BUILD] Generate include/autoconf.mk from board config filesGrant Likely
Use cpp and sed to postprocess config.h and import the defined values into include/autoconf.mk. autoconf.mk is then included by config.mk to give 'make' access to the board configuration. Doing this enables conditional compilation at the Makefile level instead of by wrapping every .c file with #ifdef/#endif wrappers. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
