There are few places where the path of the current modules is calculated
but not used. Drop them.
Now that we are using absolute paths we can remove some of the sys.path
mangling that appears in the tools.
We only need to add the path to 'tools/' so that everything can find
modules relative to that directory.
The special paths for finding pylibfdt remain.
At present patman sets the python path on startup so that it can access
the libraries it needs. If we convert to use absolute imports this is not
necessary.
Move patman to use absolute imports. This requires changes in tools which
use the patman libraries (which is most of them).
We don't need these now that the tools using Python 3. Drop them.
This script already works with Python 3. Make it use that by default so
that it can import the patman libraries.
This script attempts to create a git commit which removes a single board.
It is quite fallible and everything it does needs checking. But it can
help speed up the process.
Reviewed-by: Chris Packham <judge.packham@gmail.com>
