Sphinx expects Return: and not @return to indicate a return value.
find . -name '*.c' -exec \
sed -i 's/^\(\s\)\*\(\s*\)@return\(\s\)/\1*\2Return:\3/' {} \;
find . -name '*.h' -exec \
Signed-off-by: Heinrich Schuchardt <heinrich.schuchardt@canonical.com>
Support packing optional second level boot-loader:
$ ./tools/mkimage -n rk3399 -T rksd -d \
rk3399_ddr_800MHz_v1.24.bin:rk3399_miniloader_v1.19.bin out -v
Adding Image rk3399_ddr_800MHz_v1.24.bin
Size 116492(pad to 116736)
Adding Image rk3399_miniloader_v1.19.bin
Size 88060(pad to 88064)
Image Type: Rockchip RK33 (SD/MMC) boot image
Init Data Size: 116736 bytes
Boot Data Size: 88064 bytes
Mainly parse init file and boot file from datafile option, copy them to
the image with 2KB alignment.
Signed-off-by: Jeffy Chen <jeffy.chen@rock-chips.com>
Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
The Rockchip BootROM relies on init_size being aligned to 2KB
(see https://lists.denx.de/pipermail/u-boot/2017-May/293268.html).
This pads the image to 2KB both for SD card images and SPI images
and uses a common symbolic constant for the alignment.
Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
The rockchip image generation was previously missing the ability to
verify the generated header (and dump the image-type) without having
to resort to hexdump or od. Experience in our testing has showed it
to be very easy to get the rkspi and rksd images mixed up and the
lab... so we add the necessary support to have dumpimage tell us
what image type we're dealing with.
This change set adds the verify_header and print_header capability
to the rksd/rkspi image drivers (through shared code in rkcommon).
As of now, we only support images fully that are not RC4-encoded for
the SPL payload (i.e. header1 and payload). For RC4-encoded payloads,
the outer header (header0) is checked, but no detection of whether
this is a SD/MMC or SPI formatted payload takes place.
The output of dumpsys now prints the image type (spl_hdr), whether it
is a SD/MMC or SPI image, and the (padded) size of the image:
$ ./tools/dumpimage -l ./spl.img
^^^^^^ SD/MMC vs. SPI indication
^^^^ spl_hdr indicated by the image
Data Size: 79872 bytes
In (first) breaking and (then) fixing the rkspi tool, I realised that
the calculation of the required padding (for the header-size and the
2K-in-every-4K SPI layout) was not as self-explainatory as it could
have been. This change rewrites the code (using new, common functions
in rkcommon.c) and adds verbose in-line comments to ensure that we
won't fall into the same pit in the future...
Tested on the RK3399 (with has a boot0-style payload) with SD/MMC and SPI.
To simplify the creation of AArch64 SPL images for the RK3399, we
use the ENABLE_ARM_SOC_BOOT0_HOOK option and prepend 4 bytes of
padding at the start of the text section. This makes it easy for
mkimage to rewrite this word with the 'RK33' boot magic.
This change brings logic to calculate the header size and allocate
the header back in sync. For the RK3399 we now limit the header to
before the payload (i.e. the 'header0' and the padding up to the
actual image) and overwrite the first word (inserted by the
boot0-hook for this purpose) with the 'RK33' magic in-place.
X-AffectedPlatforms: RK3399-Q7
Tested-by: Klaus Goger <klaus.goger@theobroma-systems.com>
The RK3399 boot code (running as AArch64) poses a bit of a challenge
for SPL image generation:
* The BootROM will start execution right after the 4-byte header (at
the odd instruction word loaded into SRAM at 0xff8c2004, with the
'RK33' boot magic residing at 0xff8c2000).
* The default padding (during ELF generation) for AArch64 is 0x0,
which is an illegal instruction and the .text section needs to be
naturally aligned (someone might locate a 64bit constant relative
to the section start and unaligned loads trigger a fault for all
privileged modes of an ARMv8)... so we can't simply define the
CONFIG_SPL_TEXT_BASE option to the odd address (0xff8c2004).
* Finally, we don't want to change the values used for padding of
the SPL .text section for all ARMv8 targets to the instruction
word encoding 'nop', as this would affect all padding in this
section and might hide errors that would otherwise quickly trigger
an illegal insn exception.
To deal with this situation, we modify the rkimage generation to
- understand the fact that the RK3399 needs to pad the header to an
8 byte boundary using an AArch64 'nop'
- the necessary logic to adjust the header_size (which controls the
location where the payload is copied into the image) and to insert
this padding (AArch64 insn words are always little-endian) into
the image following the 4-byte header magic.
Rockchip SoCs allow the spl code to be rc4-encoded, not only the
image header, but only newer SoCs allow this encoding to be disabled.
The rk3188 is not part of those and requires its boot code to be
rc4-encoded with the regular key. So add the ability to do this
encoding via a setting on a per-soc basis when building spl images.
Signed-off-by: Heiko Stuebner <heiko@sntech.de>
Tested-by: Kever Yang <kever.yang@rock-chips.com>
Our chips may have different spl size and spl header, so
use imagename(passed by "mkimage -n") to select them now.
This reverts commit 10b4615f9d7e177ec7fe644fbb2616e0e0956f6e
The Rockchip boot ROM could load & run an initial spl loader,
and continue to load a second level boot-loader(which stored
right after the initial loader) when it returns.
Modify idblock generation code to support it.
Our chips may have different max spl size and spl header, so
we need to add configs for that.
Dropped CONFIG_ROCKCHIP_MAX_SPL_SIZE from rk3288_common.h,
Added $(if...) to tools/Makefile to fix widespread build breakage
Series-changes: 8
- Drop CONFIG_ROCKCHIP_MAX_SPL_SIZE from rk3288_common.h,
- Add $(if...) to tools/Makefile to fix widespread build breakage
Rockchip SoCs require certain formats for code that they execute, The
simplest format is a 4-byte header at the start of a binary file. Add
support for this so that we can create images that the boot ROM understands.
