path: root/tools/prelink-riscv.inc
2018-01-12riscv: tools: Prelink u-bootRick Chen
Add prelink-riscv to arrange .rela.dyn and .rela.got in compile time. So that u-boot can be directly executed without fixup. Signed-off-by: Chih-Mao Chen <cmchen@andestech.com> Signed-off-by: Rick Chen <rick@andestech.com> Signed-off-by: Rick Chen <rickchen36@gmail.com> Signed-off-by: Greentime Hu <green.hu@gmail.com>
