path: root/tools/pblimage.c
2017-09-11tools: pblimage: Fix address calculationYork Sun
The image size should be added to the initial pbl command, not bit "ORed". Signed-off-by: York Sun <york.sun@nxp.com>
2017-03-28tools: plbimage support generate rcw fileyuan linyu
some system will not generate pbl format u-boot, but require rcw. Signed-off-by: yuan linyu <Linyu.Yuan@alcatel-sbell.com.cn> Reviewed-by: Alison Wang <alison.wang@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-10-14pbl: use "wait" command instead of "flush" commandZhao Qiang
PBL flush command is restricted to CCSR memory space. So use WAIT PBI command to provide enough time for data to get flush in target memory. Signed-off-by: Zhao Qiang <qiang.zhao@nxp.com> [York Sun: rewrap commit message] Reviewed-by: York Sun <york.sun@nxp.com>
2015-01-29imagetool: replace image registration function by linker_lists featureGuilherme Maciel Ferreira
The registration was introduced in commit f86ed6a8d52c99bb2d17d3cac1647edca0c4399c This commit also removes all registration functions, and the member "next" from image_type_params struct Signed-off-by: Guilherme Maciel Ferreira <guilherme.maciel.ferreira@gmail.com>
2014-12-11ls102xa: pblimage: Add pblimage tool support for LS102xAAlison Wang
For LS102xA, the size of spl/u-boot-spl.bin is variable. This patch adds the support to deal with the variable u-boot size in pblimage tool. It will be padded to 64 byte boundary. Use pblimage_check_params() to add the specific operations for ARM, such as PBI CRC and END command and the calculation of pbl_cmd_initaddr. Signed-off-by: Alison Wang <alison.wang@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-06-05mkimage : Split out and clean pbl_crc32 for use by other image typesCharles Manning
The crc32 used by pblimgae is NOT the same as zlib crc32. The pbl_crc32 is useful for other purposes in mkimage so split it out. While we are about it, clean up redundant and confusing code. Signed-off-by: Charles Manning <cdhmanning@gmail.com>
2013-12-13tools: moved code common to all image tools to a separated module.Guilherme Maciel Ferreira
In order to avoid duplicating code and keep only one point of modification, the functions, structs and defines useful for "dumpimage" were moved from "mkimage" to a common module called "imagetool". This modification also weakens the coupling between image types (FIT, IMX, MXS, and so on) and image tools (mkimage and dumpimage). Any tool may initialize the "imagetool" through register_image_tool() function, while the image types register themselves within an image tool using the register_image_type() function: +---------------+ +------| fit_image | +--------------+ +-----------+ | +---------------+ | mkimage |--------> | | <-----+ +--------------+ | | +---------------+ | imagetool | <------------| imximage | +--------------+ | | +---------------+ | dumpimage |--------> | | <-----+ +--------------+ +-----------+ | +---------------+ +------| default_image | +---------------+ register_image_tool() register_image_type() Also, the struct "mkimage_params" was renamed to "image_tool_params" to make clear its general purpose. Signed-off-by: Guilherme Maciel Ferreira <guilherme.maciel.ferreira@gmail.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2013-08-16tools/Makefile: Move _GNU_SOURCE to MakefileYork Sun
Commit 669dfc2e adds libfdt_env.h to HOSTCPPFLAGS. It causes stdio.h to be included before _GNU_SOURCE is defined in C files. On some old hosts some prototypes are protected by #ifdef __USE_GNU, which is set when _GNU_SOURCE is defined. Signed-off-by: York Sun <yorksun@freescale.com> Acked-by: Simon Glass <sjg@chromium.org>
2013-06-20powerpc/CoreNet: Allow pbl images to take u-boot images != 512KChris Packham
Instead of assuming that SYS_TEXT_BASE is 0xFFF80000 calculate the initial pbl command offset by subtracting the image size from the top of the 24-bit address range. Also increase the size of the memory buffer to accommodate a larger output image. Signed-off-by: Chris Packham <chris.packham@alliedtelesis.co.nz> Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-08-23powerpc/CoreNet: add tool to support pbl image build.Shaohui Xie
Provides a tool to build boot Image for PBL(Pre boot loader) which is used on Freescale CoreNet SoCs, PBL can be used to load some instructions and/or data for pre-initialization. The default output image is u-boot.pbl, for more details please refer to doc/README.pblimage. Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
