path: root/tools/patman/project.py
2013-01-31patman: Add the concept of multiple projectsDoug Anderson
There are cases that we want to support different settings (or maybe even different aliases) for different projects. Add support for this by: * Adding detection for two big projects: U-Boot and Linux. * Adding default settings for Linux (U-Boot is already good with the standard patman defaults). * Extend the new "settings" feature in .patman to specify per-project settings. Signed-off-by: Doug Anderson <dianders@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
