path: root/tools/mxsimage.c
2019-12-02crc32: Use the crc.h header for crc functionsSimon Glass
Drop inclusion of crc.h in common.h and use the correct header directly instead. With this we can drop the conflicting definition in fw_env.h and rely on the crc.h header, which is already included. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-04-06tools/mxsimage: Support building with LibreSSLHauke Mehrtens
The mxsimage utility fails to compile against LibreSSL version < 2.7.0 because LibreSSL says it is OpenSSL 2.0, but it does not support the complete OpenSSL 1.1 interface. LibreSSL defines OPENSSL_VERSION_NUMBER with 0x20000000L and therefor claims to have an API compatible with OpenSSL 2.0, but it implements EVP_MD_CTX_new(), EVP_MD_CTX_free() and EVP_CIPHER_CTX_reset() only starting with version 2.7.0, which is not yet released. OpenSSL implements this function since version 1.1.0. This commit will activate the compatibility code meant for OpenSSL < 1.1.0 also for LibreSSL version < 2.7.0. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Reviewed-by: Jonathan Gray <jsg@jsg.id.au>
2016-12-19tools: mxsimage: Fix build with OpenSSL 1.1.xMarek Vasut
The EVP_MD_CTX and EVP_CIPHER_CTX are made opaque since 1.1.x , so instead of embedding them directly into struct sb_image_ctx and initializing them using EVP_*_CTX_init(), we use pointers and allocate the crypto contexts using EVP_*_CTX_new(). Signed-off-by: Marek Vasut <marex@denx.de> Cc: Tom Rini <trini@konsulko.com>
2015-01-29imagetool: replace image registration function by linker_lists featureGuilherme Maciel Ferreira
The registration was introduced in commit f86ed6a8d52c99bb2d17d3cac1647edca0c4399c This commit also removes all registration functions, and the member "next" from image_type_params struct Signed-off-by: Guilherme Maciel Ferreira <guilherme.maciel.ferreira@gmail.com>
2014-11-20tools/msximage.c: fix warning about nptr possibly uninitializedAlbert ARIBAUD
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2014-11-20ARM: mxs: tools: Add support for boot progress display flagAlexey Ignatov
mkimage -T mxs now support new flag in config file: DISPLAYPROGRESS - makes boot process print HTLLC characters for each BootROM instruction. Signed-off-by: Alexey Ignatov <lexszero@gmail.com>
2014-06-05tools: Refactor mxsimage to use pbl_crc32Charles Manning
Both pblimage and mxsimage use the same crc algorithm, so refactor. Signed-off-by: Charles Manning <cdhmanning@gmail.com>
2014-01-10Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
Bringing in the MMC tree means that CONFIG_BOUNCE_BUFFER needed to be added to include/configs/exynos5-dt.h now. Conflicts: include/configs/exynos5250-dt.h Signed-off-by: Tom Rini <trini@ti.com>
2013-12-17ARM: mxs: tools: Fix errno handling in strtoul() invocationMarek Vasut
According to NOTE in strtoul(3), the errno must be zeroed before strtoul() is called. Zero the errno. The NOTE reads as such: Since strtoul() can legitimately return 0 or ULONG_MAX (ULLONG_MAX for strtoull()) on both success and failure, the calling program should set errno to 0 before the call, and then determine if an error occurred by checking whether errno has a nonzero value after the call. This issue was detected on Fedora 19 with glibc 2.17 . Signed-off-by: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Tom Rini <trini@ti.com>
2013-12-13tools: moved code common to all image tools to a separated module.Guilherme Maciel Ferreira
In order to avoid duplicating code and keep only one point of modification, the functions, structs and defines useful for "dumpimage" were moved from "mkimage" to a common module called "imagetool". This modification also weakens the coupling between image types (FIT, IMX, MXS, and so on) and image tools (mkimage and dumpimage). Any tool may initialize the "imagetool" through register_image_tool() function, while the image types register themselves within an image tool using the register_image_type() function: +---------------+ +------| fit_image | +--------------+ +-----------+ | +---------------+ | mkimage |--------> | | <-----+ +--------------+ | | +---------------+ | imagetool | <------------| imximage | +--------------+ | | +---------------+ | dumpimage |--------> | | <-----+ +--------------+ +-----------+ | +---------------+ +------| default_image | +---------------+ register_image_tool() register_image_type() Also, the struct "mkimage_params" was renamed to "image_tool_params" to make clear its general purpose. Signed-off-by: Guilherme Maciel Ferreira <guilherme.maciel.ferreira@gmail.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2013-08-31ARM: mxs: tools: Add mkimage support for MXS bootstreamMarek Vasut
Add mkimage support for generating and verifying MXS bootstream. The implementation here is mostly a glue code between MXSSB v0.4 and mkimage, but the long-term goal is to rectify this and merge MXSSB with mkimage more tightly. Once this code is properly in U-Boot, MXSSB shall be deprecated in favor of mkimage-mxsimage support. Note that the mxsimage generator needs libcrypto from OpenSSL, I therefore enabled the libcrypto/libssl unconditionally. MXSSB: http://git.denx.de/?p=mxssb.git;a=summary The code is based on research presented at: http://www.rockbox.org/wiki/SbFileFormat Signed-off-by: Marek Vasut <marex@denx.de> Cc: Tom Rini <trini@ti.com> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Otavio Salvador <otavio@ossystems.com.br>
