path: root/tools/mxsboot.c
2016-02-21mxsboot: remove unused includeAndreas Bießmann
Commit 276d3ebb883024d753cd9c69ab2fd243ffa1262e removed htole32() but missed to remove the corresponding header. This is annoying, since BSD systems do not have endian.h. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Acked-by: Marek Vasut <marex@denx.de> Acked-by: Michael Heimpold <mhei@heimpold.de>
2016-02-02tools: mxsboot: Use more portable cpu_to_le32()Bin Meng
Currently when building mxsboot on certain machines it reports: HOSTCC tools/mxsboot tools/mxsboot.c: In function 'mx28_create_sd_image': tools/mxsboot.c:560: warning: implicit declaration of function 'htole32' /tmp/cchLIV6q.o: In function 'main': mxsboot.c:(.text+0x6d8): undefined reference to 'htole32' mxsboot.c:(.text+0x6e7): undefined reference to 'htole32' mxsboot.c:(.text+0x6f6): undefined reference to 'htole32' mxsboot.c:(.text+0x705): undefined reference to 'htole32' mxsboot.c:(.text+0x711): undefined reference to 'htole32' /tmp/cchLIV6q.o:mxsboot.c:(.text+0x71d): more undefined references to 'htole32' follow collect2: ld returned 1 exit status make[1]: *** [tools/mxsboot] Error 1 make: *** [tools] Error 2 The solution is to use cpu_to_le32() instead which is more portable, just like other U-Boot tools [1] do. [1] http://lists.denx.de/pipermail/u-boot/2014-October/192919.html Suggested-by: Marek Vasut <marex@denx.de> Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Marek Vasut <marex@denx.de>
2015-09-13mxs: mxsboot: fix endianess for sd boot imagesMichael Heimpold
Running mxsboot on a big-endian system produces a sd image which cannot be started by the i.MX28 ROM. It complains on the debug uart as following: 0x8020a009 0x80502008 0x8020a009 0x80502008 ... Enforcing all fields within the BCB to little-endian make the image bootable again. Signed-off-by: Michael Heimpold <mhei@heimpold.de> Acked-by: Stefano Babic <sbabic@denx.de> Acked-by: Marek Vasut <marex@denx.de>
2015-09-02tools: mxsboot: calculate ECC block level dynamicallyJörg Krause
For pages of 2048 bytes the current setting of the ECC Error Correction Level is only true for an oob size of 64 bytes and wrong for all others. Instead of hard-coding every possible combination of page size and oob size use the dynamic calculation of the ECC strength introduced in commit 6121560d7714d6d8e41ce1687a1388a1a8fea4cb. Cc: Marek Vasut <marex@denx.de> Signed-off-by: Jörg Krause <joerg.krause@embedded.rocks> Acked-by: Marek Vasut <marex@denx.de> Reviewed-by: Stefano Babic <sbabic@denx.de>
2015-05-24tools: mxsboot: Calculate ECC strength dynamicallyJörg Krause
Calculating the ECC strength dynamically to be aligned with the mxs NAND driver and the Linux Kernel. Signed-off-by: Jörg Krause <joerg.krause@embedded.rocks> Reviewed-by: Marek Vasut <marex@denx.de>
2015-05-24mtd: nand: mxs: Replace magic number for bits per ECC level with macroJörg Krause
2015-01-19mxsboot : Support of 224-bytes OOB area lengthAlexandre Coffignal
Add support for the NAND Flash chip with page size of 4096+224-bytes OOB area length For example Micron MT29F4G08 NAND flash device defines a OOB area which is 224 bytes long (oobsize). Signed-off-by: Alexandre Coffignal <acoffignal@geral.com>
2013-09-10tools: mxsboot: Mark the FCB pages as validMarek Vasut
Without this marker, Linux will complain that the NAND pages with FCB are invalid. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Stefano Babic <sbabic@denx.de>
2013-08-31tools: mxsboot: Staticize functionsMarek Vasut
Make remaining non-static functions static and the same for vars. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Stefano Babic <sbabic@denx.de>
2013-04-26mxs: mxsboot: Move sdcard BCB header to 4 sectors offsetOtavio Salvador
The MX23 Boot ROM does blindly load from 2048 offset while the MX28 does parse the BCB header to known where to load the image from. We move the BCB header to 4 sectors offset so same code can be used by both SoCs avoiding code duplication. This idea was given by Marek Vasut <marex@denx.de> Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Tested-by: Fabio Estevam <fabio.estevam@freescale.com> Tested-by: Marek Vasut <marex@denx.de>
2012-03-17mxsboot: fix tool name in usage messageOtavio Salvador
2012-01-16MX28: Fix MXSBOOT segfault if no params specifiedMarek Vasut
Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Stefano Babic <sbabic@denx.de>
2011-11-11iMX28: Add image header generator toolMarek Vasut
This tool can now generate proper image for "BootStream" files. NOTE: This tool now works only for NAND. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Detlev Zundel <dzu@denx.de>
