path: root/tools/mksunxiboot.c
2017-05-17sunxi: Store the device tree name in the SPL headerSiarhei Siamashka
This patch updates the mksunxiboot tool to optionally add the default device tree name string to the SPL header. This information can be used by the firmware upgrade tools to protect users from harming themselves by trying to upgrade to an incompatible bootloader. The primary use case here is a non-removable bootable media (such as NAND, eMMC or SPI flash), which already may have a properly working, but a little bit outdated bootloader installed. For example, the user may download or build a new U-Boot image for "Cubieboard", and then attemept to install it on a "Cubieboard2" hardware by mistake as a replacement for the already existing bootloader. If this happens, the flash programming tool can identify this problem and warn the user. The size of the SPL header is also increased from 64 bytes to 96 bytes to provide enough space for the device tree name string. [Andre: split patch to remove OF_LIST hash feature] Signed-off-by: Siarhei Siamashka <siarhei.siamashka@gmail.com> Signed-off-by: Andre Przywara <andre.przywara@arm.com>
2017-05-17tools: mksunxiboot: allow larger SPL binariesAndre Przywara
mksunxiboot limits the size of the resulting SPL binaries to pretty conservative values to cover all SoCs and all boot media (NAND). It turns out that we have limit checks in place in the build process, so mksunxiboot can be relaxed and allow packaging binaries up to the actual 32KB the mask boot ROM actually imposes. This allows to have a bigger SPL, which is crucial for AArch64 builds. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagan Teki <jagan@openedev.com>
2016-10-30tools: add mksunxiboot to tools-all targetStefan Brüns
mksunxiboot is useful outside of u-boot, it is e.g. used by sunxi-tools. Signed-off-by: Stefan Brüns <stefan.bruens@rwth-aachen.de> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-09-29sunxi: (mksunxiboot) signature to indicate "sunxi" SPL variantBernhard Nortmann
This patch follows up on a discussion of ways to improve support for the sunxi FEL ("USB boot") mechanism, especially with regard to boot scripts, see: https://groups.google.com/d/msg/linux-sunxi/wBEGUoLNRro/rHGq6nSYCQAJ The idea is to convert the (currently unused) "pad" bytes in the SPL header into an area where data can be passed to U-Boot. To do this safely, we have to make sure that we're actually using our "sunxi" flavor of the SPL, and not the Allwinner boot0. The modified mksunxiboot introduces a special signature to the SPL header in place of the "pub_head_size" field. This can be used to reliably distinguish between compatible versions of sunxi SPL and anything else (older variants or Allwinner's boot0). Signed-off-by: Bernhard Nortmann <bernhard.nortmann@web.de> Acked-by: Siarhei Siamashka <siarhei.siamashka@gmail.com> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-09-29sunxi: move SPL-related definitions to platform-specific includeBernhard Nortmann
The sunxi platform currently doesn't seem to make any use of the asm/arch-sunxi/spl.h file. This patch moves some declarations from tools/mksunxiboot.c into it. This enables us to reuse those definitions when extending the sunxi board code (boards/sunxi/boards.c). Signed-off-by: Bernhard Nortmann <bernhard.nortmann@web.de> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-09-10sunxi: Ensure that 'mksunxiboot' tool produces deterministic outputSiarhei Siamashka
Currently some uninitialized padding bytes are written to the output file, as can be confirmed with valgrind: $ valgrind tools/mksunxiboot spl/u-boot-spl.bin spl/sunxi-spl.bin ==5581== Syscall param write(buf) points to uninitialised byte(s) ==5581== at 0x4F0F940: __write_nocancel (in /lib64/libc-2.20.so) ==5581== by 0x400839: main (in /tmp/u-boot/tools/mksunxiboot) ==5581== Address 0xffeff5d3c is on thread 1's stack ==5581== in frame #1, created by main (???) This patch fixes the problem by clearing the whole structure instead of just a portion of it. Signed-off-by: Siarhei Siamashka <siarhei.siamashka@gmail.com> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-05-29sunxi/nand: change BLOCK_SIZE in mksunxiboot to match NAND block sizeDaniel Kochmański
This change is necessary to calculate correct checksum for NAND boot. Works both for MMC and NAND. Without it BROM rejects boot image as invalid (bad checksum). (Changes block size from 0x200 to 0x2000). Signed-off-by: Daniel Kochmański <dkochmanski@turtle-solutions.eu> Signed-off-by: Roy Spliet <r.spliet@ultimaker.com> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-02-16tools: mksunxiboot: Fix problems on big endian systemsSiarhei Siamashka
Now my PS3 can be also used to build u-boot for sunxi devices. Signed-off-by: Siarhei Siamashka <siarhei.siamashka@gmail.com> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2014-07-06sunxi: mksunxiboot: Fix loading of files with a size which is not a multiple ↵Hans de Goede
of 4 We should not be aligning the amount of bytes which we try to read from the disk, this leads to trying to read more bytes then there are which fails. file_size is already aligned to BLOCK_SIZE before being stored in img.header.length, so there is no need for load_size at all. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2014-05-25sunxi: non-FEL SPL boot support for sun7iIan Campbell
Add support for booting from an MMC card. Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Henrik Nordström <henrik@henriknordstrom.net> Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Reviewed-by: Marek Vasut <marex@denx.de> Cc: Tom Cubie <Mr.hipboi@gmail.com> Reviewed-by: Tom Rini <trini@ti.com>
