path: root/tools/mkimage.h
2017-07-22dtc: mkimage: Add the possibility to specify DTCEmmanuel Vadot
FreeBSD recently switch to it's BSDL dtc. While it support most of the features of the GPL one it still lacks the incbin directive. Add the possibility to specify which dtc we want to use for compiling dts and generating fit image. Signed-off-by: Emmanuel Vadot <manu@bidouilliste.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-06-19includes: move openssl headers to include/u-bootJeroen Hofstee
commit 18b06652cd "tools: include u-boot version of sha256.h" unconditionally forced the sha256.h from u-boot to be used for tools instead of the host version. This is fragile though as it will also include the host version. Therefore move it to include/u-boot to join u-boot/md5.h etc which were renamed for the same reason. cc: Simon Glass <sjg@chromium.org> Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2013-12-13tools: moved code common to all image tools to a separated module.Guilherme Maciel Ferreira
In order to avoid duplicating code and keep only one point of modification, the functions, structs and defines useful for "dumpimage" were moved from "mkimage" to a common module called "imagetool". This modification also weakens the coupling between image types (FIT, IMX, MXS, and so on) and image tools (mkimage and dumpimage). Any tool may initialize the "imagetool" through register_image_tool() function, while the image types register themselves within an image tool using the register_image_type() function: +---------------+ +------| fit_image | +--------------+ +-----------+ | +---------------+ | mkimage |--------> | | <-----+ +--------------+ | | +---------------+ | imagetool | <------------| imximage | +--------------+ | | +---------------+ | dumpimage |--------> | | <-----+ +--------------+ +-----------+ | +---------------+ +------| default_image | +---------------+ register_image_tool() register_image_type() Also, the struct "mkimage_params" was renamed to "image_tool_params" to make clear its general purpose. Signed-off-by: Guilherme Maciel Ferreira <guilherme.maciel.ferreira@gmail.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2013-08-31ARM: mxs: tools: Add mkimage support for MXS bootstreamMarek Vasut
Add mkimage support for generating and verifying MXS bootstream. The implementation here is mostly a glue code between MXSSB v0.4 and mkimage, but the long-term goal is to rectify this and merge MXSSB with mkimage more tightly. Once this code is properly in U-Boot, MXSSB shall be deprecated in favor of mkimage-mxsimage support. Note that the mxsimage generator needs libcrypto from OpenSSL, I therefore enabled the libcrypto/libssl unconditionally. MXSSB: http://git.denx.de/?p=mxssb.git;a=summary The code is based on research presented at: http://www.rockbox.org/wiki/SbFileFormat Signed-off-by: Marek Vasut <marex@denx.de> Cc: Tom Rini <trini@ti.com> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Otavio Salvador <otavio@ossystems.com.br>
2013-08-31tools: add variable padding of data image in mkimageStefano Babic
Use previously unused return value of function vrec_header to return a padding size to generic mkimage. This padding size is used in copy_files to pad with zeros after copying the data image. Signed-off-by: Stefano Babic <sbabic@denx.de>
2013-06-26mkimage: Add -r option to specify keys that must be verifiedSimon Glass
Normally, multiple public keys can be provided and U-Boot is not required to use all of them for verification. This is because some images may not be signed, or may be optionally signed. But we still need a mechanism to determine when a key must be used. This feature cannot be implemented in the FIT itself, since anyone could change it to mark a key as optional. The requirement for key verification must go in with the public keys, in a place that is protected from modification. Add a -r option which tells mkimage to mark all keys that it uses for signing as 'required'. If some keys are optional and some are required, run mkimage several times (perhaps with different key directories if some keys are very secret) using the -F flag to update an existing FIT. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2013-06-26mkimage: Add -c option to specify a comment for key signingSimon Glass
When signing an image, it is useful to add some details about which tool or person is authorising the signing. Add a comment field which can take care of miscellaneous requirements. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2013-06-26mkimage: Add -K to write public keys to an FDT blobSimon Glass
FIT image verification requires public keys. Add a convenient option to mkimage to write the public keys to an FDT blob when it uses then for signing an image. This allows us to use: mkimage -f test.its -K dest.dtb -k keys test.fit and have the signatures written to test.fit and the corresponding public keys written to dest.dtb. Then dest.dtb can be used as the control FDT for U-Boot (CONFIG_OF_CONTROL), thus providing U-Boot with access to the public keys it needs. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2013-06-26mkimage: Add -k option to specify key directorySimon Glass
Keys required for signing images will be in a specific directory. Add a -k option to specify that directory. Also update the mkimage man page with this information and a clearer list of available commands. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de> (v1)
2013-06-04mkimage: Add map_sysmem() and IH_ARCH_DEFAULT to simplfy buildingSimon Glass
These are not actually used in mkimage itself, but the image code (which is common with mkimage) does use them. To avoid #ifdefs in the image code just for mkimage, define dummy version of these here. The compiler will eliminate the dead code anyway. A better way to handle this might be to split out more things from common.h so that mkimage can include them. At present any file that mkimage uses has to be very careful what headers it includes. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-05-14mkimage: Move ARRAY_SIZE to header fileSimon Glass
Move this definition from aisimage.c to mkimage.h so that it is available more widely. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Marek Vasut <marex@denx.de>
2012-08-23powerpc/CoreNet: add tool to support pbl image build.Shaohui Xie
Provides a tool to build boot Image for PBL(Pre boot loader) which is used on Freescale CoreNet SoCs, PBL can be used to load some instructions and/or data for pre-initialization. The default output image is u-boot.pbl, for more details please refer to doc/README.pblimage. Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2011-10-23mkimage: adding support for Davinci AIS imageStefano Babic
Some Davinci processors supports the Application Image Script (AIS) boot process. The patch adds the generation of the AIS image inside the mkimage tool to make possible to generate a bootable U-boot without external tools (TI Davinci AIS Generator). Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Wolfgang Denk <wd@denx.de>
2011-10-05mkimage: Add variable lenght header supportStefano Babic
Some images have not a header of fix lenght. The patch will be used for the generation of AIS images, because this header has a variable lenght. The patch adds also the parameter "-s" (skip) to not copy automatically the passed image file. Signed-off-by: Stefano Babic <sbabic@denx.de>
2011-08-03mkimage: Add OMAP boot image supportJohn Rigby
- Add mkimage support for OMAP boot image - Add support for OMAP boot image(MLO) generation in the new SPL framework Signed-off-by: John Rigby <john.rigby@linaro.org> Signed-off-by: Aneesh V <aneesh@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-07-28mkimage: add UBL header support for booting davinci cpusHeiko Schocher
creating an u-boot.ubl file, which contains the UBL Header needed for booting from NAND with the RBL from TI. For more information read doc/README.ublimage. Signed-off-by: Heiko Schocher <hs@denx.de>
2010-01-25mkimage: Add Freescale imx Boot Image support (imximage)Stefano Babic
This patch adds support for "imximage" (MX Boot Image) to the mkimage utility. The imximage is used on the Freescales's MX.25, MX.35 and MX.51 processors. Further details under doc/README.imximage. This patch was tested on a Freescale mx51evk board. Signed-off-by: Stefano Babic <sbabic@denx.de>
2009-09-10mkimage: Add Kirkwood Boot Image support (kwbimage)Prafulla Wadaskar
This patch adds support for "kwbimage" (Kirkwood Boot Image) image types to the mkimage code. For details refer to docs/README.kwbimage This patch is tested with Sheevaplug board Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com> Acked-by: Ron Lee <ron@debian.org> Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
2009-09-10tools/mkimage: fix compiler warnings, use "const"Wolfgang Denk
This fixes some compiler warnings: tools/default_image.c:141: warning: initialization from incompatible pointer type tools/fit_image.c:202: warning: initialization from incompatible pointer type and changes to code to use "const" attributes in a few places where it's appropriate. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-09-10tools: mkimage: split code into core, default and FIT image specificPrafulla Wadaskar
This is a first step towards reorganizing the mkimage code to make it easier to add support for additional images types. Current mkimage code is specific to generating uImage and FIT image files, but the same framework can be used to generate other image types like Kirkwood boot images (kwbimage-TBD). For this, the mkimage code gets reworked: Here is the brief plan for the same:- a) Split mkimage code into core and image specific support b) Implement callback functions for image specific code c) Move image type specific code to respective C files Currently there are two types of file generation/list supported (i.e uImage, FIT), the code is abstracted from mkimage.c/.h and put in default_image.c and fit_image.c; all code in these file is static except init function call d) mkimage_register API is added to add new image type support All above is addressed in this patch e) Add kwbimage type support to this new framework (TBD) This will be implemented in a following commit. Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com> Edit commit message, fix coding style and typos. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-09-04License cleanup: remove unintended "All Rights Reserved" notices.Wolfgang Denk
Some files included my old standerd file header which had a "All Rights Reserved" part. As this has never been my intention, I remove these lines to make the files compatible with GPL v.2 and later. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-07-19compiler.h: unify system ifdef cruft hereMike Frysinger
Shove a lot of the HOSTCC and related #ifdef checking crap into the new compiler.h header so that we can keep all other headers nice and clean. Also introduce custom uswap functions so we don't have to rely on the non standard implementations that a host may (or may not in the case of OS X) provide. This allows mkimage to finally build cleanly on an OS X system. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-04-04Add support for building native win32 toolsPeter Tyser
Add support for compiling the host tools in the tools directory using the MinGW toolchain. This produces executables which can be used on standard Windows computers without requiring cygwin. One must specify the MinGW compiler and strip utilities as if they were the host toolchain in order to build win32 executables, eg: make HOSTCC=i586-mingw32msvc-gcc HOSTSTRIP=i586-mingw32msvc-strip tools Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2008-03-11[new uImage] Add support for new uImage format to mkimage toolBartlomiej Sieka
Support for the new uImage format (FIT) is added to mkimage tool. Commandline syntax is appropriately extended: mkimage [-D dtc_options] -f fit-image.its fit-image mkimage (together with dtc) takes fit-image.its and referenced therein binaries (like vmlinux.bin.gz) as inputs, and produces fit-image file -- the final image that can be transferred to the target (e.g., via tftp) and then booted using the bootm command in U-Boot. Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
2008-03-10[new uImage] New uImage low-level APIMarian Balakowicz
Add FDT-based functions for handling new format component images, configurations, node operations, property get/set, etc. fit_ - routines handling global new format uImage operations like get/set top level property, process all nodes, etc. fit_image_ - routines handling component images subnodes fit_conf_ - routines handling configurations node Signed-off-by: Bartlomiej Sieka <tur@semihalf.com> Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-02-29[new uImage] Add libfdt support to mkimageBartlomiej Sieka
2008-02-29[new uImage] Add sha1.o object to mkimage binary buildBartlomiej Sieka
2008-02-07[new uImage] Define a API for image handling operationsMarian Balakowicz
- Add inline helper macros for basic header processing - Move common non inline code common/image.c - Replace direct header access with the API routines - Rename IH_CPU_* to IH_ARCH_* Signed-off-by: Marian Balakowicz <m8@semihalf.com>
