Some Davinci processors supports the Application
Image Script (AIS) boot process. The patch adds the generation
of the AIS image inside the mkimage tool to make possible
to generate a bootable U-boot without external tools
(TI Davinci AIS Generator).
CC: Wolfgang Denk <wd@denx.de>
Some images have not a header of fix lenght. The patch will be
used for the generation of AIS images, because this header has
a variable lenght. The patch adds also the parameter "-s" (skip)
to not copy automatically the passed image file.
- Add mkimage support for OMAP boot image
- Add support for OMAP boot image(MLO) generation in the new
SPL framework
Signed-off-by: John Rigby <john.rigby@linaro.org>
Signed-off-by: Aneesh V <aneesh@ti.com>
Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
creating an u-boot.ubl file, which contains the UBL Header
needed for booting from NAND with the RBL from TI. For more
information read doc/README.ublimage.
This patch adds support for "imximage" (MX Boot Image)
to the mkimage utility. The imximage is used on the Freescales's
MX.25, MX.35 and MX.51 processors.
Further details under doc/README.imximage.
This patch was tested on a Freescale mx51evk board.
This patch adds support for "kwbimage" (Kirkwood Boot Image)
image types to the mkimage code.
For details refer to docs/README.kwbimage
This patch is tested with Sheevaplug board
Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
Acked-by: Ron Lee <ron@debian.org>
This fixes some compiler warnings:
tools/default_image.c:141: warning: initialization from incompatible pointer type
tools/fit_image.c:202: warning: initialization from incompatible pointer type
and changes to code to use "const" attributes in a few places where
it's appropriate.
This is a first step towards reorganizing the mkimage code to make it
easier to add support for additional images types. Current mkimage
code is specific to generating uImage and FIT image files, but the
same framework can be used to generate other image types like
Kirkwood boot images (kwbimage-TBD). For this, the mkimage code gets
reworked:
Here is the brief plan for the same:-
a) Split mkimage code into core and image specific support
b) Implement callback functions for image specific code
c) Move image type specific code to respective C files
Currently there are two types of file generation/list
supported (i.e uImage, FIT), the code is abstracted from
mkimage.c/.h and put in default_image.c and fit_image.c;
all code in these file is static except init function call
d) mkimage_register API is added to add new image type support
All above is addressed in this patch
e) Add kwbimage type support to this new framework (TBD)
This will be implemented in a following commit.
Edit commit message, fix coding style and typos.
Some files included my old standerd file header which had a "All
Rights Reserved" part. As this has never been my intention, I remove
these lines to make the files compatible with GPL v.2 and later.
Shove a lot of the HOSTCC and related #ifdef checking crap into the new
compiler.h header so that we can keep all other headers nice and clean.
Also introduce custom uswap functions so we don't have to rely on the non
standard implementations that a host may (or may not in the case of OS X)
provide. This allows mkimage to finally build cleanly on an OS X system.
Add support for compiling the host tools in the tools directory using
the MinGW toolchain. This produces executables which can be used on
standard Windows computers without requiring cygwin.
One must specify the MinGW compiler and strip utilities as if they
were the host toolchain in order to build win32 executables, eg:
make HOSTCC=i586-mingw32msvc-gcc HOSTSTRIP=i586-mingw32msvc-strip tools
Support for the new uImage format (FIT) is added to mkimage tool.
Commandline syntax is appropriately extended:
mkimage [-D dtc_options] -f fit-image.its fit-image
mkimage (together with dtc) takes fit-image.its and referenced therein
binaries (like vmlinux.bin.gz) as inputs, and produces fit-image file -- the
final image that can be transferred to the target (e.g., via tftp) and then
booted using the bootm command in U-Boot.
Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
Add FDT-based functions for handling new format component images,
configurations, node operations, property get/set, etc.
fit_ - routines handling global new format uImage operations
like get/set top level property, process all nodes, etc.
fit_image_ - routines handling component images subnodes
fit_conf_ - routines handling configurations node
Signed-off-by: Marian Balakowicz <m8@semihalf.com>
- Add inline helper macros for basic header processing
- Move common non inline code common/image.c
- Replace direct header access with the API routines
- Rename IH_CPU_* to IH_ARCH_*
