path: root/tools/mkimage.c
2005-04-03* Patch by Scott McNutt, 01 Nov 2004:wdenk
Add missing NIOS/NIOS2 support for "iminfo" command * Patch by Detlev Zundel, 29 Oct 2004: Add missing NIOS/NIOS2 support for "mkimage" tool.
2004-11-21* Update for AT91RM9200DK and CMC_PU2 boards:wdenk
- Enable booting directly from flash - fix CMC_PU2 flash driver * Fix mkimage usage message
2004-07-10* Rename SBC8560 into sbc8560 for consistencywdenk
* Patch by Daniel Poirot, 24 Jun 2004: Add support for Wind River's sbc8240 board * Patches by Yasushi Shoji, 26 Jun 2004: - drivers/serial_xuartlite.c: fix "return 0" in void function - add microblaze support to mkimage tool
2004-02-26* Patch by Rahul Shanbhag, 19 Feb 2004:wdenk
Fixes for for OMAP1610 board: - shift some IRQ specific code to platform.S file - remove duplicatewatchdog reset code from start.S * Make Auto-MDIX Support configurable on INCA-IP board * Fix license for mkimage tool
2003-11-17* Use "-fPIC" instead of "-mrelocatable" to prevent problems withwdenk
recent tools * Add checksum verification to 'imls' command * Add bd_info fields needed for 4xx Linux I2C driver * Patch by Martin Krause, 4 Nov. 2003: Fix error in cmd_vfd.c (TRAB board: "vfd /1" shows now only one Bitmap) * Print used network interface when CONFIG_NET_MULTI is set
2003-10-08* Patch by Anders Larsen, 18 Sep 2003:wdenk
allow mkimage to build and run on Cygwin-hosted systems * Patch by Frank Müller, 18 Sep 2003: use bi_intfreq instead of bi_busfreq to compute fec_mii_speed in cpu/mpc8xx/fec.c * Patch by Pantelis Antoniou, 16 Sep 2003: add tool to compute fileds in the PLPRCR register for MPC86x
2003-10-07Fix build problems under FreeBSDwdenk
2003-10-06Add generic filesystem image typewdenk
2003-09-16Make IPB clock on MGT5100/MPC5200 configurable in board config file;wdenk
go back to 66 MHz for stability
2003-08-05* Map ISP1362 USB OTG controller for NSCU boardwdenk
* Patch by Brad Parker, 02 Aug 2003: fix sc520_cdp problems * Implement Boot Cycle Detection (Req. 2.3 of OSDL CGL Reqirements) * Allow erase command to cross flash bank boundaries
2003-07-14* Patches by Yuli Barcohen, 13 Jul 2003:wdenk
- Correct flash and JFFS2 support for MPC8260ADS - fix PVR values and clock generation for PowerQUICC II family (8270/8275/8280) * Patch by Bernhard Kuhn, 08 Jul 2003: - add support for M68K targets * Patch by Ken Chou, 3 Jul: - Fix PCI config table for A3000 - Fix iobase for natsemi.c (PCI_BASE_ADDRESS_0 is the IO base register for DP83815) * Allow to enable "slow" POST routines by key press on power-on * Fix temperature dependend switching of LCD backlight on LWMON * Tweak output format for LWMON
2003-05-20* Patch by David Updegraff, 22 Apr 2003:LABEL_2003_05_20_1630wdenk
update for CrayL1 board * Patch by Pantelis Antoniou, 21 Apr 2003: add boot support for ARTOS (a proprietary OS) * Patch by Steven Scholz, 11 Apr 2003: Add support for RTC DS1338 * Patch by Rod Boyce, 24 Jan 2003: Fix counting of extended partitions in diskboot command
2003-04-20* Make sure Block Lock Bits get cleared in R360MPI flash driverwdenk
* MPC823 LCD driver: Fill color map backwards, to allow for steady display when Linux takes over * Patch by Erwin Rol, 27 Feb 2003: Add support for RTEMS (this time for real). * Add support for "bmp info" and "bmp display" commands to load bitmap images; this can be used (for example in a "preboot" command) to display a splash screen very quickly after poweron. * Add support for 133 MHz clock on INCA-IP board
2002-12-03* Fix startup problems with VFD display on TRABLABEL_2002_12_03_2230wdenk
* Patch by Pierre Aubert, 20 Nov 2002 Add driver for Epson SED13806 graphic controller. Add support for BMP logos in cfb_console driver.
