As suggested by Wolfgang Denk:
- image printing functions:
- remove wrappers
- remove indentation prefix from functions' signatures
- merge getenv_verify and getenv_autostart into one parametrized function
Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
Support for the new uImage format (FIT) is added to mkimage tool.
Commandline syntax is appropriately extended:
mkimage [-D dtc_options] -f fit-image.its fit-image
mkimage (together with dtc) takes fit-image.its and referenced therein
binaries (like vmlinux.bin.gz) as inputs, and produces fit-image file -- the
final image that can be transferred to the target (e.g., via tftp) and then
booted using the bootm command in U-Boot.
This patch adds the following common routines:
1) Dedicated mkimage print_header() is replaced with common
image_print_contents()
image_print_contents_noindent()
2) Common os/arch/type/comp fields name <--> id translation routines
genimg_get_os_name()
genimg_get_arch_name()
genimg_get_type_name()
genimg_get_comp_name()
genimg_get_os_id()
genimg_get_arch_id()
genimg_get_type_id()
genimg_get_comp_id()
Signed-off-by: Marian Balakowicz <m8@semihalf.com>
This patch introduces the following prefix convention for the
image format handling and bootm related code:
genimg_ - dual format shared code
image_ - legacy uImage format specific code
fit_ - new uImage format specific code
boot_ - booting process related code
Related routines are renamed and a few pieces of code are moved around and
re-grouped.
- Add inline helper macros for basic header processing
- Move common non inline code common/image.c
- Replace direct header access with the API routines
- Rename IH_CPU_* to IH_ARCH_*
Singed-off-by: Marc Hoffman <Marc.Hoffman@analog.com>
Signed-off-by: Aubrey Li <aubrey.adi@gmail.com>
Make it possible to generate AVR32 uImage files with mkimage and
make cmd_bootm recognize them.
Patch by Haavard Skinnemoen, 22 Sep 2006
Patch by David Updegraff, 06 Sep 2006
Signed-off-by: Matthew McClintock <msm@freescale.com>
- add support for Analog Devices Blackfin BF533 CPU
- add support for the ADI BF533 Stamp uClinux board
- add support for the ADI BF533 EZKit board
Patches by Richard Klingler, June 11th 2005:
Add missing NIOS/NIOS2 support for "iminfo" command
* Patch by Detlev Zundel, 29 Oct 2004:
Add missing NIOS/NIOS2 support for "mkimage" tool.
- Enable booting directly from flash
- fix CMC_PU2 flash driver
* Fix mkimage usage message
* Patch by Daniel Poirot, 24 Jun 2004:
Add support for Wind River's sbc8240 board
* Patches by Yasushi Shoji, 26 Jun 2004:
- drivers/serial_xuartlite.c: fix "return 0" in void function
- add microblaze support to mkimage tool
Fixes for for OMAP1610 board:
- shift some IRQ specific code to platform.S file
- remove duplicatewatchdog reset code from start.S
* Make Auto-MDIX Support configurable on INCA-IP board
* Fix license for mkimage tool
recent tools
* Add checksum verification to 'imls' command
* Add bd_info fields needed for 4xx Linux I2C driver
* Patch by Martin Krause, 4 Nov. 2003:
Fix error in cmd_vfd.c (TRAB board: "vfd /1" shows now only one Bitmap)
* Print used network interface when CONFIG_NET_MULTI is set
allow mkimage to build and run on Cygwin-hosted systems
* Patch by Frank Müller, 18 Sep 2003:
use bi_intfreq instead of bi_busfreq to compute fec_mii_speed in
cpu/mpc8xx/fec.c
* Patch by Pantelis Antoniou, 16 Sep 2003:
add tool to compute fileds in the PLPRCR register for MPC86x
go back to 66 MHz for stability
* Patch by Brad Parker, 02 Aug 2003:
fix sc520_cdp problems
* Implement Boot Cycle Detection (Req. 2.3 of OSDL CGL Reqirements)
* Allow erase command to cross flash bank boundaries
- Correct flash and JFFS2 support for MPC8260ADS
- fix PVR values and clock generation for PowerQUICC II family
(8270/8275/8280)
* Patch by Bernhard Kuhn, 08 Jul 2003:
- add support for M68K targets
* Patch by Ken Chou, 3 Jul:
- Fix PCI config table for A3000
- Fix iobase for natsemi.c
(PCI_BASE_ADDRESS_0 is the IO base register for DP83815)
* Allow to enable "slow" POST routines by key press on power-on
* Fix temperature dependend switching of LCD backlight on LWMON
* Tweak output format for LWMON
update for CrayL1 board
* Patch by Pantelis Antoniou, 21 Apr 2003:
add boot support for ARTOS (a proprietary OS)
* Patch by Steven Scholz, 11 Apr 2003:
Add support for RTC DS1338
* Patch by Rod Boyce, 24 Jan 2003:
Fix counting of extended partitions in diskboot command
* MPC823 LCD driver: Fill color map backwards, to allow for steady
display when Linux takes over
* Patch by Erwin Rol, 27 Feb 2003:
Add support for RTEMS (this time for real).
* Add support for "bmp info" and "bmp display" commands to load
bitmap images; this can be used (for example in a "preboot"
command) to display a splash screen very quickly after poweron.
* Add support for 133 MHz clock on INCA-IP board
* Patch by Pierre Aubert, 20 Nov 2002
Add driver for Epson SED13806 graphic controller.
Add support for BMP logos in cfb_console driver.
