path: root/tools/mkimage.c
2015-01-29dumpimage: add 'T' option to explicitly set the image typeGuilherme Maciel Ferreira
Some image types, like "KeyStone GP", do not have magic numbers to distinguish them from other image types. Thus, the automatic image type discovery does not work correctly. This patch also fix some integer type mismatches. Signed-off-by: Guilherme Maciel Ferreira <guilherme.maciel.ferreira@gmail.com>
2015-01-29imagetool: replace image registration function by linker_lists featureGuilherme Maciel Ferreira
The registration was introduced in commit f86ed6a8d52c99bb2d17d3cac1647edca0c4399c This commit also removes all registration functions, and the member "next" from image_type_params struct Signed-off-by: Guilherme Maciel Ferreira <guilherme.maciel.ferreira@gmail.com>
2015-01-29imagetool: move common code to imagetool moduleGuilherme Maciel Ferreira
The get_type() and verify_print_header() functions have the same code on both dumpimage.c and mkimage.c modules. Signed-off-by: Guilherme Maciel Ferreira <guilherme.maciel.ferreira@gmail.com>
2014-08-14mkimage: fix compilation issues on OpenBSDLuka Perkov
Signed-off-by: Luka Perkov <luka@openwrt.org>
2013-12-13tools: moved code common to all image tools to a separated module.Guilherme Maciel Ferreira
In order to avoid duplicating code and keep only one point of modification, the functions, structs and defines useful for "dumpimage" were moved from "mkimage" to a common module called "imagetool". This modification also weakens the coupling between image types (FIT, IMX, MXS, and so on) and image tools (mkimage and dumpimage). Any tool may initialize the "imagetool" through register_image_tool() function, while the image types register themselves within an image tool using the register_image_type() function: +---------------+ +------| fit_image | +--------------+ +-----------+ | +---------------+ | mkimage |--------> | | <-----+ +--------------+ | | +---------------+ | imagetool | <------------| imximage | +--------------+ | | +---------------+ | dumpimage |--------> | | <-----+ +--------------+ +-----------+ | +---------------+ +------| default_image | +---------------+ register_image_tool() register_image_type() Also, the struct "mkimage_params" was renamed to "image_tool_params" to make clear its general purpose. Signed-off-by: Guilherme Maciel Ferreira <guilherme.maciel.ferreira@gmail.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2013-12-13mkimage: added 'static' specifier to match function's prototype.Guilherme Maciel Ferreira
This function should be declared static. Signed-off-by: Guilherme Maciel Ferreira <guilherme.maciel.ferreira@gmail.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2013-08-31ARM: mxs: tools: Add mkimage support for MXS bootstreamMarek Vasut
Add mkimage support for generating and verifying MXS bootstream. The implementation here is mostly a glue code between MXSSB v0.4 and mkimage, but the long-term goal is to rectify this and merge MXSSB with mkimage more tightly. Once this code is properly in U-Boot, MXSSB shall be deprecated in favor of mkimage-mxsimage support. Note that the mxsimage generator needs libcrypto from OpenSSL, I therefore enabled the libcrypto/libssl unconditionally. MXSSB: http://git.denx.de/?p=mxssb.git;a=summary The code is based on research presented at: http://www.rockbox.org/wiki/SbFileFormat Signed-off-by: Marek Vasut <marex@denx.de> Cc: Tom Rini <trini@ti.com> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Otavio Salvador <otavio@ossystems.com.br>
2013-08-31tools: add variable padding of data image in mkimageStefano Babic
Use previously unused return value of function vrec_header to return a padding size to generic mkimage. This padding size is used in copy_files to pad with zeros after copying the data image. Signed-off-by: Stefano Babic <sbabic@denx.de>
2013-06-26mkimage: Add -r option to specify keys that must be verifiedSimon Glass
Normally, multiple public keys can be provided and U-Boot is not required to use all of them for verification. This is because some images may not be signed, or may be optionally signed. But we still need a mechanism to determine when a key must be used. This feature cannot be implemented in the FIT itself, since anyone could change it to mark a key as optional. The requirement for key verification must go in with the public keys, in a place that is protected from modification. Add a -r option which tells mkimage to mark all keys that it uses for signing as 'required'. If some keys are optional and some are required, run mkimage several times (perhaps with different key directories if some keys are very secret) using the -F flag to update an existing FIT. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2013-06-26mkimage: Add -c option to specify a comment for key signingSimon Glass
When signing an image, it is useful to add some details about which tool or person is authorising the signing. Add a comment field which can take care of miscellaneous requirements. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2013-06-26mkimage: Add -F option to modify an existing .fit fileSimon Glass
When signing images it is sometimes necessary to sign with different keys at different times, or make the signer entirely separate from the FIT creation to avoid needing the private keys to be publicly available in the system. Add a -F option so that key signing can be a separate step, and possibly done multiple times as different keys are avaiable. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2013-06-26mkimage: Add -K to write public keys to an FDT blobSimon Glass
FIT image verification requires public keys. Add a convenient option to mkimage to write the public keys to an FDT blob when it uses then for signing an image. This allows us to use: mkimage -f test.its -K dest.dtb -k keys test.fit and have the signatures written to test.fit and the corresponding public keys written to dest.dtb. Then dest.dtb can be used as the control FDT for U-Boot (CONFIG_OF_CONTROL), thus providing U-Boot with access to the public keys it needs. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2013-06-26mkimage: Add -k option to specify key directorySimon Glass
Keys required for signing images will be in a specific directory. Add a -k option to specify that directory. Also update the mkimage man page with this information and a clearer list of available commands. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de> (v1)
2012-08-23powerpc/CoreNet: add tool to support pbl image build.Shaohui Xie
Provides a tool to build boot Image for PBL(Pre boot loader) which is used on Freescale CoreNet SoCs, PBL can be used to load some instructions and/or data for pre-initialization. The default output image is u-boot.pbl, for more details please refer to doc/README.pblimage. Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2011-12-24mkimage: Fix variable length header supportChristian Riesch
Support for variable length images like AIS image was introduced in commit f0662105b674a3874227316abf8536bebc9b5995. A parameter "-s" was also introduced to prohibit copying of the image file automatically in the main program. However, this parameter was implemented incorrectly and the image file was copied nevertheless. Signed-off-by: Christian Riesch <christian.riesch@omicron.at> Cc: Stefano Babic <sbabic@denx.de> Cc: Heiko Schocher <hs@denx.de> Acked-by: Stefano Babic <sbabic@denx.de>
2011-10-23mkimage: adding support for Davinci AIS imageStefano Babic
Some Davinci processors supports the Application Image Script (AIS) boot process. The patch adds the generation of the AIS image inside the mkimage tool to make possible to generate a bootable U-boot without external tools (TI Davinci AIS Generator). Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Wolfgang Denk <wd@denx.de>
2011-10-05mkimage: Add variable lenght header supportStefano Babic
Some images have not a header of fix lenght. The patch will be used for the generation of AIS images, because this header has a variable lenght. The patch adds also the parameter "-s" (skip) to not copy automatically the passed image file. Signed-off-by: Stefano Babic <sbabic@denx.de>
2011-08-03mkimage: Add OMAP boot image supportJohn Rigby
- Add mkimage support for OMAP boot image - Add support for OMAP boot image(MLO) generation in the new SPL framework Signed-off-by: John Rigby <john.rigby@linaro.org> Signed-off-by: Aneesh V <aneesh@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-07-28mkimage: add UBL header support for booting davinci cpusHeiko Schocher
creating an u-boot.ubl file, which contains the UBL Header needed for booting from NAND with the RBL from TI. For more information read doc/README.ublimage. Signed-off-by: Heiko Schocher <hs@denx.de>
2011-04-12mkimage: add "-V" option to print version informationWolfgang Denk
2010-04-10mkimage: Fix strict-aliasing compiler warningPeter Tyser
Version 4.2.4 of gcc produces the following warnings without this change: mkimage.c: In function ‘main’: mkimage.c:204: warning: dereferencing type-punned pointer will break strict-aliasing rules mkimage.c:222: warning: dereferencing type-punned pointer will break strict-aliasing rules Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-03-28mkimage: fix Segmentation Fault when run without "-n name" optionWolfgang Denk
The restructuring of the mkimage command in commit 89a4d6b1 ("tools: mkimage: split code into core, default and FIT image specific") introduced a bug that caused mkimage to segfault when run without "-n name" option. Initialize the imagename entry to prevent that. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-03-11mkimage: dont force entry point with xipMike Frysinger
Some people boot images with the entry point in the middle of the blob (like Linux with the head code in discardable .init.text), and there is no no real requirement that the entry point be right after the mkimage header when doing XIP, so let people specify whatever they want. If they do need an entry right after the header, then they still can do that with normal -e behavior. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-01-25mkimage: Add Freescale imx Boot Image support (imximage)Stefano Babic
This patch adds support for "imximage" (MX Boot Image) to the mkimage utility. The imximage is used on the Freescales's MX.25, MX.35 and MX.51 processors. Further details under doc/README.imximage. This patch was tested on a Freescale mx51evk board. Signed-off-by: Stefano Babic <sbabic@denx.de>
2009-12-07tools/mkimage: Remove duplicate line of codePeter Tyser
Recent commits 1a99de2cb4d08eb3bf9fb3f60a9d533150de8c0e and 6a590c5f5fd12cdd27f3153522acfac3854590e7 both fixed the same bug in the same manner. Unfortunately git was "smart" enough to merge both changes which resulted in some duplicate code. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Reordered code and comment a bit. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-12-05tools/mkimage: Print FIT image contents after creationPeter Tyser
Previously, there was no indication to the user that a FIT image was successfully created after executing mkimage. For example: $ mkimage -f uImage.its uImage.itb DTC: dts->dtb on file "uImage.its" Adding some additional output after creating a FIT image lets the user know exactly what is contained in their image, eg: $ mkimage -f uImage.its uImage.itb DTC: dts->dtb on file "uImage.its" FIT description: Linux kernel 2.6.32-rc7-00201-g7550d6f-dirty Created: Tue Nov 24 15:43:01 2009 Image 0 (kernel@1) Description: Linux Kernel 2.6.32-rc7-00201-g7550d6f-dirty Type: Kernel Image Compression: gzip compressed Data Size: 2707311 Bytes = 2643.86 kB = 2.58 MB Architecture: PowerPC OS: Linux Load Address: 0x00000000 Entry Point: 0x00000000 Hash algo: crc32 Hash value: efe0798b Hash algo: sha1 Hash value: ecafba8c95684f2c8fec67e33c41ec88df1534d7 Image 1 (fdt@1) Description: Flattened Device Tree blob Type: Flat Device Tree Compression: uncompressed Data Size: 12288 Bytes = 12.00 kB = 0.01 MB Architecture: PowerPC Hash algo: crc32 Hash value: a5cab676 Hash algo: sha1 Hash value: 168722b13e305283cfd6603dfe8248cc329adea6 Default Configuration: 'config@1' Configuration 0 (config@1) Description: Default Linux kernel Kernel: kernel@1 FDT: fdt@1 This brings the behavior of creating a FIT image in line with creating a standard uImage, which also prints out the uImage contents after creation. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-12-05tools/mkimage: Assume FDT image type for FIT imagesPeter Tyser
When building a Flattened Image Tree (FIT) the image type needs to be "flat_dt". Commit 89a4d6b12fd6394898b8a454cbabeaf1cd59bae5 introduced a regression which caused the user to need to specify the "-T flat_dt" parameter on the command line when building a FIT image. The "-T flat_dt" parameter should not be needed and is at odds with the current FIT image documentation. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-11-23Building of FIT images does not work.Remy Bohmer
The type is not set for generation of the FIT images, resulting in no images being created without printing or returning an error Signed-off-by: Remy Bohmer <linux@bohmer.net>
2009-09-10mkimage: Add Kirkwood Boot Image support (kwbimage)Prafulla Wadaskar
This patch adds support for "kwbimage" (Kirkwood Boot Image) image types to the mkimage code. For details refer to docs/README.kwbimage This patch is tested with Sheevaplug board Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com> Acked-by: Ron Lee <ron@debian.org> Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
2009-09-10tools: mkimage: split code into core, default and FIT image specificPrafulla Wadaskar
This is a first step towards reorganizing the mkimage code to make it easier to add support for additional images types. Current mkimage code is specific to generating uImage and FIT image files, but the same framework can be used to generate other image types like Kirkwood boot images (kwbimage-TBD). For this, the mkimage code gets reworked: Here is the brief plan for the same:- a) Split mkimage code into core and image specific support b) Implement callback functions for image specific code c) Move image type specific code to respective C files Currently there are two types of file generation/list supported (i.e uImage, FIT), the code is abstracted from mkimage.c/.h and put in default_image.c and fit_image.c; all code in these file is static except init function call d) mkimage_register API is added to add new image type support All above is addressed in this patch e) Add kwbimage type support to this new framework (TBD) This will be implemented in a following commit. Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com> Edit commit message, fix coding style and typos. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-09-10tools: mkimage: Fixed build warningsPrafulla Wadaskar
uninitialized retval variable warning fixed crc32 APIs moved to crc.h (newly added) and build warnings fixed Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-09-10tools: mkimage : bugfix returns correct value for list commandPrafulla Wadaskar
List command always return "EXIT_SUCCESS" even in case of failure by any means. This patch return 0 if list command is sucessful, returns negative value reported by check_header functions Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-09-04License cleanup: remove unintended "All Rights Reserved" notices.Wolfgang Denk
Some files included my old standerd file header which had a "All Rights Reserved" part. As this has never been my intention, I remove these lines to make the files compatible with GPL v.2 and later. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-07-19compiler.h: unify system ifdef cruft hereMike Frysinger
Shove a lot of the HOSTCC and related #ifdef checking crap into the new compiler.h header so that we can keep all other headers nice and clean. Also introduce custom uswap functions so we don't have to rely on the non standard implementations that a host may (or may not in the case of OS X) provide. This allows mkimage to finally build cleanly on an OS X system. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-05-03mkimage: make mmap() checks consistentMike Frysinger
The mmap() related code is full of inconsistent casts/constants when it comes to error checking, and may break when building on some systems (like ones that do not implicitly define the caddr_t type). Let's just avoid the whole mess by writing the code nice and clean in the first place. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-04-24Memory footprint optimizationsBartlomiej Sieka
As suggested by Wolfgang Denk: - image printing functions: - remove wrappers - remove indentation prefix from functions' signatures - merge getenv_verify and getenv_autostart into one parametrized function Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
2008-03-11[new uImage] Add support for new uImage format to mkimage toolBartlomiej Sieka
Support for the new uImage format (FIT) is added to mkimage tool. Commandline syntax is appropriately extended: mkimage [-D dtc_options] -f fit-image.its fit-image mkimage (together with dtc) takes fit-image.its and referenced therein binaries (like vmlinux.bin.gz) as inputs, and produces fit-image file -- the final image that can be transferred to the target (e.g., via tftp) and then booted using the bootm command in U-Boot. Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
2008-02-29[new uImage] Share common uImage code between mkimage and U-bootMarian Balakowicz
This patch adds the following common routines: 1) Dedicated mkimage print_header() is replaced with common image_print_contents() image_print_contents_noindent() 2) Common os/arch/type/comp fields name <--> id translation routines genimg_get_os_name() genimg_get_arch_name() genimg_get_type_name() genimg_get_comp_name() genimg_get_os_id() genimg_get_arch_id() genimg_get_type_id() genimg_get_comp_id() Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-02-29[new uImage] Update naming convention for bootm/uImage related codeMarian Balakowicz
This patch introduces the following prefix convention for the image format handling and bootm related code: genimg_ - dual format shared code image_ - legacy uImage format specific code fit_ - new uImage format specific code boot_ - booting process related code Related routines are renamed and a few pieces of code are moved around and re-grouped. Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-02-07[new uImage] Define a API for image handling operationsMarian Balakowicz
- Add inline helper macros for basic header processing - Move common non inline code common/image.c - Replace direct header access with the API routines - Rename IH_CPU_* to IH_ARCH_* Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2007-05-15Fix compilation issues on MACOSXAubrey.Li
Singed-off-by: Marc Hoffman <Marc.Hoffman@analog.com> Signed-off-by: Aubrey Li <aubrey.adi@gmail.com>
2006-10-11Merge with /home/wd/git/u-boot/masterWolfgang Denk
2006-10-09Define IH_CPU_AVR32Stefan Roese
Make it possible to generate AVR32 uImage files with mkimage and make cmd_bootm recognize them. Patch by Haavard Skinnemoen, 22 Sep 2006
2006-09-06Fix mkimage -l bug with multifile images on 64bit platformsWolfgang Denk
Patch by David Updegraff, 06 Sep 2006
2006-08-16* Support for FDT in uImage format, error when using FDT from flashMatthew McClintock
Signed-off-by: Matthew McClintock <msm@freescale.com>
2006-04-28Fixed handling of bad checksums with "mkimage -l"Wolfgang Denk
2006-03-12Add ADI Blackfin supportWolfgang Denk
- add support for Analog Devices Blackfin BF533 CPU - add support for the ADI BF533 Stamp uClinux board - add support for the ADI BF533 EZKit board Patches by Richard Klingler, June 11th 2005:
2006-01-11Fix mkimage bug with multifile images created on 64 bit systems.Wolfgang Denk
2005-04-03* Patch by Scott McNutt, 01 Nov 2004:wdenk
Add missing NIOS/NIOS2 support for "iminfo" command * Patch by Detlev Zundel, 29 Oct 2004: Add missing NIOS/NIOS2 support for "mkimage" tool.
