Bitmap files should not be executable.
Reviewed-by: Michael Trimarchi <michael@amarulasolutions.com>
Add the TechNexion's logo from their internal U-Boot tree.
Signed-off-by: Fabio Estevam <festevam@gmail.com>
Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
When generating the Sphinx documentation with command 'make htmldocs' the
U-Boot logo is displayed with a black box as a background.
Remove the black box.
Provide a logo showing a submarine.
U-Boot currently lacks an icon identifying the project.
The German word U-Boot translates to submarine.
In order to display the company's logo via the API of DM_VIDEO,
and add the logo files of both Atmel and Microchip.
Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com>
Add custom splashscreen, engicam.bmp support for
Engicam i.CoreM6 qdl board.
Cc: Matteo Lisi <matteo.lisi@engicam.com>
Cc: Michael Trimarchi <michael@amarulasolutions.com>
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
Signed-off-by: Tim Harvey <tharvey@gateworks.com>
Add a test for the 'bmp' command. Test both the uncompressed and compressed
versions of the file, since they use different code paths.
Acked-by: Anatolij Gustschin <agust@denx.de>
Use the boot loader splash screen from WinCE which matches our
wallpapers position wise. Although the logo is an 8-bit indexed BMP as
well colours looked odd at first in U-Boot. After converting to full
RGB palette and converting back to an indexed BMP using imagemagick
the Logo showed up properly.
$ convert tools/logos/toradex-rgb.bmp -type Palette -colors 256 \
-compress none -verbose BMP3:tools/logos/toradex.bmp
Let Solidrun's logo appear on Cuboxi and Hummingboard by default.
Signed-off-by: Rabeeh Khoury <rabeeh@solid-run.com>
Add compulab logo and display it on boot.
Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
Cc: Igor Grinberg <grinberg@compulab.co.il>
Signed-off-by: Thomas Diener <dietho@gmx.de>
add support for the am335x based boards from siemens:
dxr2:
- DDR3 128MiB
- NAND 256MiB
- Ethernet with external Switch SMSC LAN9303
- no PMIC
- internal Watchdog
- DFU support
pxm2:
- DDR2 512 MiB
- NAND 1024 MiB
- PMIC
- PHY atheros ar803x
- USB Host
- internal Watchdog
- DFU support
rut:
- DDR3 256 MiB
- NAND 256 MiB
- PMIC
- PHY natsemi dp83630
- external Watchdog
- DFU support
Signed-off-by: Roger Meier <r.meier@siemens.com>
Signed-off-by: Samuel Egli <samuel.egli@siemens.com>
Cc: Pascal Bach <pascal.bach@siemens.com>
Cc: Tom Rini <trini@ti.com>
Atmel change to new logo since 2012. This patch update the logo to new one.
Signed-off-by: Josh Wu <josh.wu@atmel.com>
Add the Freescale logo and update the Makefile to build it when building
a Freescale board.
This patch adds support for the jadecpu board using the
MB86R01 'Jade' SoC from Fujitsu.
Signed-off-by: Matthias Weisser <weisserm@arcor.de>
This patch adds support for esd gmbh OTC570 board.
The OTC570 is based on an Atmel AT91SAM9263 SoC.
Signed-off-by: Daniel Gorsulowski <Daniel.Gorsulowski@esd.eu>
The PM9263 board is based on the AT91SAM9263-EK board.
Here is the page on Ronetix website:
http://www.ronetix.at/starter_kit_9263.html
Signed-off-by: Ilko Iliev <iliev@ronetix.at>
Signed-off-by: Gary Jennejohn <garyj@denx.de>
This patch adds a custom vendor logo for the Atmel AT91 boards.
Signed-off-by: Stelian Pop <stelian@popies.net>
