path: root/tools/logos
2016-09-06imx: ventana: enable splashscreen supportTim Harvey
Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2016-01-20dm: video: test: Test that bitmap display works correctlySimon Glass
Add a test for the 'bmp' command. Test both the uncompressed and compressed versions of the file, since they use different code paths. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de>
2015-08-13logos: add Toradex logoStefan Agner
Use the boot loader splash screen from WinCE which matches our wallpapers position wise. Although the logo is an 8-bit indexed BMP as well colours looked odd at first in U-Boot. After converting to full RGB palette and converting back to an indexed BMP using imagemagick the Logo showed up properly. $ convert tools/logos/toradex-rgb.bmp -type Palette -colors 256 \ -compress none -verbose BMP3:tools/logos/toradex.bmp Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2015-05-15logos: Add Solidrun's logoFabio Estevam
Let Solidrun's logo appear on Cuboxi and Hummingboard by default. Signed-off-by: Rabeeh Khoury <rabeeh@solid-run.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-01-29arm: mx6: cm-fx6: display compulab logoNikita Kiryanov
Add compulab logo and display it on boot. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Cc: Stefano Babic <sbabic@denx.de> Cc: Igor Grinberg <grinberg@compulab.co.il> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2014-05-05logos: Update of the syteco company logoThomas Diener
Signed-off-by: Thomas Diener <dietho@gmx.de> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2013-08-28arm, am335x: add support for 3 siemens boardsHeiko Schocher
add support for the am335x based boards from siemens: dxr2: - DDR3 128MiB - NAND 256MiB - Ethernet with external Switch SMSC LAN9303 - no PMIC - internal Watchdog - DFU support pxm2: - DDR2 512 MiB - NAND 1024 MiB - PMIC - PHY atheros ar803x - USB Host - internal Watchdog - DFU support rut: - DDR3 256 MiB - NAND 256 MiB - PMIC - PHY natsemi dp83630 - external Watchdog - DFU support Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Roger Meier <r.meier@siemens.com> Signed-off-by: Samuel Egli <samuel.egli@siemens.com> Cc: Pascal Bach <pascal.bach@siemens.com> Cc: Tom Rini <trini@ti.com>
2013-06-03wandboard: Add Boot Splash image with Wandboard logoOtavio Salvador
Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2013-04-05logo: update to the new logo for ATMELJosh Wu
Atmel change to new logo since 2012. This patch update the logo to new one. Signed-off-by: Josh Wu <josh.wu@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2011-07-27digsy_mtc: move board into vendor dir and add vendor logoAnatolij Gustschin
2010-09-21logos: add Freescale logoTimur Tabi
Add the Freescale logo and update the Makefile to build it when building a Freescale board. Signed-off-by: Timur Tabi <timur@freescale.com>
2010-08-10ARM: Add support for jadecpu board based on MB86R01 SoCMatthias Weisser
This patch adds support for the jadecpu board using the MB86R01 'Jade' SoC from Fujitsu. Signed-off-by: Matthias Weisser <weisserm@arcor.de>
2010-02-12at91: Add esd gmbh OTC570 board supportDaniel Gorsulowski
This patch adds support for esd gmbh OTC570 board. The OTC570 is based on an Atmel AT91SAM9263 SoC. Signed-off-by: Daniel Gorsulowski <Daniel.Gorsulowski@esd.eu>
2009-04-16at91: add support for the PM9263 board of Ronetix GmbHIlko Iliev
The PM9263 board is based on the AT91SAM9263-EK board. Here is the page on Ronetix website: http://www.ronetix.at/starter_kit_9263.html Signed-off-by: Ilko Iliev <iliev@ronetix.at> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-07-02Add logos for RRvision boardGary Jennejohn
Signed-off-by: Gary Jennejohn <garyj@denx.de>
2008-05-10Use custom logo for Atmel boardsStelian Pop
This patch adds a custom vendor logo for the Atmel AT91 boards. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2001-11-03Initial revisionwdenk
