path: root/tools/libfdt
2020-04-26libfdt: migrate fdt_ro.c to a wrapper of scripts/dtc/libfdt/fdt_ro.cMasahiro Yamada
There is no essential difference between scripts/dtc/libfdt/fdt_ro.c and lib/libfdt/fdt_ro.c Migrate to a simple wrapper like the other files. Signed-off-by: Masahiro Yamada <masahiroy@kernel.org>
2019-11-04fdt: Sync up to the latest libfdtSimon Glass
Bring over the fdt from this commit: 430419c (origin/master) tests: fix some python warnings adding in the 'assumptions' series designed to reduce code size. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-05-31scripts/dtc: Update to upstream version v1.4.6-9-gaadd0b65c987Rob Herring
This adds the following commits from upstream: aadd0b65c987 checks: centralize printing of property names in failure messages 88960e398907 checks: centralize printing of node path in check_msg f1879e1a50eb Add limited read-only support for older (V2 and V3) device tree to libfdt. 37dea76e9700 srcpos: drop special handling of tab 65893da4aee0 libfdt: overlay: Add missing license 962a45ca034d Avoid installing pylibfdt when dependencies are missing cd6ea1b2bea6 Makefile: Split INSTALL out into INSTALL_{PROGRAM,LIB,DATA,SCRIPT} 51b3a16338df Makefile.tests: Add LIBDL make(1) variable for portability sake 333d533a8f4d Attempt to auto-detect stat(1) being used if not given proper invocation e54388015af1 dtc: Bump version to v1.4.6 a1fe86f380cb fdtoverlay: Switch from using alloca to malloc c8d5472de3ff tests: Improve compatibility with other platforms c81d389a10cc checks: add chosen node checks e671852042a7 checks: add aliases node checks d0c44ebe3f42 checks: check for #{size,address}-cells without child nodes 18a3d84bb802 checks: add string list check for *-names properties 8fe94fd6f19f checks: add string list check 6c5730819604 checks: add a string check for 'label' property a384191eba09 checks: fix sound-dai phandle with arg property check b260c4f610c0 Fix ambiguous grammar for devicetree rule fe667e382bac tests: Add some basic tests for the pci_bridge checks 7975f6422260 Fix widespread incorrect use of strneq(), replace with new strprefixeq() fca296445eab Add strstarts() helper function cc392f089007 tests: Check non-matching cases for fdt_node_check_compatible() bba26a5291c8 livetree: avoid assertion of orphan phandles with overlays c8f8194d76cc implement strnlen for systems that need it c8b38f65fdec libfdt: Remove leading underscores from identifiers 3b62fdaebfe5 Remove leading underscores from identifiers 2d45d1c5c65e Replace FDT_VERSION() with stringify() 2e6fe5a107b5 Fix some errors in comments b0ae9e4b0ceb tests: Correct warning in sw_tree1.c Commit c8b38f65fdec upstream ("libfdt: Remove leading underscores from identifiers") changed the multiple inclusion define protection, so the kernel's libfdt_env.h needs the corresponding update. Signed-off-by: Rob Herring <robh@kernel.org> [ Linux commit: 9130ba884640328bb78aaa4840e5ddf06ccafb1c ] [erosca: - Fixup conflicts in include/linux/libfdt_env.h caused by v2018.03-rc4 commit b08c8c487083 ("libfdt: move headers to <linux/libfdt.h> and <linux/libfdt_env.h>") - Fix build errors in lib/libfdt/fdt_ro.c, tools/libfdt/fdt_rw.c by: - s/_fdt_mem_rsv/fdt_mem_rsv_/ - s/_fdt_offset_ptr/fdt_offset_ptr_/ - s/_fdt_check_node_offset/fdt_check_node_offset_/ - s/_fdt_check_prop_offset/fdt_check_prop_offset_/ - s/_fdt_find_add_string/fdt_find_add_string_/] Signed-off-by: Eugeniu Rosca <erosca@de.adit-jv.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-01-28libfdt: migrate fdt_rw.c to a wrapper of scripts/dtc/libfdt/fdt_rw.cMasahiro Yamada
The only difference between scripts/dtc/libfdt/fdt_rw.c and lib/libfdt/fdt_rw.c is fdt_remove_unused_strings(). It is only used by fdtgrep, so we do not need to compile it for U-Boot image. Move it to tools/libfdt/fdw_rw.c so that lib/libfdt/fdt_rw.c can be a wrapper of scripts/dtc/libfdt/fdt_rw.c. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-12-04libfdt: migrate fdt_wip.c to a wrapper of scripts/dtc/libfdt/fdt_wip.cMasahiro Yamada
Now, lib/libfdt/fdt_wip.c is the same as scripts/dtc/libfdt/fdt_wip.c Change the former to a wrapper of the latter. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-11-17tools: use files from scripts/dtc/libfdt where possibleMasahiro Yamada
Prior to this commit, tools/Makefile pulls all libfdt files from lib/libfdt. lib/libfdt/ and scripts/dtc/libfdt have the same copies for the followings 6 files: fdt.c fdt_addresses.c fdt_empty_tree.c fdt_overlay.c fdt_strerr.c fdt_sw.c This commit changes them to #include ones from scripts/dtc/libfdt. Unfortunately, U-Boot locally modified the following 3 files: fdt_ro.c fdt_wip.c fdt_rw.c I did not touch them in order to avoid unpredictable impact. The fdt_region.c is U-Boot own file. This is also borrowed from lib/libfdt/. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
