path: root/tools/kwbimage.c
2015-07-24kwbimage: Rename CONFIG_SYS_SPI_U_BOOT_OFFS to CONFIG_SYS_U_BOOT_OFFSStefan Roese
To use this offset for other boot device (like SDIO/MMC), lets rename it to a more generic name. This will be used be the SDIO/MMC SPL boot support for the A38x. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr> Cc: Dirk Eibach <eibach@gdsys.de>
2015-07-24kwbimage: Add support for SDIO/MMC boot device selectionStefan Roese
This patch adds support to select the "sdio" as boot device in the kwbimage.cfg file. This line selects this SDIO device: BOOT_FROM sdio Tested on Marvell DB-88F6820-GP board. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr> Cc: Dirk Eibach <eibach@gdsys.de>
2015-06-14tools/kwbimage.c: Correct header size for SPI bootKevin Smith
If defined, the macro CONFIG_SYS_SPI_U_BOOT_OFFS allows a board to specify the offset of the payload image into the kwb image file. This value was being used to locate the image, but was not used in the "header size" field of the main header. Move the use of this macro into the function that returns the header size so that the same value is used in all places. Signed-off-by: Kevin Smith <kevin.smith@elecsyscorp.com> Tested-by: Stefan Roese <sr@denx.de>
2015-03-05kwbimage: align v1 binary header to 4BChris Packham
According to the Armada-XP documentation the binary header format requires the header length to be aligned to 4B. Signed-off-by: Chris Packham <judge.packham@gmail.com> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Prafulla Wadaskar <prafulla@marvell.com>
2015-02-07kwbimage: Make the Makefile pass in CONFIG_SYS_SPI_U_BOOT_OFFSTom Rini
We can't use config.h directly as some platforms include headers that aren't safe to use in normal Linux userland. Signed-off-by: Tom Rini <trini@ti.com>
2015-02-06tools: kwbimage: Support u-boot.img padding to CONFIG_SYS_SPI_U_BOOT_OFFSStefan Roese
This is used on the AXP boards, to pad u-boot.img to the desired offset in SPI flash (only this boot target supported right now). This offset is used by the SPL then to load u-boot.img into SDRAM and execute it there. Signed-off-by: Stefan Roese <sr@denx.de> Reviewed-by: Luka Perkov <luka.perkov@sartura.hr>
2015-01-29imagetool: replace image registration function by linker_lists featureGuilherme Maciel Ferreira
The registration was introduced in commit f86ed6a8d52c99bb2d17d3cac1647edca0c4399c This commit also removes all registration functions, and the member "next" from image_type_params struct Signed-off-by: Guilherme Maciel Ferreira <guilherme.maciel.ferreira@gmail.com>
2015-01-11tools/kwbimage.c: fix parser error handlingAndreas Bießmann
The two error checks for image_boot_mode_id and image_nand_ecc_mode_id where wrong and would never fail, fix that! This was detected by Apple's clang compiler: ---8<--- HOSTCC tools/kwbimage.o tools/kwbimage.c:553:20: warning: comparison of unsigned expression < 0 is always false [-Wtautological-compare] if (el->bootfrom < 0) { ~~~~~~~~~~~~ ^ ~ tools/kwbimage.c:571:23: warning: comparison of unsigned expression < 0 is always false [-Wtautological-compare] if (el->nandeccmode < 0) { ~~~~~~~~~~~~~~~ ^ ~ 2 warnings generated. --->8--- Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Acked-By: Jeroen Hofstee <jeroen@myspectrum.nl>
2015-01-10fix: tools: kwbimage.c: Initialize headersz to suppress warningŁukasz Majewski
When building with my toolchain (4.8.2): CROSS_COMPILE=/home/lukma/work/ptxdist/toolchains/arm/OSELAS.Toolchain-2013.12.0/arm-v7a-linux-gnueabi/gcc-4.8.2-glibc-2.18-binutils-2.24-kernel-3.12-sanitized/bin/arm-v7a-linux-gnueabi- I see following WARNING: tools/kwbimage.c: In function "kwbimage_set_header": tools/kwbimage.c:803:8: warning: "headersz" may be used uninitialized in this function [-Wmaybe-uninitialized] memcpy(ptr, image, headersz); ^ This fix aims to suppress it. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Heiko Schocher <hs@denx.de>
2014-11-04ARM: kwimage: fix v0 formatGerald Kerma
This patch fix the kwimage tools for version 0 fileformat used for kirkwood Tested on sheevaplug Signed-off-by: Gerald Kerma <drEagle@doukki.net> Tested-by: Stefan Roese <sr@denx.de> Reviewed-by: Stefan Roese <sr@denx.de> Acked-By: Prafulla Wadaskar <prafulla@marvell.com>
2014-10-31tools/kwbimage: Fix compilation warningStefan Roese
This patch fixes a compilation warning of kwbimage.c: tools/kwbimage.c: In function ‘kwbimage_set_header’: tools/kwbimage.c:784:8: warning: ‘headersz’ may be used uninitialized in this function [-Wmaybe-uninitialized] memcpy(ptr, image, headersz); ^ Instead of using multiple if statements, use a switch statement with a default entry. And return with error if an unsupported version is configured in the cfg file. Signed-off-by: Stefan Roese <sr@denx.de> Acked-By: Wolfgang Denk <wd@denx.de>
2014-10-31tools/kwbimage.c: fix build on darwinAndreas Bießmann
kwbimage uses get_current_dir_name(3) which is a gnu extension and not available on darwin host. Fix this by converting to portable getcwd(3) function. This patch fixes the following error: ---8<--- HOSTCC tools/kwbimage.o tools/kwbimage.c:399:16: warning: implicit declaration of function 'get_current_dir_name' is invalid in C99 [-Wimplicit-function-declaration] char *cwd = get_current_dir_name(); ^ tools/kwbimage.c:399:10: warning: incompatible integer to pointer conversion initializing 'char *' with an expression of type 'int' [-Wint-conversion] char *cwd = get_current_dir_name(); ^ ~~~~~~~~~~~~~~~~~~~~~~ 2 warnings generated. ... Undefined symbols for architecture x86_64: "_get_current_dir_name", referenced from: _image_headersz_v1 in kwbimage.o ld: symbol(s) not found for architecture x86_64 --->8--- Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Cc: Stefan Roese <sr@denx.de> Acked-by: Stefan Roese <sr@denx.de> [agust: fixed getcwd() return warning] Signed-off-by: Anatolij Gustschin <agust@denx.de>
2014-10-23tools: kwbimage: Add image version 1 support for Armada XP / 370Stefan Roese
This patch integrates the Barebox version of this kwbimage.c file into U-Boot. As this version supports the image version 1 type for the Armada XP / 370 SoCs. It was easier to integrate the existing and known to be working Barebox source than to update the current U-Boot version to support this v1 image header format. Now all Marvell MVEBU SoCs are supported: Image type 0: Kirkwood & Dove Image type 1: Armada 370 & Armada XP Please note that the current v1 support has this restuction (same as has Barebox version): Not implemented: support for the register headers and secure headers in v1 images Tested on Marvell DB-78460-BP eval board. Signed-off-by: Stefan Roese <sr@denx.de> Tested-by: Luka Perkov <luka@openwrt.org>
2013-12-13tools: moved code common to all image tools to a separated module.Guilherme Maciel Ferreira
In order to avoid duplicating code and keep only one point of modification, the functions, structs and defines useful for "dumpimage" were moved from "mkimage" to a common module called "imagetool". This modification also weakens the coupling between image types (FIT, IMX, MXS, and so on) and image tools (mkimage and dumpimage). Any tool may initialize the "imagetool" through register_image_tool() function, while the image types register themselves within an image tool using the register_image_type() function: +---------------+ +------| fit_image | +--------------+ +-----------+ | +---------------+ | mkimage |--------> | | <-----+ +--------------+ | | +---------------+ | imagetool | <------------| imximage | +--------------+ | | +---------------+ | dumpimage |--------> | | <-----+ +--------------+ +-----------+ | +---------------+ +------| default_image | +---------------+ register_image_tool() register_image_type() Also, the struct "mkimage_params" was renamed to "image_tool_params" to make clear its general purpose. Signed-off-by: Guilherme Maciel Ferreira <guilherme.maciel.ferreira@gmail.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2013-08-16tools/Makefile: Move _GNU_SOURCE to MakefileYork Sun
Commit 669dfc2e adds libfdt_env.h to HOSTCPPFLAGS. It causes stdio.h to be included before _GNU_SOURCE is defined in C files. On some old hosts some prototypes are protected by #ifdef __USE_GNU, which is set when _GNU_SOURCE is defined. Signed-off-by: York Sun <yorksun@freescale.com> Acked-by: Simon Glass <sjg@chromium.org>
2011-05-12kwbimage: Fix check variable of checksumNobuhiro Iwamatsu
calc_hdrcsum two times are checked. checksumi of exthdr is not checked. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> CC: Prafulla Wadaskar <prafulla@marvell.com>
2011-01-19Fix typo ("comand" instead of "command")Loïc Minier
Signed-off-by: Loc Minier <loic.minier@linaro.org>
2009-09-15kwbimage.c: Fix compile warning when building on 64 bit systems (again)Wolfgang Denk
Commit 51003b89 attempted to fix a build problem on 64 bit systems, but just turned it into a build problem on 32 bit systems (silly me). Now do the Right Thing (TM) and use a "%zu" printf format. Also fix spelling error. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-09-11kwbimage.c: Fix compile warning when building on 64 bit systemsWolfgang Denk
Fix this warning when building on 64 bit systems: tools/kwbimage.c: In function 'kwbimage_checksum32': tools/kwbimage.c:135: warning: format '%d' expects type 'int', but argument 4 has type 'long unsigned int' Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Prafulla Wadaskar <prafulla@marvell.com>
2009-09-10mkimage: Add Kirkwood Boot Image support (kwbimage)Prafulla Wadaskar
This patch adds support for "kwbimage" (Kirkwood Boot Image) image types to the mkimage code. For details refer to docs/README.kwbimage This patch is tested with Sheevaplug board Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com> Acked-by: Ron Lee <ron@debian.org> Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
