Move the imximage.h header file to a common location so we can make
use of it from U-Boot too.
Add plugin support for imximage.
Define CONFIG_USE_IMXIMG_PLUGIN in defconfig to enable using plugin.
Signed-off-by: Peng Fan <peng.fan@nxp.com>
Cc: Eric Nelson <eric@nelint.com>
Cc: Ye Li <ye.li@nxp.com>
When CHECK_BITS_SET was added, they forgot to add
a new command table, and instead overwrote the
previous table.
Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
Tested-by: Fabio Estevam <fabio.estevam@freescale.com>
* Extend imximage DCD version 2 to support DCD commands
CMD_WRITE_CLR_BIT 4 [address] [mask bit] means:
while ((*address & ~mask) != 0);
CMD_CHECK_BITS_SET 4 [address] [mask bit] means:
while ((*address & mask) != mask);
CMD_CHECK_BITS_CLR 4 [address] [mask bit] means:
*address = *address & ~mask;
* Add set_dcd_param_v2 helper function to set DCD
command parameters
Signed-off-by: Adrian Alonso <aalonso@freescale.com>
Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
imximage header size is 4-byte, not 8-byte aligned.
This produces .imx images that a Vybrid cannot boot
on.
Fix by adding a "padding" field in header.
Signed-off-by: Albert ARIBAUD (3ADEV) <albert.aribaud@3adev.fr>
Add QuadSPI boot support to imximage tool.
Note: The QuadSPI configuration parameters at offset 0x400 are not
included in this patch. Need other tools to generate the parameters
part.
Signed-off-by: Ye.Li <B37916@freescale.com>
According to mx53 and mx6 reference manuals:
"The maximum size of the DCD limited to 1768 bytes."
As each DCD entry consists of 8 bytes, we have a total of 1768 / 8 = 221, and
excluding the first entry, which is the header leads to 220 as the maximum
number for DCD size.
Reported-by: Jonas Karlsson <jonas.d.karlsson@gmail.com>
Acked-by: Nitin Garg <nitin.garg@freescale.com>
Add support for setting the CSF (Command Sequence File) pointer
which is used for HAB (High Assurance Boot) in the imximage by
adding e.g.
CSF 0x2000
in the imximage.cfg file.
This will set the CSF pointer accordingly just after the padded
data image area. The boot_data.length is adjusted with the
value from the imximage.cfg config file.
The resulting u-boot.imx can be signed with the FSL HAB tooling.
The generated CSF block needs to be appended to the u-boot.imx.
Change to dynamically allocate the imx_header to correctly
allocate the IVT, Boot Data and DCD at correct locations
depending on the boot media.
Also check that the Image Vector Table Offset + IVT +
Boot Data + DCD <= Initial Load Region Size.
Previously struct imx_header was always 4096 bytes and was
not dealing correctly with the Image Vector Table Offset.
Now, the memory allocation looks for e.g. SD boot like this
Storage u-boot.imx RAM
Device
00000000 177ff000 <--------------
00000400 00000000 d1 00 20 40 IVT.header 177ff400 <------- |
00000404 00000004 00 00 80 17 IVT.entry 177ff404 ----------- |
00000408 00000008 00 00 00 00 IVT.reserved1 177ff408 | | |
0000040C 0000000C 2c f4 7f 17 IVT.dcd 177ff40C ------ | | |
00000410 00000010 20 f4 7f 17 IVT.boot 177ff410 ---- | | | |
00000414 00000014 00 f4 7f 17 IVT.self 177ff414 -------- | |
00000418 00000018 00 00 00 00 IVT.csf 177ff418 | | | |
0000041C 0000001C 00 00 00 00 IVT.reserved2 177ff41C | | | |
00000420 00000020 00 f0 7f 17 BootData.start 177ff420 <--- | | ---
00000424 00000024 00 60 03 00 BootData.length 177ff424 | |
00000428 00000028 00 00 00 00 BootData.plugin 177ff428 | |
0000042C 0000002C d2 03 30 40 DCD.header 177ff42C <----- |
00001000 00000c00 13 00 00 ea U-Boot Start 17800000 <----------
While at it also remove the unused #define HEADER_OFFSET.
Doing a make distclean; make mx6qsabresd_config; make
and hexdump -C u-boot.imx | less
00000360 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
000003f0 00 00 00 00 00 00 00 00 00 00 00 00 00 04 00 00 |................|
00000400 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
00001000 13 00 00 ea 14 f0 9f e5 14 f0 9f e5 14 f0 9f e5 |...ê.ð.å.ð.å.ð.å|
shows the flash_offset value being written into the final
generated image, wich is not correct.
Instead create flash_offset as static variable such that the
generated image is "clean".
[trini: Fixup common/cmd_io.c]
The MX53 ROM loads the data from NAND in multiples of pages and
supports maximum page size of 4k. Thus, align the image and header
to 4k to be safe from ROM bugs.
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
Cc: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
Cc: Fabio Estevam <fabio.estevam@freescale.com>
Cc: Scott Wood <scottwood@freescale.com>
Cc: Tom Rini <trini@ti.com>
Implement BOOT_OFFSET command for imximage. This command is parallel
to current BOOT_FROM command, but allows more flexibility in configuring
arbitrary image header offset. Also add an imximage.cfg with default
offset values into arm/arch/imx-common/ so the board-specific imximage.cfg
can include this file to avoid magic constants.
The syntax of BOOT_OFFSET command is "BOOT_OFFSET <u32 offset>".
Call with the value the function will use
instead of going through a pointer.
The flash header supports different flash offsets for different
boot devices. E.g. parallel NOR or OneNAND use a different offset
than FLASH_OFFSET_STANDARD (== 0x400).
The flash offset is correctly read from the configuration in
parse_cfg_cmd(). But is then overwritten wrongly in set_imx_hdr_v1/2().
Fix this by removing this overwriting. Use the flash offset
correctly read from the configuration, instead.
If there is no flash_offset read from the configuration file, i.e.
the BOOT_FROM tag is missing, exit with an error message.
Signed-off-by: Dirk Behme <dirk.behme@de.bosch.com>
CC: Jason Liu <liu.h.jason@gmail.com>
CC: Stefano Babic <sbabic@denx.de>
Tested-by: Stefano Babic <sbabic@denx.de>
The i.MX6 processor can boot from NOR flash and SATA disks,
additionally. Add the flash offsets for these additional
boot modes.
Signed-off-by: Fabio Estevam <festevam@gmail.com>
CC: Jason Liu <jason.hui@linaro.org>
Acked-by: Jason Liu <jason.hui@linaro.org>
"make tools-all" should allow building tools such as mkimage and the new
imximage without any config, but imximage.c currently fails to build
with:
imximage.h:27:20: error: config.h: No such file or directory
config.h is not needed in imximage.h nor in imximage.c, and imximage.h
is only included from imximage.c, so drop this include to fix the build.
Signed-off-by: Loïc Minier <loic.minier@linaro.org>
This patch add the MX53 boot image support.
This patch has been tested on Freescale MX53EVK board
and MX51EVK board.
Signed-off-by: Jason Liu <r64343@freescale.com>
Running mkimage to generate an imximage produces a SEGFAULT
on 64 bit machines due to pointer arithmetic limited to 32 bit.
Acked-by: Kim Phillips <kim.phillips@freescale.com>
This patch adds support for "imximage" (MX Boot Image)
to the mkimage utility. The imximage is used on the Freescales's
MX.25, MX.35 and MX.51 processors.
Further details under doc/README.imximage.
This patch was tested on a Freescale mx51evk board.
