path: root/tools/imximage.c
2010-02-24mkimage: SEGFAULT with imximage on 64 bit systemsStefano Babic
Running mkimage to generate an imximage produces a SEGFAULT on 64 bit machines due to pointer arithmetic limited to 32 bit. Signed-off-by: Stefano Babic <sbabic@denx.de> Acked-by: Kim Phillips <kim.phillips@freescale.com>
2010-01-27Fix compiler warning in imximage.c due to getline prototypeKumar Gala
imximage.c: In function 'imximage_parse_cfg_file': imximage.c:142: warning: implicit declaration of function 'getline' Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-01-25mkimage: Add Freescale imx Boot Image support (imximage)Stefano Babic
This patch adds support for "imximage" (MX Boot Image) to the mkimage utility. The imximage is used on the Freescales's MX.25, MX.35 and MX.51 processors. Further details under doc/README.imximage. This patch was tested on a Freescale mx51evk board. Signed-off-by: Stefano Babic <sbabic@denx.de>
