path: root/tools/imximage.c
2018-03-09imximage: Remove failure when no IVT offset is foundFabio Estevam
Sometimes imximage throws the following error: CFGS board/freescale/vf610twr/imximage.cfg.cfgtmp CFGS board/freescale/vf610twr/imximage.cfg.cfgtmp MKIMAGE u-boot-dtb.imx Error: No BOOT_FROM tag in board/freescale/vf610twr/imximage.cfg.cfgtmp arch/arm/mach-imx/Makefile:100: recipe for target 'u-boot-dtb.imx' failed Later on, when running mkimage for the u-boot.imx it will succeed in finding the IVT offset. Looks like some race condition happening during parallel build when processing mkimage for u-boot-dtb.imx and u-boot.imx. A proper fix still needs to be implemented, but as a workaround let's remove the error when the IVT offset is not found. It is useful to have such message, especially during bring-up phase, but the build error that it causes is severe, so better avoid the build error for now. The error checking can be re-implemented later when we have a proper fix. Reported-by: Breno Lima <breno.lima@nxp.com> Reported-by: Thomas Petazzoni <thomas.petazzoni@bootlin.com> Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
2017-03-19tools: imximage: add set bit commandPeng Fan
Add set bit command support. Usage: SET_BIT 4 [address] [bitmask] Signed-off-by: Peng Fan <peng.fan@nxp.com> Cc: Stefano Babic <sbabic@denx.de> Reviewed-by: Stefano Babic <sbabic@denx.de>
2017-01-27tools: imximage: refactor header length calculations for imximage v1Martin Kaiser
We can use the same header length calculations for both imximage v1 and v2. This addresses TODO comments about imximage v1 in the current code. With this patch applied, *header_size_ptr in imximage_set_header() will have the correct value for both imximage v1 and v2. This is necessary for people wanting to add proprietary data behind the created imximage. Signed-off-by: Martin Kaiser <martin@kaiser.cx> Cc: sbabic@denx.de
2016-11-29tools: imximage: display DCD block offset, lengthEric Nelson
These values can be used to sign a U-Boot image for use when loading an image through the Serial Download Protocol (SDP). Note that the address of 0x910000 is usable with the stock configuration of imx_usb_loader on i.MX6 and i.MX7 SOCs: https://github.com/boundarydevices/imx_usb_loader/blob/master/mx6_usb_work.conf#L3 Refer to the section on imx_usb_loader in this post for more details: https://boundarydevices.com/high-assurance-boot-hab-dummies/ Signed-off-by: Eric Nelson <eric@nelint.com>
2016-11-05tools: imximage: check return value when open the plugin filePeng Fan
Check return value when open the plugin file. Coverity report: ** CID 153926: Error handling issues (NEGATIVE_RETURNS) /tools/imximage.c: 542 in copy_plugin_code() ifd = open(plugin_file, O_RDONLY|O_BINARY); >>> CID 153926: Error handling issues (NEGATIVE_RETURNS) >>> "ifd" is passed to a parameter that cannot be negative. Signed-off-by: Peng Fan <peng.fan@nxp.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Tom Rini <trini@konsulko.com> Reported-by: Coverity (CID: 153926) Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-24tools: imximage: add plugin supportPeng Fan
Add plugin support for imximage. Define CONFIG_USE_IMXIMG_PLUGIN in defconfig to enable using plugin. Signed-off-by: Peng Fan <peng.fan@nxp.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Eric Nelson <eric@nelint.com> Cc: Ye Li <ye.li@nxp.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-05-17imx: tools: imximage: fix CLR bit commandAdrian Alonso
Fix incorrect parametr in CMD_CHECK_BITS_CLR command Pass CLR parameter to DCD header for CMD_CHECK_BITS_CLR Signed-off-by: Adrian Alonso <adrian.alonso@nxp.com>
2015-10-07imximage: fix commands other than write_dataTroy Kisky
When CHECK_BITS_SET was added, they forgot to add a new command table, and instead overwrote the previous table. Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com> Tested-by: Fabio Estevam <fabio.estevam@freescale.com>
2015-10-07imximage: header.length of 4 is validTroy Kisky
2015-09-02tools/imximage: set DCD pointer to NULL when its length is 0Baruch Siach
When dcd_len is 0 the Write Data command that the set_dcd_rst_v2() routine generates is empty. This causes HAB to complain that the command is invalid. --------- HAB Event 1 ----------------- event data: 0xdb 0x00 0x0c 0x41 0x33 0x06 0xc0 0x00 0xcc 0x00 0x04 0x04 To fix this set the DCD pointer in the IVT to NULL in this case. The DCD header itself is still needed for detect_imximage_version() to determine the image version. Signed-off-by: Baruch Siach <baruch@tkos.co.il> Acked-by: Stefano Babic <sbabic@denx.de>
2015-07-26imx: imximage: add new CHECK/CLR BIT commandAdrian Alonso
* Extend imximage DCD version 2 to support DCD commands CMD_WRITE_CLR_BIT 4 [address] [mask bit] means: while ((*address & ~mask) != 0); CMD_CHECK_BITS_SET 4 [address] [mask bit] means: while ((*address & mask) != mask); CMD_CHECK_BITS_CLR 4 [address] [mask bit] means: *address = *address & ~mask; * Add set_dcd_param_v2 helper function to set DCD command parameters Signed-off-by: Adrian Alonso <aalonso@freescale.com> Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
2015-02-10Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2015-02-10imx: imximage: Add QuadSPI boot supportYe.Li
Add QuadSPI boot support to imximage tool. Note: The QuadSPI configuration parameters at offset 0x400 are not included in this patch. Need other tools to generate the parameters part. Signed-off-by: Ye.Li <B37916@freescale.com>
2015-01-29imagetool: replace image registration function by linker_lists featureGuilherme Maciel Ferreira
The registration was introduced in commit f86ed6a8d52c99bb2d17d3cac1647edca0c4399c This commit also removes all registration functions, and the member "next" from image_type_params struct Signed-off-by: Guilherme Maciel Ferreira <guilherme.maciel.ferreira@gmail.com>
2014-11-03imximage: Fix the bootdata.size calculationYe.Li
In system boot chapter of i.MX6 reference manual, the "Image Vector Table" figure shows the bootdata.start points to the beginning of the destination memory. It means the bootdata.size should contain the IVT offset part, but the calculation in imximage tool does not have. We found this issue when booting from QuadSPI NOR on i.MX6SX. The u-boot runs into abnormal (crash or stop) after booting. After checked the destination memory where the image is loaded to, there are hundreds of bytes at the image end are not loaded into memory. Since there is a 4096 bytes round in the calculation, for the booting devices using smaller IVT offset, such as SD and SPI booting, they are not easy to reproduce. Signed-off-by: Ye.Li <B37916@freescale.com>
2014-09-09imximage: Fix imximage IVT bug for EIM-NOR bootYe.Li
The load region size of EIM-NOR are defined to 0. For this case, the parameter "imximage_init_loadsize" must be calculated. The imximage tool implements the calculation in the "imximage_generate" function, but the following function "imximage_set_header" resets the value and not calculate. This bug cause some fields of IVT head are not correct, for example the boot_data and DCD overlay the application area. Signed-off-by: Ye.Li <B37916@freescale.com>
2013-12-13tools: moved code common to all image tools to a separated module.Guilherme Maciel Ferreira
In order to avoid duplicating code and keep only one point of modification, the functions, structs and defines useful for "dumpimage" were moved from "mkimage" to a common module called "imagetool". This modification also weakens the coupling between image types (FIT, IMX, MXS, and so on) and image tools (mkimage and dumpimage). Any tool may initialize the "imagetool" through register_image_tool() function, while the image types register themselves within an image tool using the register_image_type() function: +---------------+ +------| fit_image | +--------------+ +-----------+ | +---------------+ | mkimage |--------> | | <-----+ +--------------+ | | +---------------+ | imagetool | <------------| imximage | +--------------+ | | +---------------+ | dumpimage |--------> | | <-----+ +--------------+ +-----------+ | +---------------+ +------| default_image | +---------------+ register_image_tool() register_image_type() Also, the struct "mkimage_params" was renamed to "image_tool_params" to make clear its general purpose. Signed-off-by: Guilherme Maciel Ferreira <guilherme.maciel.ferreira@gmail.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2013-09-27tools/imximage.c: Fix compiling warningYork Sun
Convert set_hdr_func(struct imx_header *imxhdr) to set_hdr_func(void) to get rid of the warning warning: ‘imxhdr’ is used uninitialized in this function Signed-off-by: York Sun <yorksun@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de>
2013-09-05Merge branch 'u-boot-imx/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: drivers/serial/serial.c The conflict above was a trivial case of adding one init function in each branch, and manually resolved in merge.
2013-08-31tools: add support for setting the CSF into imximageStefano Babic
Add support for setting the CSF (Command Sequence File) pointer which is used for HAB (High Assurance Boot) in the imximage by adding e.g. CSF 0x2000 in the imximage.cfg file. This will set the CSF pointer accordingly just after the padded data image area. The boot_data.length is adjusted with the value from the imximage.cfg config file. The resulting u-boot.imx can be signed with the FSL HAB tooling. The generated CSF block needs to be appended to the u-boot.imx. Signed-off-by: Stefano Babic <sbabic@denx.de>
2013-08-31tools: add padding of data image file for imximageStefano Babic
Implement function vrec_header to be able to pad the final data image file according the what has been calculated for boot_data.length. Signed-off-by: Stefano Babic <sbabic@denx.de>
2013-08-31tools: dynamically allocate imx_header in imximageStefano Babic
Change to dynamically allocate the imx_header to correctly allocate the IVT, Boot Data and DCD at correct locations depending on the boot media. Also check that the Image Vector Table Offset + IVT + Boot Data + DCD <= Initial Load Region Size. Previously struct imx_header was always 4096 bytes and was not dealing correctly with the Image Vector Table Offset. Now, the memory allocation looks for e.g. SD boot like this Storage u-boot.imx RAM Device 00000000 177ff000 <-------------- | 00000400 00000000 d1 00 20 40 IVT.header 177ff400 <------- | 00000404 00000004 00 00 80 17 IVT.entry 177ff404 ----------- | 00000408 00000008 00 00 00 00 IVT.reserved1 177ff408 | | | 0000040C 0000000C 2c f4 7f 17 IVT.dcd 177ff40C ------ | | | 00000410 00000010 20 f4 7f 17 IVT.boot 177ff410 ---- | | | | 00000414 00000014 00 f4 7f 17 IVT.self 177ff414 -------- | | 00000418 00000018 00 00 00 00 IVT.csf 177ff418 | | | | 0000041C 0000001C 00 00 00 00 IVT.reserved2 177ff41C | | | | 00000420 00000020 00 f0 7f 17 BootData.start 177ff420 <--- | | --- 00000424 00000024 00 60 03 00 BootData.length 177ff424 | | 00000428 00000028 00 00 00 00 BootData.plugin 177ff428 | | 0000042C 0000002C d2 03 30 40 DCD.header 177ff42C <----- | ... | 00001000 00000c00 13 00 00 ea U-Boot Start 17800000 <---------- While at it also remove the unused #define HEADER_OFFSET. Signed-off-by: Stefano Babic <sbabic@denx.de>
2013-08-31tools: rename mximage_flash_offset to imximage_ivt_offsetStefano Babic
This better reflects the naming from the Reference Manual as well as fits better since "flash" is not really applicabe for SATA. Signed-off-by: Stefano Babic <sbabic@denx.de>
2013-08-31tools: imx_header should not include flash_offsetStefano Babic
Doing a make distclean; make mx6qsabresd_config; make and hexdump -C u-boot.imx | less ... 00000360 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................| * 000003f0 00 00 00 00 00 00 00 00 00 00 00 00 00 04 00 00 |................| ^^^^^^^^^^^ 00000400 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................| * 00001000 13 00 00 ea 14 f0 9f e5 14 f0 9f e5 14 f0 9f e5 |...ê.ð.å.ð.å.ð.å| ... shows the flash_offset value being written into the final generated image, wich is not correct. Instead create flash_offset as static variable such that the generated image is "clean". 00000360 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................| * 00001000 13 00 00 ea 14 f0 9f e5 14 f0 9f e5 14 f0 9f e5 |...ê.ð.å.ð.å.ð.å| Signed-off-by: Stefano Babic <sbabic@denx.de>
2013-08-16tools/Makefile: Move _GNU_SOURCE to MakefileYork Sun
Commit 669dfc2e adds libfdt_env.h to HOSTCPPFLAGS. It causes stdio.h to be included before _GNU_SOURCE is defined in C files. On some old hosts some prototypes are protected by #ifdef __USE_GNU, which is set when _GNU_SOURCE is defined. Signed-off-by: York Sun <yorksun@freescale.com> Acked-by: Simon Glass <sjg@chromium.org>
2013-05-05imx: Align the imximage header and payload to multiples of 4kMarek Vasut
The MX53 ROM loads the data from NAND in multiples of pages and supports maximum page size of 4k. Thus, align the image and header to 4k to be safe from ROM bugs. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Scott Wood <scottwood@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Tom Rini <trini@ti.com>
2013-04-28tools: arm: imx: Implement BOOT_OFFSET command for imximageMarek Vasut
Implement BOOT_OFFSET command for imximage. This command is parallel to current BOOT_FROM command, but allows more flexibility in configuring arbitrary image header offset. Also add an imximage.cfg with default offset values into arm/arch/imx-common/ so the board-specific imximage.cfg can include this file to avoid magic constants. The syntax of BOOT_OFFSET command is "BOOT_OFFSET <u32 offset>". Signed-off-by: Marek Vasut <marex@denx.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Scott Wood <scottwood@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Tom Rini <trini@ti.com> Acked-by: Stefano Babic <sbabic@denx.de> Acked-by: Stefan Roese <sr@denx.de>
2013-01-28tools: imximage: Let .name field be more genericFabio Estevam
Since this structure is not i.MX5x specific, remove the '5x' to make it more generic. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-01-05tools: imximage: Load a size that is multiple of 512Fabio Estevam
In order to mx53 ROM to properly load the U-boot image, its header size should be multiple of 512 bytes. This issue was observed with gcc 4.6.2/4.7.3, which caused data aborts: U-Boot 2013.01-rc2-00172-gf8cfcf1-dirty (Dec 26 2012 - 13:13:28) Board: MX53 LOCO I2C: ready DRAM: 1 GiB MMC: FSL_SDHC: 0, FSL_SDHC: 1 In: serial Out: serial Err: serial CPU: Freescale i.MX53 family rev2.1 at 1000 MHz Reset cause: WDOG Net: FEC Warning: FEC using MAC address from net device Hit any key to stop autoboot: 0 data abort MAYBE you should read doc/README.arm-unaligned-accesses pc : [<aff72220>] lr : [<aff721fc>] sp : af565e20 ip : af566918 fp : 00000000 r10: 00000003 r9 : affabb5b r8 : af565f58 r7 : 00000000 r6 : 36747fff r5 : af5668e8 r4 : 36747fff r3 : af5668ec r2 : af5668eb r1 : 00000000 r0 : af5668e8 Flags: NzcV IRQs off FIQs off Mode SVC_32 Resetting CPU ... resetting ... ,and this patch fixes it. Also, even though the ROUND macro is already defined in common.h, the reason for redefining it in image.h is explained by Stefano Babic: "I will remark a previous comment - even if including common.h seems a good idea to avoid duplications, it makes tools like mkimage to depend on the selected board, because <board>_config must run. Even if this is not a problem for us u-boot developers, it becomes an issue when these tools are included in distros (like u-boot-tools in Ubuntu) and cannot be packaged." Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-10-20imximage: make set_imx_hdr_v1/v2 easier to readTroy Kisky
2012-10-20imximage: change parameters to set_imx_hdrTroy Kisky
Call with the value the function will use instead of going through a pointer. Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
2012-10-20imximage: delay setting of image sizeTroy Kisky
When later we change to variable length header, we won't know the file size when set_imx_hdr is called. So this is prep work. Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
2012-10-20imximage: fix size of image to load.Troy Kisky
sbuf->st_size already includes sizeof(struct imx_header), so remove extra addition. Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
2012-10-20imximage: move flash_offset check to common locationTroy Kisky
Both set_imx_hdr_v1 and set_imx_hdr_v2 perform the same check. Move check to before the set_imx_hdr call. Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com> Acked-by: Stefano Babic <sbabic@denx.de>
2012-10-20imximage: remove redundant setting of app_dest_ptrTroy Kisky
2012-10-20imximage: check dcd_len as entries addedTroy Kisky
Before the len was checked after the entire file was processed, so it could have already overflowed. Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
2012-03-27imximage: Remove overwriting of flash_offsetDirk Behme
The flash header supports different flash offsets for different boot devices. E.g. parallel NOR or OneNAND use a different offset than FLASH_OFFSET_STANDARD (== 0x400). The flash offset is correctly read from the configuration in parse_cfg_cmd(). But is then overwritten wrongly in set_imx_hdr_v1/2(). Fix this by removing this overwriting. Use the flash offset correctly read from the configuration, instead. If there is no flash_offset read from the configuration file, i.e. the BOOT_FROM tag is missing, exit with an error message. Signed-off-by: Dirk Behme <dirk.behme@de.bosch.com> CC: Jason Liu <liu.h.jason@gmail.com> CC: Stefano Babic <sbabic@denx.de> Tested-by: Stefano Babic <sbabic@denx.de>
2012-02-12imximage: Sort bootops alphabeticallyDirk Behme
Signed-off-by: Dirk Behme <dirk.behme@de.bosch.com> CC: Fabio Estevam <festevam@gmail.com> CC: Stefano Babic <sbabic@denx.de> CC: Jason Liu <jason.hui@linaro.org> Acked-by: Jason Liu <jason.hui@linaro.org>
2012-02-12imximage: Add support for i.MX6Dirk Behme
The i.MX6 processor can boot from NOR flash and SATA disks, additionally. Add the flash offsets for these additional boot modes. Signed-off-by: Dirk Behme <dirk.behme@de.bosch.com> Signed-off-by: Fabio Estevam <festevam@gmail.com> CC: Stefano Babic <sbabic@denx.de> CC: Jason Liu <jason.hui@linaro.org> Acked-by: Jason Liu <jason.hui@linaro.org>
2011-02-02imximage: Add MX53 boot image supportLiu Hui-R64343
This patch add the MX53 boot image support. This patch has been tested on Freescale MX53EVK board and MX51EVK board. Signed-off-by: Jason Liu <r64343@freescale.com>
2010-04-30mkimage: correct spelling error in imximageStefano Babic
2010-02-24tools: fix imximage warningKim Phillips
Fix build warning: Configuring for MPC837XEMDS board... imximage.c: In function `imximage_parse_cfg_file': imximage.c:146: warning: passing argument 2 of `getline' from incompatible pointer type /usr/include/bits/stdio.h:116: note: expected `size_t *' but argument is of type `uint32_t *' Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2010-02-24mkimage: SEGFAULT with imximage on 64 bit systemsStefano Babic
Running mkimage to generate an imximage produces a SEGFAULT on 64 bit machines due to pointer arithmetic limited to 32 bit. Signed-off-by: Stefano Babic <sbabic@denx.de> Acked-by: Kim Phillips <kim.phillips@freescale.com>
2010-01-27Fix compiler warning in imximage.c due to getline prototypeKumar Gala
imximage.c: In function 'imximage_parse_cfg_file': imximage.c:142: warning: implicit declaration of function 'getline' Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-01-25mkimage: Add Freescale imx Boot Image support (imximage)Stefano Babic
This patch adds support for "imximage" (MX Boot Image) to the mkimage utility. The imximage is used on the Freescales's MX.25, MX.35 and MX.51 processors. Further details under doc/README.imximage. This patch was tested on a Freescale mx51evk board. Signed-off-by: Stefano Babic <sbabic@denx.de>
