path: root/tools/imximage.c
2012-03-27imximage: Remove overwriting of flash_offsetDirk Behme
The flash header supports different flash offsets for different boot devices. E.g. parallel NOR or OneNAND use a different offset than FLASH_OFFSET_STANDARD (== 0x400). The flash offset is correctly read from the configuration in parse_cfg_cmd(). But is then overwritten wrongly in set_imx_hdr_v1/2(). Fix this by removing this overwriting. Use the flash offset correctly read from the configuration, instead. If there is no flash_offset read from the configuration file, i.e. the BOOT_FROM tag is missing, exit with an error message. Signed-off-by: Dirk Behme <dirk.behme@de.bosch.com> CC: Jason Liu <liu.h.jason@gmail.com> CC: Stefano Babic <sbabic@denx.de> Tested-by: Stefano Babic <sbabic@denx.de>
2012-02-12imximage: Sort bootops alphabeticallyDirk Behme
Signed-off-by: Dirk Behme <dirk.behme@de.bosch.com> CC: Fabio Estevam <festevam@gmail.com> CC: Stefano Babic <sbabic@denx.de> CC: Jason Liu <jason.hui@linaro.org> Acked-by: Jason Liu <jason.hui@linaro.org>
2012-02-12imximage: Add support for i.MX6Dirk Behme
The i.MX6 processor can boot from NOR flash and SATA disks, additionally. Add the flash offsets for these additional boot modes. Signed-off-by: Dirk Behme <dirk.behme@de.bosch.com> Signed-off-by: Fabio Estevam <festevam@gmail.com> CC: Stefano Babic <sbabic@denx.de> CC: Jason Liu <jason.hui@linaro.org> Acked-by: Jason Liu <jason.hui@linaro.org>
2011-02-02imximage: Add MX53 boot image supportLiu Hui-R64343
This patch add the MX53 boot image support. This patch has been tested on Freescale MX53EVK board and MX51EVK board. Signed-off-by: Jason Liu <r64343@freescale.com>
2010-04-30mkimage: correct spelling error in imximageStefano Babic
2010-02-24tools: fix imximage warningKim Phillips
Fix build warning: Configuring for MPC837XEMDS board... imximage.c: In function `imximage_parse_cfg_file': imximage.c:146: warning: passing argument 2 of `getline' from incompatible pointer type /usr/include/bits/stdio.h:116: note: expected `size_t *' but argument is of type `uint32_t *' Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2010-02-24mkimage: SEGFAULT with imximage on 64 bit systemsStefano Babic
Running mkimage to generate an imximage produces a SEGFAULT on 64 bit machines due to pointer arithmetic limited to 32 bit. Signed-off-by: Stefano Babic <sbabic@denx.de> Acked-by: Kim Phillips <kim.phillips@freescale.com>
2010-01-27Fix compiler warning in imximage.c due to getline prototypeKumar Gala
imximage.c: In function 'imximage_parse_cfg_file': imximage.c:142: warning: implicit declaration of function 'getline' Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-01-25mkimage: Add Freescale imx Boot Image support (imximage)Stefano Babic
This patch adds support for "imximage" (MX Boot Image) to the mkimage utility. The imximage is used on the Freescales's MX.25, MX.35 and MX.51 processors. Further details under doc/README.imximage. This patch was tested on a Freescale mx51evk board. Signed-off-by: Stefano Babic <sbabic@denx.de>
