path: root/tools/imx8m_image.sh
2020-02-09tools: imx8m_image: fix warning messageSébastien Szymanski
When a firmware file is missing the warning message doesn't indicate the firmware file name because '$tmp' var doesn't exist. Fix the warning message and while at it reduce the if/else statement. Signed-off-by: Sébastien Szymanski <sebastien.szymanski@armadeus.com> Reviewed-by: Frieder Schrempf <frieder.schrempf@kontron.de>
2020-01-07tools: imx8m_image: Change source path for DDR firmware to build dirFrieder Schrempf
The DDR firmware binaries are not part of the U-Boot source code, so we should look for them in the build directory, where they need to be copied to before building U-Boot. The ATF binary is already fetched from the build directory, but the README files for the i.MX8M EVKs claim that it needs to be copied to the source directory (which is still true for in-tree builds, but not in general). Therefore we also fix the READMEs to use the build directory as the correct location for all additional binary files. Sined-off-by: Frieder Schrempf <frieder.schrempf@kontron.de>
2019-11-05tools: imx8m_image: support ddr4 firmwarePeng Fan
some boards use ddr4, not lpddr4, so we need to check ddr4 firmware. Signed-off-by: Peng Fan <peng.fan@nxp.com>
2019-10-08tools: imx8m_image: align spl bin image sizePeng Fan
The loader for the DDR firmware in drivers/ddr/imx/imx8m/helper.c uses a 4-byte-aligned address to load the firmware. In cases where OF is enabled in SPL the dtb will be appended to the SPL binary and can result in a binary that is not aligned correctly. If OF is not enabled in SPL, `_end` is already aligned correctly, but this patch does not hurt. To ensure the correct alignment we use dd to create a temporary file u-boot-spl-pad.bin with the correct padding. Reviewed-by: Frieder Schrempf <frieder.schrempf@kontron.de> Tested-by: Frieder Schrempf <frieder.schrempf@kontron.de> Signed-off-by: Peng Fan <peng.fan@nxp.com>
2019-04-01tools/imx8m_image.sh: remove bashismBaruch Siach
Use a single '=' to test string equality for compatibility with non-bash shells. Otherwise, if /bin/sh is dash, build fails: ./tools/imx8m_image.sh: 15: [: signed_hdmi_imx8m.bin: unexpected operator ./tools/imx8m_image.sh: 15: [: signed_hdmi_imx8m.bin: unexpected operator ./tools/imx8m_image.sh: 15: [: spl/u-boot-spl-ddr.bin: unexpected operator ./tools/imx8m_image.sh: 15: [: spl/u-boot-spl-ddr.bin: unexpected operator WARNING './spl/u-boot-spl-ddr.bin' not found, resulting binary is not-functional Signed-off-by: Baruch Siach <baruch@tkos.co.il> Tested-by: Chris Spencer <christopher.spencer@sea.co.uk>
2019-01-01imx: imx8mq: build flash.binPeng Fan
Build flash.bin for i.MX8MQ, it will include signed hdmi firmware, spl, ddr firmware, fit image(bl31.bin, u-boot-nodtb.bin, dtb). Burn it to 33KB offset of SD card. Signed-off-by: Peng Fan <peng.fan@nxp.com>
