It looks like tools/imls/Makefile is invoked from nowhere.
And also it is broken.
In-tree build:
- Do not create a symbolic link
from include/asm to arch/${ARCH}/include/asm
- Add ${SRCTREE}/arch/arm/include into the header search path
Out-of-tree build:
- Do not create a directory ${OBJTREE}/include2
from ${OBJTREE}/include2/asm to ${SRCTREE}/arch/${ARCH}/include/asm
[trini: Drop changes for PEP 4 following python tools]
[trini: Fixup common/cmd_io.c]
Commit d984fed0 (makefiles: fixes for building build tools)
changed the variable name FIT_CFLAGS to HOSTCFLAGS_NOPED
but forgot to update to corresponding comment.
Signed-off-by: Daniel Hobi <daniel.hobi@schmid-telecom.ch>
Cc: Scott Wood <scottwood@freescale.com>
Move the libfdt directory into the common lib/ directory to clean up the
top-level directory.
Now that the other architecture-specific lib directories have been
moved out of the top-level directory there's not much reason to have the
'_generic' suffix on the common lib directory.
Currently, some of the tools instead set CC to be HOSTCC in order to re-use
some pattern rules -- but this fails when the user overrides CC on the make
command line. Also, the HOSTCFLAGS in tools/Makefile are currently not
being used because config.mk overwrites them.
This patch adds static pattern rules for files that have been requested to
be built with the native compiler using $(HOSTSRCS) and $(HOSTOBJS), and
converts the tools to use them.
It restores easylogo to using the host compiler, which was broken by commit
38d299c2db81bd889c601b5dfc12c4e83ef83333 (if this was an intentional change,
please let me know -- but it seems to be a build tool).
It restores -pedantic and the special flags for darwin and cygwin that were
requested in tools/makefile (but keeps the flags added by config.mk) --
hopefully someone can test this on those platforms. It no longer
conditionalizes -pedantic on not being darwin; it wasn't clear that that was
intentional, and unless there's a real problem it's just inviting people to
contribute non-pedantic patches to those files (I'm not a fan of -pedantic
personally, but if it's on for one platform it should be on for all).
HOST_LDFLAGS is renamed HOSTLDFLAGS for consistency with the previous
HOST_CFLAGS to HOSTCFLAGS rename. A new HOSTCFLAGS_NOPED is made available
for those files which currently cannot be built with -pedantic, and replaces
the old FIT_CFLAGS.
imls now uses the cross compiler properly, rather than by trying to
reconstruct CC using the typoed $(CROSS_COMPILER).
envcrc.c is now dependency-processed unconditionally -- previously it would
be built without being on (HOST)SRCS if CONFIG_ENV_IS_EMBEDDED was not
selected.
The top build system sets up HOSTCFLAGS a bit and exports it, but other
places use HOST_CFLAGS instead. Unify the two as HOSTCFLAGS so that the
values stay in sync.
This patch adds, under tools folder, a new command called imls. Its
goal is the same of UBoot's imls but it can be used as Linux shell
command. It reads from raw mtd partition and prints the list of the
stored images.
Signed-off-by: Marco Stornelli <marco.stornelli@gmail.com>
