path: root/tools/image-host.c
2018-01-15fix incorrect usage of DT node unit address in commentsAndre Przywara
The DT spec demands a unit-address in a node name to match the "reg" property in that node. Newer dtc versions will throw warnings if this is not the case. Fix all occurences in the tree where node names were mentioned in comments, to not give bad examples to the reader. Signed-off-by: Andre Przywara <andre.przywara@arm.com>
2017-11-06tools: image: fix message when fail to add verification data for configMasahiro Yamada
This function is called when signing configuration nodes. Adjust the error message. I do not know why we do not need to show the error message in case of ENOSPC. Remove the if-conditional that seems unnecessary. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-11-06tools: image: allow to sign image nodes without -K optionMasahiro Yamada
If -K option is missing when you sign image nodes, it fails with an unclear error message: tools/mkimage Can't add hashes to FIT blob: -1 It is hard to figure out the cause of the failure. In contrast, when you sign configuration nodes, -K is optional because fit_config_process_sig() returns successfully if keydest is unset. Probably this is a preferred behavior when you want to update FIT with the same key; you do not have to update the public key in this case. So, this commit changes fit_image_process_sig() to continue signing without keydest. If ->add_verify_data() fails, show a clearer error message, which has been borrowed from fit_config_process_sig(). Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-11-06tools: image: fix "algo" property of public key for verified bootMasahiro Yamada
The "algo_name" points to a property in a blob being edited. The pointer becomes stale when fit_image_write_sig() inserts signatures. Then crypto->add_verify_data() writes wrong data to the public key destination. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-10-23tools: image: fix node name of signature node in FITMasahiro Yamada
Both "conf_name" and "sig_name" point to the name of config node. The latter should be the name of the signature node. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-01-14mkimage: Add support for signing with pkcs11George McCollister
Add support for signing with the pkcs11 engine. This allows FIT images to be signed with keys securely stored on a smartcard, hardware security module, etc without exposing the keys. Support for other engines can be added in the future by modifying rsa_engine_get_pub_key() and rsa_engine_get_priv_key() to construct correct key_id strings. Signed-off-by: George McCollister <george.mccollister@gmail.com>
2016-11-21image: Combine image_sig_algo with image_sign_infoAndrew Duda
Remove the need to explicitly add SHA/RSA pairings. Invalid SHA/RSA pairings will still fail on verify operations when the hash length is longer than the key length. Follow the same naming scheme "checksum,crytpo" without explicitly defining the string. Indirectly adds support for "sha1,rsa4096" signing/verification. Signed-off-by: Andrew Duda <aduda@meraki.com> Signed-off-by: aduda <aduda@meraki.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-11-21image: Add crypto_algo struct for RSA infoAndrew Duda
Cut down on the repetition of algorithm information by defining separate checksum and crypto structs. image_sig_algos are now simply pairs of unique checksum and crypto algos. Signed-off-by: Andrew Duda <aduda@meraki.com> Signed-off-by: aduda <aduda@meraki.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-07-25tools, rsa: Further minor cleanups on top of c236ebd and 2b9ec7mario.six@gdsys.cc
[NOTE: I took v1 of these patches in, and then v2 came out, this commit is squashing the minor deltas from v1 -> v2 of updates to c236ebd and 2b9ec76 into this commit - trini] - Added an additional NULL check, as suggested by Simon Glass to fit_image_process_sig - Re-formatted the comment blocks Signed-off-by: Mario Six <mario.six@gdsys.cc> Reviewed-by: Simon Glass <sjg@chromium.org> [For merging the chnages from v2 back onto v1] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-07-22tools: Fix return code of fit_image_process_sig()mario.six@gdsys.cc
When signing images, we repeatedly call fit_add_file_data() with successively increasing size values to include the keys in the DTB. Unfortunately, if large keys are used (such as 4096 bit RSA keys), this process fails sometimes, and mkimage needs to be called repeatedly to integrate the keys into the DTB. This is because fit_add_file_data actually returns the wrong error code, and the loop terminates prematurely, instead of trying again with a larger size value. This patch corrects the return value and also removes a error message, which is misleading, since we actually allow the function to fail. A (hopefully helpful) comment is also added to explain the lack of error message. This is probably related to 1152a05 ("tools: Correct error handling in fit_image_process_hash()") and the corresponding error reported here: https://www.mail-archive.com/u-boot@lists.denx.de/msg217417.html Signed-off-by: Mario Six <mario.six@gdsys.cc>
2016-07-14tools: Correct error handling in fit_image_process_hash()Simon Glass
We should not be returning -1 as an error code. This can mask a situation where we run out of space adding things to the FIT. By returning the correct error in this case (-ENOSPC) it can be handled by the higher-level code. This may fix the error reported by Tom Van Deun here: https://www.mail-archive.com/u-boot@lists.denx.de/msg217417.html although I am not sure as I cannot actually repeat it. Signed-off-by: Simon Glass <sjg@chromium.org> Reported-by: Tom Van Deun <tom.vandeun@wapice.com> Reviewed-by: Teddy Reed <teddy.reed@gmail.com>
2014-08-14tools: fix typo in tools/image-host.cHeiko Schocher
fix a typo in error printf. If FIT_CONFS_PATH is not found print FIT_CONFS_PATH not FIT_IMAGES_PATH. Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2014-06-19Enhance fit_check_sign to check all imagesSimon Glass
At present this tool only checks the configuration signing. Have it also look at each of the images in the configuration and confirm that they verify. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Heiko Schocher <hs@denx.de> (v1)
2014-06-19mkimage: Automatically expand FDT in more casesSimon Glass
The original code did not cover every case and there was a missing negative sign in one case. Expand the coverage and fix the bug. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-06-11mkimage: Automatically make space in FDT when fullSimon Glass
When adding hashes or signatures, the target FDT may be full. Detect this and automatically try again after making 1KB of space. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-03-21tools, fit_check_sign: verify a signed fit imageHeiko Schocher
add host tool "fit_check_sign" which verifies, if a fit image is signed correct. Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Simon Glass <sjg@chromium.org>
2014-03-21tools/image-host: fix sign-images bugHeiko Schocher
property "sign-images" is never found, fix this. Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Simon Glass <sjg@chromium.org>
2013-06-26image: Add support for signing of FIT configurationsSimon Glass
While signing images is useful, it does not provide complete protection against several types of attack. For example, it it possible to create a FIT with the same signed images, but with the configuration changed such that a different one is selected (mix and match attack). It is also possible to substitute a signed image from an older FIT version into a newer FIT (roll-back attack). Add support for signing of FIT configurations using the libfdt's region support. Please see doc/uImage.FIT/signature.txt for more information. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-06-26image: Support signing of imagesSimon Glass
Add support for signing images using a new signature node. The process is handled by fdt_add_verification_data() which now takes parameters to provide the keys and related information. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-05-14image: Rename fit_add_hashes() to fit_add_verification_data()Simon Glass
We intend to add signatures to FITs also, so rename this function so that it is not specific to hashing. Also rename fit_image_set_hashes() and make it static since it is not used outside this file. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2013-05-14image: Convert fit_image_hash_set_value() to static, and renameSimon Glass
This function doesn't need to be exported, and with verification we want to use it for setting the 'value' property in any node, so rename it. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2013-05-14image: Split hash node processing into its own functionSimon Glass
This function has become quite long and much of the body is indented quite a bit. Move it into a separate function to make it easier to work with. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Marek Vasut <marex@denx.de>
2013-05-14image: Move HOSTCC image code to tools/Simon Glass
This code is never compiled into U-Boot, so move it into a separate file in tools/ to avoid the large #ifdef. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
