path: root/tools/image-host.c
2014-03-21tools, fit_check_sign: verify a signed fit imageHeiko Schocher
add host tool "fit_check_sign" which verifies, if a fit image is signed correct. Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Simon Glass <sjg@chromium.org>
2014-03-21tools/image-host: fix sign-images bugHeiko Schocher
property "sign-images" is never found, fix this. Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Simon Glass <sjg@chromium.org>
2013-06-26image: Add support for signing of FIT configurationsSimon Glass
While signing images is useful, it does not provide complete protection against several types of attack. For example, it it possible to create a FIT with the same signed images, but with the configuration changed such that a different one is selected (mix and match attack). It is also possible to substitute a signed image from an older FIT version into a newer FIT (roll-back attack). Add support for signing of FIT configurations using the libfdt's region support. Please see doc/uImage.FIT/signature.txt for more information. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-06-26image: Support signing of imagesSimon Glass
Add support for signing images using a new signature node. The process is handled by fdt_add_verification_data() which now takes parameters to provide the keys and related information. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-05-14image: Rename fit_add_hashes() to fit_add_verification_data()Simon Glass
We intend to add signatures to FITs also, so rename this function so that it is not specific to hashing. Also rename fit_image_set_hashes() and make it static since it is not used outside this file. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2013-05-14image: Convert fit_image_hash_set_value() to static, and renameSimon Glass
This function doesn't need to be exported, and with verification we want to use it for setting the 'value' property in any node, so rename it. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2013-05-14image: Split hash node processing into its own functionSimon Glass
This function has become quite long and much of the body is indented quite a bit. Move it into a separate function to make it easier to work with. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Marek Vasut <marex@denx.de>
2013-05-14image: Move HOSTCC image code to tools/Simon Glass
This code is never compiled into U-Boot, so move it into a separate file in tools/ to avoid the large #ifdef. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
