path: root/tools/ifdtool.c
2022-01-19doc: replace @return by Return:Heinrich Schuchardt
Sphinx expects Return: and not @return to indicate a return value. find . -name '*.c' -exec \ sed -i 's/^\(\s\)\*\(\s*\)@return\(\s\)/\1*\2Return:\3/' {} \; find . -name '*.h' -exec \ sed -i 's/^\(\s\)\*\(\s*\)@return\(\s\)/\1*\2Return:\3/' {} \; Signed-off-by: Heinrich Schuchardt <heinrich.schuchardt@canonical.com>
2018-05-10SPDX: Convert a few files that were missed beforeTom Rini
As part of the main conversion a few files were missed. These files had additional whitespace after the '*' and before the SPDX tag and my previous regex was too strict. This time I did a grep for all SPDX tags and then filtered out anything that matched the correct styles. Fixes: 83d290c56fab ("SPDX: Convert all of our single license tags to Linux Kernel style") Reported-by: Heinrich Schuchardt <xypron.debian@gmx.de> Signed-off-by: Tom Rini <trini@konsulko.com>
2018-03-05libfdt: move headers to <linux/libfdt.h> and <linux/libfdt_env.h>Masahiro Yamada
Thomas reported U-Boot failed to build host tools if libfdt-devel package is installed because tools include libfdt headers from /usr/include/ instead of using internal ones. This commit moves the header code: include/libfdt.h -> include/linux/libfdt.h include/libfdt_env.h -> include/linux/libfdt_env.h and replaces include directives: #include <libfdt.h> -> #include <linux/libfdt.h> #include <libfdt_env.h> -> #include <linux/libfdt_env.h> Reported-by: Thomas Petazzoni <thomas.petazzoni@bootlin.com> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-01-28tools: include necessary headers explicitlyMasahiro Yamada
Several host-tools use "bool" type without including <stdbool.h>. This relies on the crappy header inclusion chain. tools/Makefile has the following line: HOST_EXTRACFLAGS += -include $(srctree)/include/libfdt_env.h \ All host-tools are forced to include libfdt_env.h even if they are totally unrelated to FDT. Then, <stdbool.h> is indirectly included as follows: include/libfdt_env.h -> include/linux/types.h -> <stdbool.h> I am fixing this horrible crap. In advance, I need to add necessary include directives explicitly. tools/fdtgrep.c needs more; <fctl.h> for open() and <errno.h> for errno. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-12-20binman: Drop microcode features from ifdtoolSimon Glass
Now that binman supports creating images with microcode, drop the code from ifdtool. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com>
2015-09-09x86: ifdtool: Support checking region overlap before U-BootBin Meng
We have the capability to check regions written after U-Boot that do not overlap. Since regions can also be written before U-Boot, add such check for these too. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Andy Pont <andy.pont@sdcsystems.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2015-08-26x86: ifdtool: Drop microcode from the device tree when collatingSimon Glass
When ifdtool collates the microcode into one place it effectively creates a copy of the 'data' properties in the device tree microcode nodes. This is wasteful since we now have two copies of the microcode in the ROM. To avoid this, remove the microcode data from the device tree and shrink it down. This means that there is only one copy and the overall ROM space used by the microcode does not increase. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com>
2015-08-26x86: ifdtool: Support collating microcode into one placeSimon Glass
The Intel Firmware Support Package (FSP) requires that microcode be provided very early before the device tree can be scanned. We already support adding a pointer to the microcode data in a place where early init code can access. However this just points into the device tree and can only point to a single lot of microcode. For boards which may have different CPU types we must support multiple microcodes and pass all of them to the FSP in one place. Enhance ifdtool to scan all the microcode, place it together in the ROM and update the microcode pointer to point there. This allows us to pass multiple microcode blocks to the FSP using its existing API. Enable the flag in the Makefile so that this feature is used by default for all boards. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com>
2015-08-26x86: ifdtool: Split microcode linking into its own functionSimon Glass
The code to set up the microcode pointer in the ROM shares almost nothing with the write_uboot() function. Move it into its own function so it will be easier to extend. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com>
2015-08-26x86: ifdtool: Check that U-Boot does not overlap other regionsSimon Glass
Since U-Boot and its device tree can grow we should check that it does not overlap the regions above it. Track the ROM offset that U-Boot reaches and check that other regions (written after U-Boot) do not interfere. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com>
2015-07-14tools: ifdtool: Write correct offset on 32-bit machineBin Meng
On 32-bit machine strtol() returns LONG_MAX which is 0x7fffffff, which is wrong for u-boot.rom components like u-boot-x86-16bit.bin. Change to use strtoll() so that it works on both 32-bit and 64-bit machines. Reported-by: Fei Wang <wangfei.jimei@gmail.com> Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-06-04tools: ifdtool: Do not write region while its size is negativeBin Meng
We should ignore those regions whose size is negative. These are typically optional and unused regions (like GbE and platform data). Change-Id: I65ad01746144604a1dc0588b617af21f2722ebbf Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-01-13x86: Correct ifdtool microcode calculationSimon Glass
This currently assumes that U-Boot resides at the start of ROM. Update it to remove this assumption. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Bin Meng <bmeng.cn@gmail.com>
2014-12-18x86: ifdtool: Add support for early microcode accessSimon Glass
Some Intel CPUs use an 'FSP' binary blob which provides an inflexible means of starting up the CPU. One result is that microcode updates can only be done before RAM is available and therefore parsing of the device tree is impracticle. Worse, the addess of the microcode update must be stored in ROM since a pointer to its start address and size is passed to the 'FSP' blob. It is not possible to perform any calculations to obtain the address and size. To work around this, ifdtool is enhanced to work out the address and size of the first microcode update it finds in the supplied device tree. It then writes these into the correct place in the ROM. U-Boot can then start up the FSP correctly. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2014-12-18x86: ifdtool: Use a structure for the file/address listSimon Glass
Rather than two independent arrays, use a single array of a suitable structure. Also add a 'type' member since we will shortly add additional types. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2014-12-18x86: ifdtool: Display filename when file errors are reportedSimon Glass
When a file is missing it helps to know which file. Update the error message to print this information. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2014-12-18x86: ifdtool: Correct a debug() missing parameterSimon Glass
This is missing a parameter. Fix it to avoid a warning when debug is enabled. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2014-12-13x86: ifdtool: Separate out filenames for -D and -iSimon Glass
To allow these options to be specified together, separate them out. Change-Id: Ib93f11cd51eb3302127f4c82936ff2b44c88d5a2 Signed-off-by: Simon Glass <sjg@chromium.org>
2014-12-13tools/ifdtool: Support writing multiple files (-w) simultaneouslyBin Meng
Currently ifdtool only supports writing one file (-w) at a time. This looks verbose when generating u-boot.rom for x86 targets. This change allows at most 16 files to be written simultaneously. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-11-21x86: ifdtool: Allow creation of an empty ROMSimon Glass
Allow an empty ROM to be created, without needing to provide a descriptor. The descriptor is not needed on some x86 boards. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-11-21x86: Add ifdtool for working with Intel Flash Descriptor ROM imagesSimon Glass
Newer Intel chips require a Management Engine which requires a particular format for the SPI flash that contains the boot loader. Add a tool that supports creating and modifying these ROM images. This tool is from Chrome OS but has been cleaned up to use U-Boot style and to add comments. A few features have been added also. Signed-off-by: Simon Glass <sjg@chromium.org>
