path: root/tools/fit_image.c
2016-11-06mkimage: Allow including a ramdisk in FIT auto modeTomeu Vizoso
Adds -i option that allows specifying a ramdisk file to be added to the FIT image when we are using the automatic FIT mode (no ITS file). This makes adding Depthcharge support to LAVA much more convenient, as no additional configuration files need to be kept around in the machine that dispatches jobs to the boards. Signed-off-by: Tomeu Vizoso <tomeu.vizoso@collabora.com> Cc: Simon Glass <sjg@chromium.org> Cc: Matt Hart <matthew.hart@linaro.org> Cc: Neil Williams <codehelp@debian.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-07-14tools: Add an error code when fit_handle_file() failsSimon Glass
The error code may provide useful information for debugging. Add it to the error string. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Teddy Reed <teddy.reed@gmail.com>
2016-07-14image: Correct auto-fit architecture property nameSimon Glass
The fit_write_images() function incorrectly uses the long name for the architecture. This cannot be parsed with the FIT is read. Fix this by using the short name instead. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-06-24Respect SOURCE_DATE_EPOCH when building FIT images.Vagrant Cascadian
Embedding timestamps in FIT images results in unreproducible builds for targets that generate a fit image, such as dra7xx_evm. This patch uses the SOURCE_DATE_EPOCH environment variable, when set, to use specified value for the date. Thanks to HW42 for debugging the issue and providing the patch: https://lists.alioth.debian.org/pipermail/reproducible-builds/Week-of-Mon-20160606/005722.html For more information about reproducible builds and the SOURCE_DATE_EPOCH specification: https://reproducible-builds.org/specs/source-date-epoch/ https://reproducible-builds.org/ Signed-off-by: Vagrant Cascadian <vagrant@debian.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-06-24mkimage: fit: spl: Add an optional static offset for external dataTeddy Reed
When building a FIT with external data (-E), U-Boot proper may require absolute positioning for executing the external firmware. To acheive this use the (-p) switch, which will replace the amended 'data-offset' with 'data-position' indicating the absolute position of external data. It is considered an error if the requested absolute position overlaps with the initial data required for the compact FIT. Signed-off-by: Teddy Reed <teddy.reed@gmail.com>
2016-05-02fit_image: Fix a double close() on the error pathSimon Glass
There is an extra close() call which is not needed. Reported-by: Coverity (CID: 143065) Signed-off-by: Simon Glass <sjg@chromium.org>
2016-03-22mkimage: Don't close the file if it wasn't openedSimon Glass
The error path for fit_import_data() is incorrect if the second open() call fails. Reported-by: Coverity (CID: 138489) Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-03-22mkimage: Ensure file is closed in fdt_property_file()Simon Glass
The file that is opened is not closed in all cases. Fix it. Reported-by: Coverity (CID: 138490) Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-03-22mkimage: Fix missing free() and close() in fit_build()Simon Glass
Make sure that both the error path and normal return free the buffer and close the file. Reported-by: Coverity (CID: 138491) Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-03-22mkimage: Fix missing free() in fit_extract_data()Simon Glass
The 'buf' variable is not freed. Fix it. Reported-by: Coverity (CID: 138492) Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-03-22mkimage: Fix error path in fit_extract_data()Simon Glass
The 'fdt' variable is not unmapped in all error cases. Fix this. Reported-by: Coverity (CID: 138493) Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-03-22mkimage: Add a missing free() to fit_import_data()Simon Glass
The space allocated to fdt is not freed on error. Fix it. Reported-by: Coverity (CID: 138494) Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-03-22mkimage: Correct file being closed twice in fit_extract_data()Simon Glass
The code flows through to the end of the function, so we don't need another close() before this. Remove it. Reported-by: Coverity (CID: 138503) Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-03-22mkimage: Correct file being closed twice in fit_import_data()Simon Glass
The code flows through to the end of the function, so we don't need another close() before this. Remove it. Reported-by: Coverity (CID: 138504) Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-03-22mkimage: Fix munmap() call when importing dataSimon Glass
The munmap() call unmaps the wrong memory buffer. Fix it. Reported-by: Coverity (CID: 138505) Reported-by: Coverity (CID: 138495) Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-03-14mkimage: Bring data into the FIT before processingSimon Glass
Since we now support data outside the FIT image, bring it into the FIT image first before we do any processing. This avoids adding new functionality to the core FIT code for now. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-03-14mkimage: Support placing data outside the FITSimon Glass
One limitation of FIT is that all the data is 'inline' within it, using a 'data' property in each image node. This means that to find out what is in the FIT it is necessary to scan the entire file. Once loaded it can be scanned and then the images can be copied to the correct place in memory. In SPL it can take a significant amount of time to copy images around in memory. Also loading data that does not end up being used is wasteful. It would be useful if the FIT were small, acting as a directory, with the actual data stored elsewhere. This allows SPL to load the entire FIT, without the images, then load the images it wants later. Add a -E option to mkimage to request that it output an 'external' FIT. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-03-14mkimage: Support adding device tree files to a FITSimon Glass
To make the auto-FIT feature useful we need to be able to provide a list of device tree files on the command line for mkimage to add into the FIT. Add support for this feature. So far there is no support for hashing or verified boot using this method. For those cases, a .its file must still be provided. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-03-14mkimage: Support automatic creating of a FIT without a .itsSimon Glass
At present, when generating a FIT, mkimage requires a .its file containing the structure of the FIT and referring to the images to be included. Creating the .its file is a separate step that makes it harder to use FIT. This is not required for creating legacy images. Often the FIT is pretty standard, consisting of an OS image, some device tree files and a single configuration. We can handle this case automatically and avoid needing a .its file at all. To start with, support automatically generate the FIT using a new '-f auto' option. Initially this only supports adding a single image (e.g. a linux kernel) and a single configuration. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-01-29dumpimage: fit: extract FIT imagesGuilherme Maciel Ferreira
The dumpimage is able to extract components contained in a FIT image: $ ./dumpimage -T flat_dt -i CONTAINER.ITB -p INDEX FILE The CONTAINER.ITB is a regular FIT container file. The INDEX is the poisition of the sub-image to be retrieved, and FILE is the file (path+name) to save the extracted sub-image. For example, given the following kernel.its to build a kernel.itb: /dts-v1/; / { ... images { kernel@1 { description = "Kernel 2.6.32-34"; data = /incbin/("/boot/vmlinuz-2.6.32-34-generic"); type = "kernel"; arch = "ppc"; os = "linux"; compression = "gzip"; load = <00000000>; entry = <00000000>; hash@1 { algo = "md5"; }; }; ... }; ... }; The dumpimage can extract the 'kernel@1' node through the following command: $ ./dumpimage -T flat_dt -i kernel.itb -p 0 kernel Extracted: Image 0 (kernel@1) Description: Kernel 2.6.32-34 Created: Wed Oct 22 15:50:26 2014 Type: Kernel Image Compression: gzip compressed Data Size: 4040128 Bytes = 3945.44 kB = 3.85 MB Architecture: PowerPC OS: Linux Load Address: 0x00000000 Entry Point: 0x00000000 Hash algo: md5 Hash value: 22352ad39bdc03e2e50f9cc28c1c3652 Which results in the file 'kernel' being exactly the same as '/boot/vmlinuz-2.6.32-34-generic'. Signed-off-by: Guilherme Maciel Ferreira <guilherme.maciel.ferreira@gmail.com>
2015-01-29imagetool: replace image registration function by linker_lists featureGuilherme Maciel Ferreira
The registration was introduced in commit f86ed6a8d52c99bb2d17d3cac1647edca0c4399c This commit also removes all registration functions, and the member "next" from image_type_params struct Signed-off-by: Guilherme Maciel Ferreira <guilherme.maciel.ferreira@gmail.com>
2014-06-11mkimage: Automatically make space in FDT when fullSimon Glass
When adding hashes or signatures, the target FDT may be full. Detect this and automatically try again after making 1KB of space. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-03-21tools, fit: add fit_info host commandHeiko Schocher
add fit_info command to the host tools. This command prints the name, offset and the len from a property from a node in a fit file. This info can be used to extract a properties data with linux tools, for example "dd". Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Simon Glass <sjg@chromium.org>
2013-12-13tools: moved code common to all image tools to a separated module.Guilherme Maciel Ferreira
In order to avoid duplicating code and keep only one point of modification, the functions, structs and defines useful for "dumpimage" were moved from "mkimage" to a common module called "imagetool". This modification also weakens the coupling between image types (FIT, IMX, MXS, and so on) and image tools (mkimage and dumpimage). Any tool may initialize the "imagetool" through register_image_tool() function, while the image types register themselves within an image tool using the register_image_type() function: +---------------+ +------| fit_image | +--------------+ +-----------+ | +---------------+ | mkimage |--------> | | <-----+ +--------------+ | | +---------------+ | imagetool | <------------| imximage | +--------------+ | | +---------------+ | dumpimage |--------> | | <-----+ +--------------+ +-----------+ | +---------------+ +------| default_image | +---------------+ register_image_tool() register_image_type() Also, the struct "mkimage_params" was renamed to "image_tool_params" to make clear its general purpose. Signed-off-by: Guilherme Maciel Ferreira <guilherme.maciel.ferreira@gmail.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2013-09-20FIT: delete unnecessary castsMasahiro Yamada
Becuase fdt_check_header function takes (const void *) type argument, the argument should be passed to it without being casted to (char *). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-06-26mkimage: Add -r option to specify keys that must be verifiedSimon Glass
Normally, multiple public keys can be provided and U-Boot is not required to use all of them for verification. This is because some images may not be signed, or may be optionally signed. But we still need a mechanism to determine when a key must be used. This feature cannot be implemented in the FIT itself, since anyone could change it to mark a key as optional. The requirement for key verification must go in with the public keys, in a place that is protected from modification. Add a -r option which tells mkimage to mark all keys that it uses for signing as 'required'. If some keys are optional and some are required, run mkimage several times (perhaps with different key directories if some keys are very secret) using the -F flag to update an existing FIT. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2013-06-26mkimage: Add -c option to specify a comment for key signingSimon Glass
When signing an image, it is useful to add some details about which tool or person is authorising the signing. Add a comment field which can take care of miscellaneous requirements. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2013-06-26mkimage: Add -F option to modify an existing .fit fileSimon Glass
When signing images it is sometimes necessary to sign with different keys at different times, or make the signer entirely separate from the FIT creation to avoid needing the private keys to be publicly available in the system. Add a -F option so that key signing can be a separate step, and possibly done multiple times as different keys are avaiable. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2013-06-26mkimage: Add -K to write public keys to an FDT blobSimon Glass
FIT image verification requires public keys. Add a convenient option to mkimage to write the public keys to an FDT blob when it uses then for signing an image. This allows us to use: mkimage -f test.its -K dest.dtb -k keys test.fit and have the signatures written to test.fit and the corresponding public keys written to dest.dtb. Then dest.dtb can be used as the control FDT for U-Boot (CONFIG_OF_CONTROL), thus providing U-Boot with access to the public keys it needs. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2013-06-26mkimage: Add -k option to specify key directorySimon Glass
Keys required for signing images will be in a specific directory. Add a -k option to specify that directory. Also update the mkimage man page with this information and a clearer list of available commands. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de> (v1)
2013-06-26image: Support signing of imagesSimon Glass
Add support for signing images using a new signature node. The process is handled by fdt_add_verification_data() which now takes parameters to provide the keys and related information. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-05-14mkimage: Put FIT loading in function and tidy error handlingSimon Glass
The fit_handle_file() function is quite long - split out the part that loads and checks a FIT into its own function. We will use this function for storing public keys into a destination FDT file. The error handling is currently a bit repetitive - tidy it. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-05-14image: Rename fit_add_hashes() to fit_add_verification_data()Simon Glass
We intend to add signatures to FITs also, so rename this function so that it is not specific to hashing. Also rename fit_image_set_hashes() and make it static since it is not used outside this file. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2012-12-11Correct comment to show the parameters as defined in tools/mkimage.hLars Rasmusson
Signed-off-by: Lars Rasmusson <Lars.Rasmusson@sics.se>
2009-12-05tools/fit_image.c: Remove unused fit_set_header()Peter Tyser
The FIT fit_set_header() function was copied from the standard uImage's image_set_header() function during mkimage reorganization. However, the fit_set_header() function is not used since FIT images use a standard device tree blob header. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-09-10tools: mkimage: split code into core, default and FIT image specificPrafulla Wadaskar
This is a first step towards reorganizing the mkimage code to make it easier to add support for additional images types. Current mkimage code is specific to generating uImage and FIT image files, but the same framework can be used to generate other image types like Kirkwood boot images (kwbimage-TBD). For this, the mkimage code gets reworked: Here is the brief plan for the same:- a) Split mkimage code into core and image specific support b) Implement callback functions for image specific code c) Move image type specific code to respective C files Currently there are two types of file generation/list supported (i.e uImage, FIT), the code is abstracted from mkimage.c/.h and put in default_image.c and fit_image.c; all code in these file is static except init function call d) mkimage_register API is added to add new image type support All above is addressed in this patch e) Add kwbimage type support to this new framework (TBD) This will be implemented in a following commit. Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com> Edit commit message, fix coding style and typos. Signed-off-by: Wolfgang Denk <wd@denx.de>
