path: root/tools/file2include.c
2018-11-26tools/file2include: don't use malloc.h for mallocJonathan Gray
stdlib.h is the header for malloc since at least c89/c90. Previously this would fail to build on OpenBSD and fallback to the wrong header: In file included from u-boot/tools/file2include.c:21: u-boot/include/malloc.h:875:5: error: function-like macro 'CONFIG_IS_ENABLED' is not defined Signed-off-by: Jonathan Gray <jsg@jsg.id.au> Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2018-05-10tools/file2include: avoid incorrect commentsHeinrich Schuchardt
Avoid creating incorrect comments like /* ...*/... */ by printing '.' instead of '*' inside comments. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2018-05-10tools/file2include: create Linux style SPDX headerHeinrich Schuchardt
file2include is used to convert a binary file to a C include. With the patch the SPDX header is written to the first line as expected by scripts/checkpatch.pl. Cf. https://www.kernel.org/doc/html/v4.16/process/license-rules.html Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-01-22tools: provide a tool to convert a binary file to an includeHeinrich Schuchardt
For testing EFI disk management we need an in-memory image of a disk. The tool file2include converts a file to a C include. The file is separated into strings of 8 bytes. Only the non-zero strings are written to the include. The output format has been designed to maintain readability. #define EFI_ST_DISK_IMG { 0x00010000, { \ {0x000001b8, "\x94\x37\x69\xfc\x00\x00\x00\x00"}, /* .7i..... */ \ {0x000001c0, "\x02\x00\x83\x02\x02\x00\x01\x00"}, /* ........ */ \ {0x000001c8, "\x00\x00\x7f\x00\x00\x00\x00\x00"}, /* ........ */ \ {0x000001f8, "\x00\x00\x00\x00\x00\x00\x55\xaa"}, /* ......U. */ \ ... {0x00006000, "\x48\x65\x6c\x6c\x6f\x20\x77\x6f"}, /* Hello wo */ \ {0x00006008, "\x72\x6c\x64\x21\x0a\x00\x00\x00"}, /* rld!.... */ \ {0, NULL} } } As the disk image needed for testing contains mostly zeroes a high compression ratio can be attained. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
