path: root/tools/fdtgrep.c
2018-06-19fdtgrep: Separate out checking of two allocationsSimon Glass
The current code might succeed on the first allocation and fail on the second. Separate the checks to avoid this problem. Of course, free() will never fail and the chances that (when allocating two small areas) one will succeed and one will fail are just as remote. But this keeps coverity happy. Reported-by: Coverity (CID: 131226) Signed-off-by: Simon Glass <sjg@chromium.org>
2018-06-19fdtgrep: Fix logic of free() in do_fdtgrep()Simon Glass
This loop never actually exits, but the way the code is written this is not obvious. Add an explicit error check. Reported-by: Coverity (CID: 131280) Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Add explicit init of region to NULL per LLVM warning] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-01-28tools: include necessary headers explicitlyMasahiro Yamada
Several host-tools use "bool" type without including <stdbool.h>. This relies on the crappy header inclusion chain. tools/Makefile has the following line: HOST_EXTRACFLAGS += -include $(srctree)/include/libfdt_env.h \ All host-tools are forced to include libfdt_env.h even if they are totally unrelated to FDT. Then, <stdbool.h> is indirectly included as follows: include/libfdt_env.h -> include/linux/types.h -> <stdbool.h> I am fixing this horrible crap. In advance, I need to add necessary include directives explicitly. tools/fdtgrep.c needs more; <fctl.h> for open() and <errno.h> for errno. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-01-28libfdt: migrate fdt_rw.c to a wrapper of scripts/dtc/libfdt/fdt_rw.cMasahiro Yamada
The only difference between scripts/dtc/libfdt/fdt_rw.c and lib/libfdt/fdt_rw.c is fdt_remove_unused_strings(). It is only used by fdtgrep, so we do not need to compile it for U-Boot image. Move it to tools/libfdt/fdw_rw.c so that lib/libfdt/fdt_rw.c can be a wrapper of scripts/dtc/libfdt/fdt_rw.c. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-11-06Do not attempt to use the systemwide libfdtJan Kundrát
U-Boot bundles a patched copy of libfdt, so it's wrong to attempt to include it <like/this>. This breaks the build for me when I have dtc fully installed in my host -- as happened earlier tonight with Buildroot, for example. There are several other occurrences throughout the code where '<libfdt' matches. I'm not modifying these because I have no clue why the <systemwide> include style is being used -- IMHO wrongly. Signed-off-by: Jan Kundrát <jan.kundrat@cesnet.cz>
2017-06-12fdtgrep: Deal with NULL data passed to check_type_include()Simon Glass
Since the parameter can be NULL we must be careful not to dereference it in this case. Signed-off-by: Simon Glass <sjg@chromium.org> Reported-by: Coverity (CID: 163250) Fixes: 1043d0a0 (fdt: Add fdtgrep tool)
2017-04-13fdtgrep: Cope with the /aliases node being lastSimon Glass
With skeleton.dtsi being dropped it is more likely that the /aliases node will be last in the device tree. Update fdtgrep to handle this. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-10-06Various, accumulated typos collected from around the tree.Robert P. J. Day
Fix various misspellings of: * deprecated * partition * preceding,preceded * preparation * its versus it's * export * existing * scenario * redundant * remaining * value * architecture Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Reviewed-by: Jagan Teki <jteki@openedev.com> Reviewed-by: Stefan Roese <sr@denx.de>
2016-03-14fdtgrep: Improve error handling with invalid device treeSimon Glass
This tool requires that the aliases node be the first node in the tree. But when it is not, it does not handle things gracefully. In fact it crashes. Fix this, and add a more helpful error message. Signed-off-by: Simon Glass <sjg@chromium.org> Reported-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-11-04fdtgrep: Simplify the alias generation codeSimon Glass
We don't need to allocate a new region list when we run out of space. The outer function can take care of this for us. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-07-21fdt: Add fdtgrep toolSimon Glass
This tool allows us to extract subsets of a device tree file. It is used by the SPL vuild, which needs to cut down the device tree size for use in limited memory. This tool was originally written for libfdt but it has not been accepted upstream, so for now, include it in U-Boot. Several utilfdt library functions been included inline here. If fdtgrep is eventually accepted in libfdt then we can bring that version of libfdt in here, and drop fdtgrep (requiring that fdtgrep is provided by the user). If it is not accepted then another approach would be to write a special tool for chopping down device tree files for SPL. While it would use the same libfdt support, it would be less code than fdtgrep.c because it would not have general-purpose functions. Another approach (which was used with v1 of this series) is to sprinkler all the device tree files with #ifdef. I don't like that idea. Signed-off-by: Simon Glass <sjg@chromium.org>
