path: root/tools/envcrc.c
2016-11-23tools/env: Correct include kconfigYork Sun
While we move some config macros to Kconfig, kconfig header is needed to avoid compiling error if not already included. Signed-off-by: York Sun <york.sun@nxp.com>
2012-01-05env: remove value from boolean definesIgor Grinberg
Several boolean defines have a value assigned. Remove the value as defining the symbol is enough. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Acked-by: Marek Vasut <marek.vasut@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-12-06tools/envcrc: fix compile breakageIgor Grinberg
When ENV_IS_EMBEDDED is not set, but CONFIG_BUILD_ENVCRC is set, the environment.h file does not get included resulting in unrecognized env_t type. Fix this by moving the include directive. Reported-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Tested-by: Mike Frysinger <vapier@gentoo.org>
2011-11-22env: move extern environment[] to environment.hIgor Grinberg
Extract all extern declarations for environment out of c files into the environment.h header. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2011-07-26env: allow people to force envcrc buildingMike Frysinger
For people who want to manually extract the embedded environment so that it can be manually packed into the final u-boot image, add a config opt to force building of the envcrc tool. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-10-27Revert "env: only build env_embedded and envcrc when needed"Wolfgang Denk
Breaks building on many boards, and no really clean fix available yet. This reverts commit 6dab6add2d8ee80905234b326abc3de11be1d178.
2009-10-19envcrc: check return value of fwrite()Mike Frysinger
Newer toolchains will often complain about unchecked fwrite(): envcrc.c:117: warning: ignoring return value of `fwrite´, declared with attribute warn_unused_result So check the return value to silence the warnings. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-10-18env: only build env_embedded and envcrc when neededMike Frysinger
The env code is protected by the ENV_IS_EMBEDDED define, so attempting to compile the code when this isn't defined is pointless. Now that the env headers have unified around CONFIG_ENV_IS_EMBEDDED, convert the build system to only build the env objects when this is enabled. And now that the env code is conditionally compiled, we can drop the source code checks. For people who want to extract the environment manually, add a new option CONFIG_BUILD_ENVCRC that only enables the envcrc utility. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-06-12tools/envcrc: add --binary option to export embedded envMike Frysinger
The --binary option to envcrc can be used to export the embedded env as a binary blob so that it can be manipulated/examined/whatever externally. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-04-24crc32: use uint32_t rather than unsigned longMike Frysinger
The envcrc.c does sizeof(unsigned long) when calculating the crc, but this is done with the build toolchain instead of the target tool chain, so if the build is a 64bit system but the target is 32bits, the size will obviously be wrong. This converts all unsigned long stuff related to crc32 to uint32_t types. Compile tested only: output of ./tools/envcrc when run on a 32bit build system matches that of a 64bit build system. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2005-08-03Cleanup build problems (on Fedora Core x86_64 build host)Wolfgang Denk
2003-03-06* Patch by Robert Schwebel, 21 Jan 2003:LABEL_2003_03_06_0050wdenk
- Add support for Innokom board - Don't complain if "install" fails - README cleanup (remove duplicated lines) - Update PXA header files * Add documentation for existing POST code (doc/README.POST) * Patch by Laudney Ren, 15 Jan 2003: Fix handling of redundand environment in "tools/envcrc.c" * Patch by Detlev Zundel, 28 Feb 2003: Add bedbug support for 824x systems * Add support for 16 MB flash configuration of TRAB board * Patch by Erwin Rol, 27 Feb 2003: Add support for RTEMS * Add image information to README * Fix dual PCMCIA slot support (when running with just one slot populated) * Add VFD type detection to trab board * extend drivers/cs8900.c driver to synchronize ethaddr environment variable with value in the EEPROM
2002-09-18Initial revisionwdenk
