path: root/tools/env
2010-09-19tools/env: use host build flagsMike Frysinger
Convert the tools/env/Makefile to use the same host tool syntax as the other tool subdirs. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-09-18tools/env: fail on invalid optionsDaniel Hobi
Signed-off-by: Daniel Hobi <daniel.hobi@schmid-telecom.ch>
2010-09-18tools/env: allow option "-n" for fw_printenvDaniel Hobi
In commit bd7b26f8 (Tools: set multiple variable with fw_setenv utility), the option parsing was changed to getopt_long(3), but option "-n" of fw_printenv was not included. This leads to an error message "invalid option -- 'n'" on stderr, although the output on stdout is correct. Signed-off-by: Daniel Hobi <daniel.hobi@schmid-telecom.ch>
2010-08-09tools/env/fw_printenv: Make redundant env work on locked flashes alsoDetlev Zundel
The invalidation of the old environment instance did not work for flashes supporting hardware locking. Now we unlock/lock around this update also. Signed-off-by: Detlev Zundel <dzu@denx.de>
2010-06-29Tools: set multiple variable with fw_setenv utilityStefano Babic
Add a sort of batch mode to fw_setenv, allowing to set multiple variables in one shot, without updating the flash after each set as now. It is added the possibility to pass a config file with a list of pairs <variable, value> to be set, separated by a TAB character. Signed-off-by: Stefano Babic <sbabic@denx.de>
2010-04-13Rename lib_generic/ to lib/Peter Tyser
Now that the other architecture-specific lib directories have been moved out of the top-level directory there's not much reason to have the '_generic' suffix on the common lib directory. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2008-12-15Fix a typo in fw_env.configMartin Michlmayr
Reported-by: Martin Michlmayr <tbm@cyrius.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-10-18Adds two more ethernet interface to 83xxrichardretanubun
Added as a convenience for other platforms that uses MPC8360 (has 8 UCC). Six eth interface is chosen because the platform I am using combines UCC1&2 and UCC3&4 as 1000 Eth and the other four UCCs as 10/100 Eth. Signed-off-by: Richard Retanubun <RichardRetanubun@RugggedCom.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-09-09fw_env: add NAND supportGuennadi Liakhovetski
Add support for environment in NAND with automatic NOR / NAND recognition, including unaligned environment, bad-block skipping, redundant environment copy. Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
2008-09-02fw_env.c: fix build problems with MTD_VERSION=oldWolfgang Denk
(as needed to support old 2.4 Linux kernel based releases) Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-05-09Propagate Error Status to the Shell on fw_printenv ErrorsGrant Erickson
Changed implementation such that fw_printenv returns failure status when one or more specified variables do not exist or when incorrect command syntax is used. This aids scripting fw_printenv such that the script can key of the return status rather than relying on standard error "scraping". Signed-off-by: Grant Erickson <gerickson@nuovations.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-05-09Fix Compilation Errors with 'tools/env/fw_printenv'Grant Erickson
In the current top-of-tree, 1.3.3.-rc2, the optional tool 'tools/env/fw_printenv' fails to compile for two reasons: 1) The header watchdog.h cannot be found. 2) The header zlib.h is picked up from the tool chain rather than the project causing a prototype conflict for crc32. This patch addresses both of these issues. Platforms Tested On: - AMCC "Kilauea" Signed-off-by: Grant Erickson <gerickson@nuovations.com>
2008-01-08Fix compile problem with new env code.Wolfgang Denk
2008-01-08tools: fix fw_printenv tool to compile againMarkus Klotzbücher
This patch updates the fw_printenv/fw_setenv userspace tool to include the correct MTD header in order to compile against current kernel headers. Backward compatibility is preserved by introducing an option MTD_VERSION which can be set to "old" for compilation using the old MTD headers. Along with this a number of warnings are fixed. Signed-off-by: Markus Klotzbuecher <mk@denx.de>
2006-03-12Fix array overflow with fw_setenv on uninitialised environmentWolfgang Denk
Patch by Murray Jensen, 15 Jul 2005
2005-09-25Fix error handling in tools/env/fw_env.cWolfgang Denk
Patch by Ara Avanesyan, 01 Feb 2005
2004-12-31* Code cleanup, mostly for GCC-3.3.xwdenk
* Cleanup confusing use of CONFIG_ETH*ADDR - ust his only to pre-define a MAC address; use CONFIG_HAS_ETH* to enable support for additional ethernet addresses. * Cleanup drivers/i82365.c - avoid duplication of code * Fix bogus "cannot span across banks" flash error message * Add support for CompactFlash for the CPC45 Board.
2003-06-21Patch by Murray Jensen, 20 Jun 2003:wdenk
- hymod update - cleanup (especially for gcc-3.x compilers)
2003-04-20* Make sure Block Lock Bits get cleared in R360MPI flash driverwdenk
* MPC823 LCD driver: Fill color map backwards, to allow for steady display when Linux takes over * Patch by Erwin Rol, 27 Feb 2003: Add support for RTEMS (this time for real). * Add support for "bmp info" and "bmp display" commands to load bitmap images; this can be used (for example in a "preboot" command) to display a splash screen very quickly after poweron. * Add support for 133 MHz clock on INCA-IP board
2003-04-12* Patch by Lutz Dennig, 10 Apr 2003:LABEL_2003_04_15_1900wdenk
Update for R360MPI board * Add new meaning to "autostart" environment variable: If set to "no", a standalone image passed to the "bootm" command will be copied to the load address (and eventually uncompressed), but NOT be started. This can be used to load and uncompress arbitrary data. * Set max brightness for MN11236 displays on TRAB board
2003-02-28* Add support for 16 MB flash configuration of TRAB boardLABEL_2003_02_28_0150wdenk
* Patch by Erwin Rol, 27 Feb 2003: Add support for RTEMS * Add image information to README * Fix dual PCMCIA slot support (when running with just one slot populated) * Add VFD type detection to trab board * extend drivers/cs8900.c driver to synchronize ethaddr environment variable with value in the EEPROM * Start adding MIPS support files
2003-02-14Add "pcidelay" environment variable (in ms, enabled via CONFIG_PCI_BOOTDELAY).stroese
2003-01-11* Restrict baudrate settings on LWMON to higher speedsLABEL_2003_01_11_1050wdenk
when watchdog is on * Update baudrate in bd_info when it gets changed * Add watchdog trigger points while waiting for serial port (so far only 8xx -- needed on LWMON with 100ms watchdog) * Improve command line tool to access the U-Boot's environment (figuration of the utility, using a config file)
2002-12-17* Use 1-byte-read instead of -write for iprobe() functionwdenk
Add i2c commands to PM826 config * extend I2C POST code: check for list on known addresses
