path: root/tools/env
2016-10-08env: tool: add command line option to input lockfile pathB, Ravi
The default lockname is set to /var/lock. This limits the usage of this application where OS uses different lockfile location parameter. For example, In case of android, the default lock path location is /data. Hence by providing the command line option to input lockfile path will be useful to reuse the tool across multiple operating system. usage: ./fw_printenv -l <lockfile path> Signed-off-by: Ravi Babu <ravibabu@ti.com>
2016-10-06Suspected Spam: Do not open attachements![PATCH 4/6] tools/env: ↵Andreas Fenkart
flash_write_buf: enforce offset to be start of environment This allows to take advantage of the environment being block aligned. This is not a new constraint. Writes always start at the begin of the environment, since the header with CRC/length as there. Every environment modification requires updating the header Signed-off-by: Andreas Fenkart <andreas.fenkart@digitalstrom.com>
2016-10-06tools/env: lookup dev_type directly from flash_read_buf/flash_write_bufAndreas Fenkart
flash_write_buf already looks up size/offset/#sector from struct envdev_s. It can look up mtd_type as well. Same applies to flash_read_buf. Makes the interface simpler Signed-off-by: Andreas Fenkart <andreas.fenkart@digitalstrom.com>
2016-10-06tools/env: pass bad block offset by valueAndreas Fenkart
the offset is not modified by linux ioctl call see mtd_ioctl{drivers/mtd/mtdchar.c} Makes the interface less ambiguous, since the caller can now exclude a modification of blockstart Signed-off-by: Andreas Fenkart <andreas.fenkart@digitalstrom.com>
2016-10-06tools/env: factor out environment_end functionAndreas Fenkart
instead of adhoc computation of the environment end, use a function with a proper name Signed-off-by: Andreas Fenkart <andreas.fenkart@digitalstrom.com>
2016-08-20tools/env: soften warning about erase block alignmentAndreas Fenkart
addon 183923d3e MMC/SATA have no erase blocks, only blocks. Hence the warning about erase block alignment might be confusing in such environment. Signed-off-by: Andreas Fenkart <andreas.fenkart@digitalstrom.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-08-20tools/env: return with error if redundant environments have unequal sizeAndreas Fenkart
For double buffering to work, the target buffer must always be big enough to hold all data. This can only be ensured if buffers are of equal size, otherwise one must be smaller and we risk data loss when copying from the bigger to the smaller buffer. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Andreas Fenkart <andreas.fenkart@digitalstrom.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-08-15tools/env: ensure environment starts at erase block boundaryAndreas Fenkart
56086921 added support for unaligned environments access. U-boot itself does not support this: - env_nand.c fails when using an unaligned offset. It produces an error in nand_erase_opts{drivers/mtd/nand/nand_util.c} - in env_sf/env_flash the unused space at the end is preserved, but not in the beginning. block alignment is assumed - env_sata/env_mmc aligns offset/length to the block size of the underlying device. data is silently redirected to the beginning of a block There is seems no use case for unaligned environment. If there is some useful data at the beginning of the the block (e.g. end of u-boot) that would be very unsafe. If the redundant environments are hosted by the same erase block then that invalidates the idea of double buffering. It might be that unaligned access was allowed in the past, and that people with legacy u-boot are trapped. But at the time of 56086921 it wasn't supported and due to reasons above I guess it was never introduced. I prefer to remove that (unused) feature in favor of simplicity Signed-off-by: Andreas Fenkart <andreas.fenkart@digitalstrom.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2016-07-26tools: env: Fix format warnings in debugMarcin Niestroj
Format warnings (-Wformat) were shown in printf() calls after defining DEBUG macro. Update format string and explicitly cast variables to suppress all warnings. Signed-off-by: Marcin Niestroj <m.niestroj@grinn-global.com>
2016-07-22tools/env: reuse fw_getenv in fw_printenv functionAndreas Fenkart
Try to avoid adhoc iteration of the environment. Reuse fw_getenv to find the variables that should be printed. Only use open-coded iteration when printing all variables. For backwards compatibility, keep emitting a newline when printing with value_only. Signed-off-by: Andreas Fenkart <andreas.fenkart@digitalstrom.com>
2016-07-22tools/env: move envmatch further up in file to avoid forward declarationsAndreas Fenkart
forward declaration not needed when re-ordered Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Andreas Fenkart <andreas.fenkart@digitalstrom.com>
2016-07-22tools/env: kernel-doc for fw_printenv, fw_getenv and fw_parse_scriptAndreas Fenkart
there are two groups of functions: - application ready tools: fw_setenv/fw_getenv/fw_parse_script these are used, when creating a single binary containing multiple tools (busybox like) - file access like: open/read/write/close above functions are implemented on top of these. applications can use those to modify several variables without creating a temporary batch script file tested with "./scripts/kernel-doc -html -v tools/env/fw_env.h" Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Andreas Fenkart <andreas.fenkart@digitalstrom.com>
2016-07-22tools/env: allow negative offsetsStefan Agner
A negative value for the offset is treated as a backwards offset for from the end of the device/partition for block devices. This aligns the behavior of the config file with the syntax of CONFIG_ENV_OFFSET where the functionality has been introduced with commit 5c088ee841f9 ("env_mmc: allow negative CONFIG_ENV_OFFSET"). Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-07-22tools/env: complete environment device config earlyStefan Agner
Currently flash_read completes a crucial part of the environment device configuration, the device type (mtd_type). This is rather confusing as flash_io calls flash_read conditionally, and one might think flash_write, which also makes use of mtd_type, gets called before flash_read. But since flash_io is always called with O_RDONLY first, this is not actually the case in reality. However, it is much cleaner to complete and verify the config early in parse_config. This also prepares the code for further extension. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Reviewed-by: Andreas Fenkart
2016-07-16Various, unrelated tree-wide typo fixes.Robert P. J. Day
Fix a number of typos, including: * "compatble" -> "compatible" * "eanbeld" -> "enabled" * "envrionment" -> "environment" * "FTD" -> "FDT" (for "flattened device tree") * "ommitted" -> "omitted" * "overriden" -> "overridden" * "partiton" -> "partition" * "propogate" -> "propagate" * "resourse" -> "resource" * "rest in piece" -> "rest in peace" * "suport" -> "support" * "varible" -> "variable" Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca>
2016-05-31tools/env: allow to pass NULL for environment optionsAndreas Fenkart
If users of the library are happy with the default, e.g. config file name. They can pass NULL as the opts pointer. This simplifies the transition of existing library users. FIXES a compile error. since common_args has been removed by a previous patch Signed-off-by: Andreas Fenkart <andreas.fenkart@digitalstrom.com>
2016-05-27tools/env: no global variable sharing between application and libraryAndreas Fenkart
2016-05-27tools/env: compute size of usable area only onceAndreas Fenkart
for double buffering to work, redundant buffers must have equal size Signed-off-by: Andreas Fenkart <andreas.fenkart@digitalstrom.com>
2016-05-27tools/env: fw_printenv pass value_only as argumentAndreas Fenkart
2016-05-27tools/env: remove 'extern' from function prototype in fw_env.hAndreas Fenkart
checkpatch complains about in succeding patch. Prefer to fix all declarations in a dedicated patch. Signed-off-by: Andreas Fenkart <andreas.fenkart@digitalstrom.com>
2016-05-27tools/env: pass key as argument to env_aes_cbc_cryptAndreas Fenkart
2016-05-02tools: env: fix config file loading in env libraryAnatolij Gustschin
env library is broken as the config file pointer is only initialized in main(). When running in the env library parse_config() fails: Cannot parse config file '(null)': Bad address Ensure that config file pointer is always initialized. Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: Stefano Babic <sbabic@denx.de>
2016-03-27tools: env: bug: config structs must be defined in tools libraryAndreas Fenkart
fw_senten/fw_printenv can be compiled as a tools library, excluding the fw_env_main object. Reported-by: Stefano Babic <sbabic@denx.de> Signed-off-by: Andreas Fenkart <andreas.fenkart@digitalstrom.com>
2016-03-26tools: env: fw_parse_script: simplify removal of newline/carriage returnAndreas Fenkart
fgets returns when the first '\n' is found Signed-off-by: Andreas Fenkart <andreas.fenkart@digitalstrom.com>
2016-03-26tools: env: split fw_string_blank into skip_chars / skip_blanksAndreas Fenkart
2016-03-26tools: env: fw_string_blank: return from loop when item foundAndreas Fenkart
2016-03-26tools: env: replace WHITESPACE macro by isblankAndreas Fenkart
2016-03-22Fix spelling of "comment".Vagrant Cascadian
Signed-off-by: Vagrant Cascadian <vagrant@debian.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-02-08tools: env: update usage stringsAndreas Fenkart
2016-02-08tools: env: factor out parse_common_argsAndreas Fenkart
2016-02-08tools: env: shift optind arguments and fix argument indicesAndreas Fenkart
2016-02-08tools: env: parse aes key / suppress flag into argument structAndreas Fenkart
disabled original parsing, but not yet removed since the argument indexing needs to be fixed Signed-off-by: Andreas Fenkart <andreas.fenkart@digitalstrom.com>
2016-02-08tools: env: introduce setenv/printenv argument structsAndreas Fenkart
goal is to use getopt for all argument parsing instead of adhoc parsing in fw_getenv/fw_setenv functions Signed-off-by: Andreas Fenkart <andreas.fenkart@digitalstrom.com>
2016-02-08tools: env: make parse_aes_key statelessAndreas Fenkart
2016-02-08tools: env validate: pass values as 0-based arrayAndreas Fenkart
passing argv/argc can produce off-by-one errors Signed-off-by: Andreas Fenkart <andreas.fenkart@digitalstrom.com>
2015-12-13tools: env: include compiler.hPeter Robinson
With gcc 5.2 and later we get a bunch of "error: unknown type name" for 'uint8_t', 'uint32_t' and friends. Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
2015-11-18Allow fw env tools to be available as libraryStefano Babic
Sometimes it can be useful to link the fw_ tools instead of having the fw_setenv/fw_printenv installed. Patch exports the tool as library and allowes to link it with own programs. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Tom Rini <trini@konsulko.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-11-18tools/env: allow config filename to be passed via command line argumentMichael Heimpold
When for example generating/manipulating SD card/eMMC images which contain U-Boot and its environment(s), it is handy to use a given configuration file instead of the compiled-in default one. And since the default configuration file is expected under /etc it's hard for an usual linux user account without special permissions to use fw_printenv/fw_setenv for this purpose. So allow to pass an optional filename via a new '-c' command line argument. Example: $ ln -s fw_printenv tools/env/fw_setenv $ cat fw_env.config test.img 0x20000 0x20000 test.img 0x40000 0x20000 $ tools/env/fw_printenv -c ./fw_env.config fdt_file fdt_file=imx28-duckbill.dtb $ tools/env/fw_setenv -c ./fw_env.config fdt_file imx28-duckbill-spi.dtb $ tools/env/fw_printenv -c ./fw_env.config fdt_file fdt_file=imx28-duckbill-spi.dtb Signed-off-by: Michael Heimpold <mhei@heimpold.de>
2015-06-18tools/env/fw_env.h: Correct include orderPeter Robinson
When building tools-only (or env) we need to be sure that we do use <linux/kconfig.h> and do not use <generated/autoconf.h>. This will fix problems such as running 'make defconfig' or 'make sandbox_config' and then 'make tools-only'. Based on the responses below to the thread add linux/kconfig.h higher in the includes and drop the now unneeded autoconf.h lower down to ensure the default environment is included correctly http://lists.denx.de/pipermail/u-boot/2015-June/216849.html Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
2015-05-08Fix musl buildJörg Krause
This patch fixes cross-compiling U-Boot tools with the musl C library: * including <sys/types.h> is needed for ulong * defining _GNU_SOURCE is needed for loff_t Tested for target at91sam9261ek_dataflash_cs3. Signed-off-by: Jörg Krause <joerg.krause@embedded.rocks> Cc: Tom Rini <trini@konsulko.com>
2015-05-05fw_env.h: include autoconf.hMax Krummenacher
Without this, when CONFIG_ENV_VARS_UBOOT_CONFIG is active we get a compile time error when doing 'make env'. In file included from tools/env/fw_env.c:117:0: include/env_default.h:110:11: error: expected ‘}’ before ‘CONFIG_SYS_ARCH’ When building U-Boot this is included indirectly by the compiler switch -include /home/trdx/git.toradex.com/u-boot-2014.10-toradex/include/linux/kconfig.h Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2015-02-17add example for file on VFAT filesystem usageWaldemar Brodkorb
For example on a raspberry pi the u-boot environment can be saved in a file on the first VFAT partition. This example illustrates how to use it with fw_printenv/fw_setenv. Signed-off-by: Waldemar Brodkorb <wbx@openadk.org>
2014-11-07tools/env: Fix environment size and CRC on 64-bit hostsDominic Sacré
On architectures where 'long' is 64 bit, the u-boot environment as seen by the fw_env tools was missing 4 bytes. This patch fixes getenvsize(), and thus also ensures that the environment's CRC32 checksum is calculated correctly. Signed-off-by: Dominic Sacré <dominic.sacre@gmx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Tom Rini <trini@ti.com>
2014-09-24tools/env: change stripping strategy to allow no-strippingThomas Petazzoni
When building the U-Boot tools for non-ELF platforms (such as Blackfin FLAT), since commit 79fc0c5f498c3982aa4740c273ab1a9255063d9c ("tools/env: cross-compile fw_printenv without setting HOSTCC"), the build fails because it tries to strip a FLAT binary, which does not make sense. This commit solves this by changing the stripping logic in tools/env/Makefile to be similar to the one in tools/Makefile. This logic continues to apply strip to the final binary, but does not abort the build if it fails, and does the stripping in place on the final binary. This allows the logic to work fine if stripping doesn't work, as it leaves the final binary untouched. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Sonic Zhang <sonic.zhang@analog.com> Reviewed-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Sonic Zhang <sonic.zhang@analog.com>
2014-07-30kconfig: switch to KconfigMasahiro Yamada
This commit enables Kconfig. Going forward, we use Kconfig for the board configuration. mkconfig will never be used. Nor will include/config.mk be generated. Kconfig must be adjusted for U-Boot because our situation is a little more complicated than Linux Kernel. We have to generate multiple boot images (Normal, SPL, TPL) from one source tree. Each image needs its own configuration input. Usage: Run "make <board>_defconfig" to do the board configuration. It will create the .config file and additionally spl/.config, tpl/.config if SPL, TPL is enabled, respectively. You can use "make config", "make menuconfig" etc. to create a new .config or modify the existing one. Use "make spl/config", "make spl/menuconfig" etc. for spl/.config and do likewise for tpl/.config file. The generic syntax of configuration targets for SPL, TPL is: <target_image>/<config_command> Here, <target_image> is either 'spl' or 'tpl' <config_command> is 'config', 'menuconfig', 'xconfig', etc. When the configuration is done, run "make". (Or "make <board>_defconfig all" will do the configuration and build in one time.) For futher information of how Kconfig works in U-Boot, please read the comment block of scripts/multiconfig.py. By the way, there is another item worth remarking here: coexistence of Kconfig and board herder files. Prior to Kconfig, we used C headers to define a set of configs. We expect a very long term to migrate from C headers to Kconfig. Two different infractructure must coexist in the interim. In our former configuration scheme, include/autoconf.mk was generated for use in makefiles. It is still generated under include/, spl/include/, tpl/include/ directory for the Normal, SPL, TPL image, respectively. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-05-12tools: env: Add aes.c placeholderMarek Vasut
Add missing aes.c placeholder which includes lib/aes.c . Without this one, tools/env/ will fail to build. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Alexey Brodkin <Alexey.Brodkin@synopsys.com> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com> Tested-by: Alexey Brodkin <abrodkin@synopsys.com> Tested-by: Heiko Schocher <hs@denx.de>
2014-05-09Merge branch 'u-boot/master'Albert ARIBAUD
Conflicts: drivers/net/Makefile (trivial merge)
2014-04-17fw_env.c: Switch get_config to use '%ms' in sscanfTom Rini
We currently limit ourself to 16 characters for the device name to read the environment from. This is insufficient for /dev/mmcblk0boot1 to work for example. Switch to '%ms' which gives us a dynamically allocated buffer instead. We're short lived enough to not bother free()ing the buffer. Signed-off-by: Tom Rini <trini@ti.com>
2014-03-21env: Implement support for AES encryption into fw_* toolsMarek Vasut
Implement support for encrypting/decrypting the environment block into the tools/env/fw_* tools. The cipher used is AES 128 CBC and the implementation depends solely on components internal to U-Boot. To allow building against the internal AES library, the library did need minor adjustments to not include U-Boot's headers which are not wanted to be included and define missing types. Signed-off-by: Marek Vasut <marex@denx.de>
2014-03-12kbuild: rename SRCTREE to srctreeMasahiro Yamada
Prior to Kbuild, $(TOPDIR) or $(SRCTREE) was used for pointing to the top of source directory. (No difference between the two.) In Kbuild style, $(srctree) is used for instead. This commit renames SRCTREE to srctree and deletes the defition of SRCTREE. Note that SRCTREE in scripts/kernel-doc, scripts/docproc.c, doc/DocBook/Makefile should be keep. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
