path: root/tools/easylogo
2006-09-01tools/easylogo/easylogo.cMarian Balakowicz
2003-03-06* Patches by Robert Schwebel, 06 Mar 2003:wdenk
- fix bug in BOOTP code (must use NetCopyIP) - update of CSB226 port - clear BSS segment on XScale - added support for i2c_init_board() function - update to the Innokom plattform * Extend support for redundand environments for configurations where environment size < sector size
2000-10-14Initial revisionwdenk
