path: root/tools/dtoc/test_fdt
2018-07-09dtoc: Add some tests for the fdt moduleSimon Glass
At present this module is tested via the dtoc tests. This is a bit painful since the tests are at a higher level and so failures are more difficult to diagnose. Add some tests that exercise the fdt module directly. Signed-off-by: Simon Glass <sjg@chromium.org>
